{"name":"PI North America","description":"The leader in Industrial Ethernet &amp; Fieldbus","url":"https:\/\/us.profinet.com","home":"https:\/\/us.profinet.com","gmt_offset":-7,"timezone_string":"America\/Phoenix","page_for_posts":21398,"page_on_front":4,"show_on_front":"page","namespaces":["oembed\/1.0","fl-controls\/v1","code-snippets\/v1","mailin\/v1","wordfence\/v1","wp-fusion\/v1","whm\/v3","ldlms\/v1","ldlms\/v2","pll\/v1","ee\/v4.8.29","ee\/v4.8.33","ee\/v4.8.34","ee\/v4.8.36","google-site-kit\/v1","bsf-core\/v1","nps-survey\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":[],"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"The URL of the resource for which to fetch oEmbed data.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"The URL of the resource for which to fetch oEmbed data.","type":"string","format":"uri","required":true},"format":{"description":"The oEmbed format to use.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"The maximum width of the embed frame in pixels.","type":"integer","default":600,"required":false},"maxheight":{"description":"The maximum height of the embed frame in pixels.","type":"integer","required":false},"discover":{"description":"Whether to perform an oEmbed discovery request for unsanctioned providers.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/oembed\/1.0\/proxy"}]}},"\/fl-controls\/v1":{"namespace":"fl-controls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"fl-controls\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/fl-controls\/v1"}]}},"\/fl-controls\/v1\/state":{"namespace":"fl-controls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/fl-controls\/v1\/state"}]}},"\/fl-controls\/v1\/color_presets":{"namespace":"fl-controls\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/fl-controls\/v1\/color_presets"}]}},"\/fl-controls\/v1\/background_presets":{"namespace":"fl-controls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/fl-controls\/v1\/background_presets"}]}},"\/fl-controls\/v1\/attachment_sizes":{"namespace":"fl-controls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/fl-controls\/v1\/attachment_sizes"}]}},"\/code-snippets\/v1":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"code-snippets\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1"}]}},"\/code-snippets\/v1\/snippets":{"namespace":"code-snippets\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Descriptive title for the snippet.","type":"string","required":false},"desc":{"description":"Descriptive text associated with snippet.","type":"string","required":false},"code":{"description":"Executable snippet code.","type":"string","required":false},"tags":{"description":"List of tag categories the snippet belongs to.","type":"array","items":{"type":"string"},"required":false},"scope":{"description":"Context in which the snippet is executable.","type":"string","required":false},"condition_id":{"description":"Identifier of condition linked to this snippet.","type":"integer","required":false},"active":{"description":"Snippet activation status.","type":"boolean","required":false},"priority":{"description":"Relative priority in which the snippet is executed.","type":"integer","required":false},"network":{"description":"Whether the snippet is network-wide instead of site-wide.","type":["boolean","null"],"required":false},"shared_network":{"description":"If a network snippet, whether can be activated on discrete sites instead of network-wide.","type":["boolean","null"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/snippets"}]}},"\/code-snippets\/v1\/snippets\/(?P<id>[\\d]+)":{"namespace":"code-snippets\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Descriptive title for the snippet.","type":"string","required":false},"desc":{"description":"Descriptive text associated with snippet.","type":"string","required":false},"code":{"description":"Executable snippet code.","type":"string","required":false},"tags":{"description":"List of tag categories the snippet belongs to.","type":"array","items":{"type":"string"},"required":false},"scope":{"description":"Context in which the snippet is executable.","type":"string","required":false},"condition_id":{"description":"Identifier of condition linked to this snippet.","type":"integer","required":false},"active":{"description":"Snippet activation status.","type":"boolean","required":false},"priority":{"description":"Relative priority in which the snippet is executed.","type":"integer","required":false},"network":{"description":"Whether the snippet is network-wide instead of site-wide.","type":["boolean","null"],"required":false},"shared_network":{"description":"If a network snippet, whether can be activated on discrete sites instead of network-wide.","type":["boolean","null"],"required":false}}},{"methods":["DELETE"],"args":[]}]},"\/code-snippets\/v1\/snippets\/schema":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/snippets\/schema"}]}},"\/code-snippets\/v1\/snippets\/(?P<id>[\\d]+)\/activate":{"namespace":"code-snippets\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/code-snippets\/v1\/snippets\/(?P<id>[\\d]+)\/deactivate":{"namespace":"code-snippets\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/code-snippets\/v1\/snippets\/(?P<id>[\\d]+)\/export":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/code-snippets\/v1\/snippets\/(?P<id>[\\d]+)\/export-code":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/code-snippets\/v1\/insert-headers-and-footers":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/insert-headers-and-footers"}]}},"\/code-snippets\/v1\/insert-headers-and-footers\/import":{"namespace":"code-snippets\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"type":"array","required":false},"network":{"type":"boolean","required":false},"auto_add_tags":{"type":"boolean","required":false},"tag_value":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/insert-headers-and-footers\/import"}]}},"\/code-snippets\/v1\/header-footer-code-manager":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/header-footer-code-manager"}]}},"\/code-snippets\/v1\/header-footer-code-manager\/import":{"namespace":"code-snippets\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"type":"array","required":false},"network":{"type":"boolean","required":false},"auto_add_tags":{"type":"boolean","required":false},"tag_value":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/header-footer-code-manager\/import"}]}},"\/code-snippets\/v1\/insert-php-code-snippet":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/insert-php-code-snippet"}]}},"\/code-snippets\/v1\/insert-php-code-snippet\/import":{"namespace":"code-snippets\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"type":"array","required":false},"network":{"type":"boolean","required":false},"auto_add_tags":{"type":"boolean","required":false},"tag_value":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/insert-php-code-snippet\/import"}]}},"\/code-snippets\/v1\/importers":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/importers"}]}},"\/code-snippets\/v1\/file-upload\/parse":{"namespace":"code-snippets\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/file-upload\/parse"}]}},"\/code-snippets\/v1\/file-upload\/import":{"namespace":"code-snippets\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"snippets":{"description":"Array of snippet data to import","type":"array","required":true},"duplicate_action":{"description":"Action to take when duplicate snippets are found","type":"string","enum":["ignore","replace","skip"],"default":"ignore","required":false},"network":{"description":"Whether to import to network table","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/code-snippets\/v1\/file-upload\/import"}]}},"\/mailin\/v1":{"namespace":"mailin\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"mailin\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/mailin\/v1"}]}},"\/mailin\/v1\/testconnection":{"namespace":"mailin\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/mailin\/v1\/testconnection"}]}},"\/mailin\/v1\/mailin_disconnect":{"namespace":"mailin\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/mailin\/v1\/mailin_disconnect"}]}},"\/wordfence\/v1":{"namespace":"wordfence\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wordfence\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wordfence\/v1"}]}},"\/wordfence\/v1\/authenticate":{"namespace":"wordfence\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wordfence\/v1\/authenticate"}]}},"\/wordfence\/v1\/authenticate-premium":{"namespace":"wordfence\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wordfence\/v1\/authenticate-premium"}]}},"\/wordfence\/v1\/config":{"namespace":"wordfence\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wordfence\/v1\/config"}]}},"\/wordfence\/v1\/disconnect":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wordfence\/v1\/disconnect"}]}},"\/wordfence\/v1\/premium-connect":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wordfence\/v1\/premium-connect"}]}},"\/wordfence\/v1\/scan\/issues":{"namespace":"wordfence\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wordfence\/v1\/scan\/issues"}]}},"\/wordfence\/v1\/scan":{"namespace":"wordfence\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wordfence\/v1\/scan"}]}},"\/wordfence\/v1\/scan\/issue":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wordfence\/v1\/scan\/issue"}]}},"\/wp-fusion\/v1":{"namespace":"wp-fusion\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-fusion\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-fusion\/v1"}]}},"\/wp-fusion\/v1\/available-tags":{"namespace":"wp-fusion\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-fusion\/v1\/available-tags"}]}},"\/wp-fusion\/v1\/update-available-tags":{"namespace":"wp-fusion\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-fusion\/v1\/update-available-tags"}]}},"\/wp-fusion\/v1\/sync-tags":{"namespace":"wp-fusion\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-fusion\/v1\/sync-tags"}]}},"\/whm\/v3":{"namespace":"whm\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"whm\/v3","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/whm\/v3"}]}},"\/whm\/v3\/themesettings":{"namespace":"whm\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/whm\/v3\/themesettings"}]}},"\/whm\/v3\/themecss\/(?P<post_id>\\d+)":{"namespace":"whm\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/whm\/v3\/settings":{"namespace":"whm\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/whm\/v3\/settings"}]}},"\/whm\/v3\/plugins":{"namespace":"whm\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/whm\/v3\/plugins"}]}},"\/whm\/v3\/pluginsettings":{"namespace":"whm\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/whm\/v3\/pluginsettings"}]}},"\/whm\/v3\/advancedactions":{"namespace":"whm\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/whm\/v3\/advancedactions"}]}},"\/whm\/v3\/fonts":{"namespace":"whm\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/whm\/v3\/fonts"}]}},"\/whm\/v3\/templatelibrary":{"namespace":"whm\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/whm\/v3\/templatelibrary"}]}},"\/whm\/v3\/sendtestmail":{"namespace":"whm\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/whm\/v3\/sendtestmail"}]}},"\/ldlms\/v1":{"namespace":"ldlms\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ldlms\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v1"}]}},"\/ldlms\/v1\/echo":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v1\/echo"}]}},"\/ldlms\/v1\/sfwd-courses":{"namespace":"ldlms\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"course_materials":{"description":"Course Materials","type":"html","required":false},"course_price_type":{"default":"open","description":"Course Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"Custom Button URL","type":"text","required":false},"course_price":{"description":"Course Price","type":"text","required":false},"course_prerequisite_enabled":{"default":false,"description":"Enable Course Prerequisites","type":"boolean","required":false},"course_prerequisite":{"default":[],"description":"Course Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"default":"ANY","description":"Course Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Enable Course Points","type":"boolean","required":false},"course_points":{"description":"Course Points","type":"number","required":false},"course_points_access":{"description":"Course Points Access","type":"number","required":false},"course_disable_lesson_progression":{"default":0,"description":"Disable Lesson Progression","type":"boolean","required":false},"expire_access":{"description":"Expire Access","type":"boolean","required":false},"expire_access_days":{"description":"Expire Access After (days)","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Course and Quiz Data After Expiration","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v1\/sfwd-courses"}]}},"\/ldlms\/v1\/sfwd-courses\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":true},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"course_materials":{"description":"Course Materials","type":"html","required":false},"course_price_type":{"description":"Course Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"Custom Button URL","type":"text","required":false},"course_price":{"description":"Course Price","type":"text","required":false},"course_prerequisite_enabled":{"description":"Enable Course Prerequisites","type":"boolean","required":false},"course_prerequisite":{"description":"Course Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"description":"Course Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Enable Course Points","type":"boolean","required":false},"course_points":{"description":"Course Points","type":"number","required":false},"course_points_access":{"description":"Course Points Access","type":"number","required":false},"course_disable_lesson_progression":{"description":"Disable Lesson Progression","type":"boolean","required":false},"expire_access":{"description":"Expire Access","type":"boolean","required":false},"expire_access_days":{"description":"Expire Access After (days)","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Course and Quiz Data After Expiration","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v1\/sfwd-courses\/(?P<id>[\\d]+)\/steps":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Course ID to enroll user into.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Filter returned results by step type.","type":"string","default":"all","enum":["all","h","l","t","r"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Course ID to enroll user into.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Filter returned results by step type.","type":"string","default":"all","enum":["all","h","l","t","r"],"required":false}}}]},"\/ldlms\/v1\/sfwd-courses\/(?P<id>[\\d]+)\/users":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Course ID.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"roles":{"description":"Limit result set to users matching at least one specific role provided. Accepts csv list or single role.","type":"array","items":{"type":"string"},"required":false},"slug":{"description":"Limit result set to users with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Course ID.","type":"integer","required":true},"user_ids":{"description":"User IDs to enroll into course. Limit 50 per request.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Course ID.","type":"integer","required":true},"user_ids":{"description":"User IDs to remove from group. Limit 50 per request.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/sfwd-courses\/(?P<id>[\\d]+)\/groups":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Course ID to enroll into.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Course ID to enroll into.","type":"integer","required":true},"group_ids":{"description":"Group IDs to enroll into Course.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Course ID to enroll into.","type":"integer","required":true},"group_ids":{"description":"Group IDs to remove from Course.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/sfwd-lessons":{"namespace":"ldlms\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limit result set to items with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limit result set to items except those with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limit result set to items with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limit result set to items except those with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"ld_lesson_category":{"description":"Limit result set to items with specific terms assigned in the ld_lesson_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_lesson_category_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_lesson_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_lesson_tag":{"description":"Limit result set to items with specific terms assigned in the ld_lesson_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_lesson_tag_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_lesson_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the post in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the post in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_category":{"description":"The terms assigned to the post in the ld_lesson_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_tag":{"description":"The terms assigned to the post in the ld_lesson_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"lesson_materials":{"description":"Lesson Materials","type":"html","required":false},"forced_lesson_time":{"default":"","description":"Forced Lesson Timer","type":"text","required":false},"lesson_assignment_upload":{"default":0,"description":"Upload Assignment","type":"boolean","required":false},"auto_approve_assignment":{"default":"on","description":"Auto Approve Assignment","type":"boolean","required":false},"assignment_upload_limit_count":{"default":"1","description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_deletion_enabled":{"default":0,"description":"Allow Student to Delete own Assignment(s)","type":"boolean","required":false},"lesson_assignment_points_enabled":{"default":0,"description":"Award Points for Assignment","type":"boolean","required":false},"lesson_assignment_points_amount":{"default":0,"description":"Set Number of Points for Assignment","type":"number","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Allowed File Size","type":"text","required":false},"visible_after":{"default":0,"description":"Make Lesson visible X Days After Sign-up","type":"number","required":false},"visible_after_specific_date":{"description":"Make Lesson Visible on Specific Date","type":"wp_date_selector","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v1\/sfwd-lessons"}]}},"\/ldlms\/v1\/sfwd-lessons\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the post in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the post in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_category":{"description":"The terms assigned to the post in the ld_lesson_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_tag":{"description":"The terms assigned to the post in the ld_lesson_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"lesson_materials":{"description":"Lesson Materials","type":"html","required":false},"forced_lesson_time":{"description":"Forced Lesson Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Upload Assignment","type":"boolean","required":false},"auto_approve_assignment":{"description":"Auto Approve Assignment","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_deletion_enabled":{"description":"Allow Student to Delete own Assignment(s)","type":"boolean","required":false},"lesson_assignment_points_enabled":{"description":"Award Points for Assignment","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Set Number of Points for Assignment","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false},"visible_after":{"description":"Make Lesson visible X Days After Sign-up","type":"number","required":false},"visible_after_specific_date":{"description":"Make Lesson Visible on Specific Date","type":"wp_date_selector","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v1\/sfwd-topic":{"namespace":"ldlms\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"ld_topic_category":{"description":"Limit result set to items with specific terms assigned in the ld_topic_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_category_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_topic_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_topic_tag":{"description":"Limit result set to items with specific terms assigned in the ld_topic_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_tag_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_topic_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Lesson. Must be used with Course parameter.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"ld_topic_category":{"description":"The terms assigned to the post in the ld_topic_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"The terms assigned to the post in the ld_topic_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"topic_materials":{"description":"Topic Materials","type":"html","required":false},"forced_lesson_time":{"default":"","description":"Forced Topic Timer","type":"text","required":false},"lesson_assignment_upload":{"default":0,"description":"Upload Assignment","type":"boolean","required":false},"auto_approve_assignment":{"default":"on","description":"Auto Approve Assignment","type":"boolean","required":false},"assignment_upload_limit_count":{"default":"1","description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_points_enabled":{"default":0,"description":"Award Points for Assignment","type":"boolean","required":false},"lesson_assignment_points_amount":{"default":0,"description":"Set Number of Points for Assignment","type":"number","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Allowed File Size","type":"text","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v1\/sfwd-topic"}]}},"\/ldlms\/v1\/sfwd-topic\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"ld_topic_category":{"description":"The terms assigned to the post in the ld_topic_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"The terms assigned to the post in the ld_topic_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"topic_materials":{"description":"Topic Materials","type":"html","required":false},"forced_lesson_time":{"description":"Forced Topic Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Upload Assignment","type":"boolean","required":false},"auto_approve_assignment":{"description":"Auto Approve Assignment","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_points_enabled":{"description":"Award Points for Assignment","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Set Number of Points for Assignment","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v1\/sfwd-quiz":{"namespace":"ldlms\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Lesson. Pass zero to show global Course Quizzes. Must be used with Course parameter.","type":"integer","required":false},"topic":{"description":"Limit results to be within a specific Topic. Must be used with Course parameter.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"quiz_materials":{"description":"Quiz Materials","type":"html","required":false},"threshold":{"default":"0.8","description":"Certificate Threshold","type":"text","required":false},"passingpercentage":{"default":"80","description":"Passing Percentage","type":"text","required":false},"certificate":{"default":"","description":"Associated Certificate","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v1\/sfwd-quiz"}]}},"\/ldlms\/v1\/sfwd-quiz\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the quiz object.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the quiz object.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"quiz_materials":{"description":"Quiz Materials","type":"html","required":false},"threshold":{"description":"Certificate Threshold","type":"text","required":false},"passingpercentage":{"description":"Passing Percentage","type":"text","required":false},"certificate":{"description":"Associated Certificate","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the quiz object.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v1\/groups":{"namespace":"ldlms\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v1\/groups"}]}},"\/ldlms\/v1\/groups\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":true},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v1\/groups\/(?P<id>[\\d]+)\/courses":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Group ID to enroll into.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Group ID to enroll into.","type":"integer","required":true},"course_ids":{"description":"Course IDs to enroll into group.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Group ID to enroll into.","type":"integer","required":true},"course_ids":{"description":"Course IDs to remove from group.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/groups\/(?P<id>[\\d]+)\/leaders":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"group ID to enroll group leader into.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"roles":{"description":"Limit result set to users matching at least one specific role provided. Accepts csv list or single role.","type":"array","items":{"type":"string"},"required":false},"slug":{"description":"Limit result set to users with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"group ID to enroll group leader into.","type":"integer","required":true},"user_ids":{"description":"Group Leader User IDs to enroll into Group","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"group ID to enroll group leader into.","type":"integer","required":true},"user_ids":{"description":"Group Leader User IDs to remove from Group","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/groups\/(?P<id>[\\d]+)\/users":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"group ID to enroll group leader into.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"roles":{"description":"Limit result set to users matching at least one specific role provided. Accepts csv list or single role.","type":"array","items":{"type":"string"},"required":false},"slug":{"description":"Limit result set to users with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"group ID to enroll group leader into.","type":"integer","required":true},"user_ids":{"description":"User IDs to enroll into Group.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"group ID to enroll group leader into.","type":"integer","required":true},"user_ids":{"description":"User IDs to remove from Group.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/users\/(?P<id>[\\d]+)\/groups":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"User ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"User ID","type":"integer","required":true},"group_ids":{"description":"Group IDs to add to User.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"User ID","type":"integer","required":true},"group_ids":{"description":"Group IDs to remove from User.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/users\/(?P<id>[\\d]+)\/courses":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"User ID to enroll user into.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"User ID to enroll user into.","type":"integer","required":true},"course_ids":{"description":"Courses IDs to add to User.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"User ID to enroll user into.","type":"integer","required":true},"course_ids":{"description":"Courses IDs to remove from User.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/sfwd-questions\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The question ID","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"The question ID","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"The question ID","required":true}}}]},"\/ldlms\/v1\/sections\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":true}}}]},"\/ldlms\/v2":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ldlms\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2"}]}},"\/ldlms\/v2\/sfwd-courses":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"materials_enabled":{"default":false,"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Materials","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"certificate":{"default":0,"description":"Course Certificate","type":"integer","required":false},"exam_challenge":{"default":0,"description":"Challenge Exam Show","type":"integer","required":false},"disable_content_table":{"default":false,"description":"Disable Course Content Table","type":"boolean","required":false},"lessons_per_page":{"default":false,"description":"Custom Pagination","type":"boolean","required":false},"lesson_per_page_custom":{"default":0,"description":"Lessons per page","type":"integer","required":false},"topic_per_page_custom":{"default":0,"description":"Topics per page","type":"integer","required":false},"price_type":{"default":"open","description":"Course Price Type","type":"string","enum":["open","closed","free","paynow","subscribe"],"required":false},"price_type_paynow_price":{"default":"","description":"Pay Now Course Price","type":"string","required":false},"price_type_paynow_enrollment_url":{"default":"","description":"Pay Now course Enrollment URL","type":"string","required":false},"price_type_subscribe_price":{"default":"","description":"Subscribe Course Price","type":"string","required":false},"trial_price":{"default":"","description":"Course Trial Price","type":"string","required":false},"price_type_subscribe_enrollment_url":{"default":"","description":"Subscribe course Enrollment URL","type":"string","required":false},"price_type_closed_price":{"default":"","description":"Closed Course Price","type":"string","required":false},"price_type_closed_custom_button_url":{"default":"","description":"Closed Course Button URL","type":"string","required":false},"prerequisite_enabled":{"default":false,"description":"Course Prerequisites","type":"boolean","required":false},"prerequisite_compare":{"default":"ANY","description":"Prerequisite Compare Mode.","type":"string","enum":["ANY","ALL"],"required":false},"prerequisites":{"default":[],"description":"Prerequisites.","type":"array","items":{"type":"integer"},"required":false},"points_enabled":{"default":false,"description":"Course Points","type":"boolean","required":false},"points_access":{"default":0,"description":"Required for Access","type":"float","required":false},"points_amount":{"default":0,"description":"Awarded on Completion","type":"float","required":false},"expire_access":{"default":false,"description":"Course Access Expiration","type":"boolean","required":false},"expire_access_days":{"description":"Access Period","type":"integer","required":false},"expire_access_delete_progress":{"default":false,"description":"Data Deletion","type":"boolean","required":false},"progression_disabled":{"default":false,"description":"Course Progression Disabled","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/sfwd-courses"}]}},"\/ldlms\/v2\/sfwd-courses\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"materials_enabled":{"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Materials","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"certificate":{"description":"Course Certificate","type":"integer","required":false},"exam_challenge":{"description":"Challenge Exam Show","type":"integer","required":false},"disable_content_table":{"description":"Disable Course Content Table","type":"boolean","required":false},"lessons_per_page":{"description":"Custom Pagination","type":"boolean","required":false},"lesson_per_page_custom":{"description":"Lessons per page","type":"integer","required":false},"topic_per_page_custom":{"description":"Topics per page","type":"integer","required":false},"price_type":{"description":"Course Price Type","type":"string","enum":["open","closed","free","paynow","subscribe"],"required":false},"price_type_paynow_price":{"description":"Pay Now Course Price","type":"string","required":false},"price_type_paynow_enrollment_url":{"description":"Pay Now course Enrollment URL","type":"string","required":false},"price_type_subscribe_price":{"description":"Subscribe Course Price","type":"string","required":false},"trial_price":{"description":"Course Trial Price","type":"string","required":false},"price_type_subscribe_enrollment_url":{"description":"Subscribe course Enrollment URL","type":"string","required":false},"price_type_closed_price":{"description":"Closed Course Price","type":"string","required":false},"price_type_closed_custom_button_url":{"description":"Closed Course Button URL","type":"string","required":false},"prerequisite_enabled":{"description":"Course Prerequisites","type":"boolean","required":false},"prerequisite_compare":{"description":"Prerequisite Compare Mode.","type":"string","enum":["ANY","ALL"],"required":false},"prerequisites":{"description":"Prerequisites.","type":"array","items":{"type":"integer"},"required":false},"points_enabled":{"description":"Course Points","type":"boolean","required":false},"points_access":{"description":"Required for Access","type":"float","required":false},"points_amount":{"description":"Awarded on Completion","type":"float","required":false},"expire_access":{"description":"Course Access Expiration","type":"boolean","required":false},"expire_access_days":{"description":"Access Period","type":"integer","required":false},"expire_access_delete_progress":{"description":"Data Deletion","type":"boolean","required":false},"progression_disabled":{"description":"Course Progression Disabled","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v2\/sfwd-courses\/(?P<id>[\\d]+)\/steps":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Course ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Filter returned results by step type.","type":"string","default":"all","enum":["all","h","l","t","r","co","sections","legacy"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Course ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Filter returned results by step type.","type":"string","default":"all","enum":["all","h","l","t","r","co","sections","legacy"],"required":false}}}]},"\/ldlms\/v2\/sfwd-courses\/(?P<id>[\\d]+)\/prerequisites":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Course ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}}]},"\/ldlms\/v2\/sfwd-courses\/(?P<id>[\\d]+)\/users":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Course ID.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sort collection by user attribute.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limit result set to users with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limit result set to users matching at least one specific role provided. Accepts csv list or single role.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limit result set to users matching at least one specific capability provided. Accepts csv list or single capability.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limit result set to users who are considered authors.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limit result set to users who have published posts.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","igmap":"igmap","um_form":"um_form","um_directory":"um_directory","application-stories":"application-stories","documents":"documents","headlines":"headlines","pi-newsletters":"pi-newsletters","profibus_tech":"profibus_tech","profinet_tech":"profinet_tech","webinar":"webinar","white-papers":"white-papers","sfwd-courses":"sfwd-courses","sfwd-lessons":"sfwd-lessons","sfwd-topic":"sfwd-topic","sfwd-quiz":"sfwd-quiz","sfwd-question":"sfwd-question","ld-exam":"ld-exam","sfwd-certificates":"sfwd-certificates","groups":"groups","fl-builder-template":"fl-builder-template"}},"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Course ID.","type":"integer","required":true},"user_ids":{"description":"User IDs to update in Course. Limit 50 per request.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Course ID.","type":"integer","required":true},"user_ids":{"description":"User IDs to remove from Course. Limit 50 per request.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/sfwd-courses\/(?P<id>[\\d]+)\/groups":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Course ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Course ID","type":"integer","required":true},"group_ids":{"description":"Group IDs to enroll into Course.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Course ID","type":"integer","required":true},"group_ids":{"description":"Group IDs to remove from Course.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/sfwd-lessons":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limit result set to items with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limit result set to items except those with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limit result set to items with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limit result set to items except those with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"ld_lesson_category":{"description":"Limit result set to items with specific terms assigned in the ld_lesson_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_lesson_category_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_lesson_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_lesson_tag":{"description":"Limit result set to items with specific terms assigned in the ld_lesson_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_lesson_tag_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_lesson_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the post in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the post in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_category":{"description":"The terms assigned to the post in the ld_lesson_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_tag":{"description":"The terms assigned to the post in the ld_lesson_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"default":false,"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Materials","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"video_enabled":{"default":false,"description":"Lesson Video Progression Enabled","type":"boolean","required":false},"video_url":{"default":"","description":"Lesson Video Progression URL","type":"text","required":false},"video_shown":{"default":"BEFORE","description":"Lesson Video Shown before or after sub-steps","type":"string","enum":["BEFORE","AFTER"],"required":false},"video_auto_complete":{"default":false,"description":"Lesson Video Auto-complete","type":"boolean","required":false},"video_auto_complete_delay":{"default":0,"description":"Lesson Video Completion Delay (seconds).","type":"integer","required":false},"video_show_complete_button":{"default":false,"description":"Lesson Video Show Mark Complete Button","type":"boolean","required":false},"video_auto_start":{"default":false,"description":"Lesson Video Autostart","type":"boolean","required":false},"video_show_controls":{"default":false,"description":"Lesson Video Controls Display. YouTube and local videos only","type":"boolean","required":false},"video_focus_pause":{"default":false,"description":"Video Pause on Window Unfocused","type":"boolean","required":false},"video_resume":{"default":false,"description":"Video Resume","type":"boolean","required":false},"assignment_upload_enabled":{"default":false,"description":"Lesson Assignment Uploads Enabled","type":"boolean","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Lesson Assignment Allowed file extensions. Comma separated pdf, xls, zip","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Lesson Assignment Upload size limit. Max per server is 100M ","type":"text","required":false},"assignment_points_enabled":{"default":false,"description":"Lesson Assignment Points Enabled","type":"boolean","required":false},"assignment_points_amount":{"default":0,"description":"Lesson Assignment Points Amount","type":"integer","required":false},"assignment_auto_approve":{"default":true,"description":"Lesson Assignment Auto-approve Enabled","type":"boolean","required":false},"assignment_upload_limit_count":{"default":0,"description":"Lesson Assignment Upload Count Limit.","type":"integer","required":false},"assignment_deletion_enabled":{"default":false,"description":"Lesson Assignment Allow File Deletion.","type":"boolean","required":false},"forced_timer_enabled":{"default":false,"description":"Lesson Time Enabled","type":"boolean","required":false},"forced_timer_amount":{"default":0,"description":"Lesson Timer Amount.","type":"integer","required":false},"course":{"default":0,"description":"Associated Course","type":"integer","required":false},"is_sample":{"default":false,"description":"Sample Lesson","type":"boolean","required":false},"visible_type":{"default":"","description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"default":0,"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"default":"","description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false},"is_external":{"default":false,"description":"External Lesson","type":"boolean","required":false},"external_type":{"default":"virtual","description":"Type","type":"string","enum":["virtual","in-person"],"required":false},"external_require_attendance":{"default":"","description":"Require Attendance","type":"string","enum":["","yes"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/sfwd-lessons"}]}},"\/ldlms\/v2\/sfwd-lessons\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limit result set to items with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limit result set to items except those with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limit result set to items with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limit result set to items except those with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"ld_lesson_category":{"description":"Limit result set to items with specific terms assigned in the ld_lesson_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_lesson_category_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_lesson_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_lesson_tag":{"description":"Limit result set to items with specific terms assigned in the ld_lesson_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_lesson_tag_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_lesson_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the post in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the post in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_category":{"description":"The terms assigned to the post in the ld_lesson_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_tag":{"description":"The terms assigned to the post in the ld_lesson_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Materials","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"video_enabled":{"description":"Lesson Video Progression Enabled","type":"boolean","required":false},"video_url":{"description":"Lesson Video Progression URL","type":"text","required":false},"video_shown":{"description":"Lesson Video Shown before or after sub-steps","type":"string","enum":["BEFORE","AFTER"],"required":false},"video_auto_complete":{"description":"Lesson Video Auto-complete","type":"boolean","required":false},"video_auto_complete_delay":{"description":"Lesson Video Completion Delay (seconds).","type":"integer","required":false},"video_show_complete_button":{"description":"Lesson Video Show Mark Complete Button","type":"boolean","required":false},"video_auto_start":{"description":"Lesson Video Autostart","type":"boolean","required":false},"video_show_controls":{"description":"Lesson Video Controls Display. YouTube and local videos only","type":"boolean","required":false},"video_focus_pause":{"description":"Video Pause on Window Unfocused","type":"boolean","required":false},"video_resume":{"description":"Video Resume","type":"boolean","required":false},"assignment_upload_enabled":{"description":"Lesson Assignment Uploads Enabled","type":"boolean","required":false},"assignment_upload_limit_extensions":{"description":"Lesson Assignment Allowed file extensions. Comma separated pdf, xls, zip","type":"text","required":false},"assignment_upload_limit_size":{"description":"Lesson Assignment Upload size limit. Max per server is 100M ","type":"text","required":false},"assignment_points_enabled":{"description":"Lesson Assignment Points Enabled","type":"boolean","required":false},"assignment_points_amount":{"description":"Lesson Assignment Points Amount","type":"integer","required":false},"assignment_auto_approve":{"description":"Lesson Assignment Auto-approve Enabled","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Lesson Assignment Upload Count Limit.","type":"integer","required":false},"assignment_deletion_enabled":{"description":"Lesson Assignment Allow File Deletion.","type":"boolean","required":false},"forced_timer_enabled":{"description":"Lesson Time Enabled","type":"boolean","required":false},"forced_timer_amount":{"description":"Lesson Timer Amount.","type":"integer","required":false},"course":{"description":"Associated Course","type":"integer","required":false},"is_sample":{"description":"Sample Lesson","type":"boolean","required":false},"visible_type":{"description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false},"is_external":{"description":"External Lesson","type":"boolean","required":false},"external_type":{"description":"Type","type":"string","enum":["virtual","in-person"],"required":false},"external_require_attendance":{"description":"Require Attendance","type":"string","enum":["","yes"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v2\/sfwd-topic":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"ld_topic_category":{"description":"Limit result set to items with specific terms assigned in the ld_topic_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_category_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_topic_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_topic_tag":{"description":"Limit result set to items with specific terms assigned in the ld_topic_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_tag_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_topic_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Lesson. Must be used with Course parameter.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"ld_topic_category":{"description":"The terms assigned to the post in the ld_topic_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"The terms assigned to the post in the ld_topic_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"default":false,"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Materials","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"video_enabled":{"default":false,"description":"Topic Video Progression Enabled","type":"boolean","required":false},"video_url":{"default":"","description":"Topic Video Progression URL","type":"text","required":false},"video_shown":{"default":"BEFORE","description":"Topic Video Shown before or after sub-steps","type":"string","enum":["BEFORE","AFTER"],"required":false},"video_auto_complete":{"default":false,"description":"Topic Video Auto-complete","type":"boolean","required":false},"video_auto_complete_delay":{"default":0,"description":"Topic Video Completion Delay (seconds).","type":"integer","required":false},"video_show_complete_button":{"default":false,"description":"Topic Video Show Mark Complete Button","type":"boolean","required":false},"video_auto_start":{"default":false,"description":"Topic Video Autostart","type":"boolean","required":false},"video_show_controls":{"default":false,"description":"Topic Video Controls Display. YouTube and local videos only","type":"boolean","required":false},"video_focus_pause":{"default":false,"description":"Video Pause on Window Unfocused","type":"boolean","required":false},"video_resume":{"default":false,"description":"Video Resume","type":"boolean","required":false},"assignment_upload_enabled":{"default":false,"description":"Topic Assignment Uploads Enabled","type":"boolean","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Topic Assignment Allowed file extensions. Comma separated pdf, xls, zip","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Topic Assignment Upload size limit. Max per server is 100M ","type":"text","required":false},"assignment_points_enabled":{"default":false,"description":"Topic Assignment Points Enabled","type":"boolean","required":false},"assignment_points_amount":{"default":0,"description":"Topic Assignment Points Amount","type":"integer","required":false},"assignment_auto_approve":{"default":true,"description":"Topic Assignment Auto-approve Enabled","type":"boolean","required":false},"assignment_upload_limit_count":{"default":0,"description":"Topic Assignment Upload Count Limit.","type":"integer","required":false},"assignment_deletion_enabled":{"default":false,"description":"Topic Assignment Allow File Deletion.","type":"boolean","required":false},"forced_timer_enabled":{"default":false,"description":"Topic Time Enabled","type":"boolean","required":false},"forced_timer_amount":{"default":0,"description":"Topic Timer Amount.","type":"integer","required":false},"course":{"default":0,"description":"Associated Course","type":"integer","required":false},"lesson":{"default":0,"description":"Associated Lesson","type":"integer","required":false},"visible_type":{"default":"","description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"default":0,"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"default":"","description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false},"is_external":{"default":false,"description":"External Topic","type":"boolean","required":false},"external_type":{"default":"virtual","description":"Type","type":"string","enum":["virtual","in-person"],"required":false},"external_require_attendance":{"default":"","description":"Require Attendance","type":"string","enum":["","yes"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/sfwd-topic"}]}},"\/ldlms\/v2\/sfwd-topic\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"ld_topic_category":{"description":"Limit result set to items with specific terms assigned in the ld_topic_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_category_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_topic_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_topic_tag":{"description":"Limit result set to items with specific terms assigned in the ld_topic_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_tag_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_topic_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Lesson. Must be used with Course parameter.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"ld_topic_category":{"description":"The terms assigned to the post in the ld_topic_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"The terms assigned to the post in the ld_topic_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Materials","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"video_enabled":{"description":"Topic Video Progression Enabled","type":"boolean","required":false},"video_url":{"description":"Topic Video Progression URL","type":"text","required":false},"video_shown":{"description":"Topic Video Shown before or after sub-steps","type":"string","enum":["BEFORE","AFTER"],"required":false},"video_auto_complete":{"description":"Topic Video Auto-complete","type":"boolean","required":false},"video_auto_complete_delay":{"description":"Topic Video Completion Delay (seconds).","type":"integer","required":false},"video_show_complete_button":{"description":"Topic Video Show Mark Complete Button","type":"boolean","required":false},"video_auto_start":{"description":"Topic Video Autostart","type":"boolean","required":false},"video_show_controls":{"description":"Topic Video Controls Display. YouTube and local videos only","type":"boolean","required":false},"video_focus_pause":{"description":"Video Pause on Window Unfocused","type":"boolean","required":false},"video_resume":{"description":"Video Resume","type":"boolean","required":false},"assignment_upload_enabled":{"description":"Topic Assignment Uploads Enabled","type":"boolean","required":false},"assignment_upload_limit_extensions":{"description":"Topic Assignment Allowed file extensions. Comma separated pdf, xls, zip","type":"text","required":false},"assignment_upload_limit_size":{"description":"Topic Assignment Upload size limit. Max per server is 100M ","type":"text","required":false},"assignment_points_enabled":{"description":"Topic Assignment Points Enabled","type":"boolean","required":false},"assignment_points_amount":{"description":"Topic Assignment Points Amount","type":"integer","required":false},"assignment_auto_approve":{"description":"Topic Assignment Auto-approve Enabled","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Topic Assignment Upload Count Limit.","type":"integer","required":false},"assignment_deletion_enabled":{"description":"Topic Assignment Allow File Deletion.","type":"boolean","required":false},"forced_timer_enabled":{"description":"Topic Time Enabled","type":"boolean","required":false},"forced_timer_amount":{"description":"Topic Timer Amount.","type":"integer","required":false},"course":{"description":"Associated Course","type":"integer","required":false},"lesson":{"description":"Associated Lesson","type":"integer","required":false},"visible_type":{"description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false},"is_external":{"description":"External Topic","type":"boolean","required":false},"external_type":{"description":"Type","type":"string","enum":["virtual","in-person"],"required":false},"external_require_attendance":{"description":"Require Attendance","type":"string","enum":["","yes"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v2\/sfwd-quiz":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Lesson. Pass zero to show global Course Quizzes. Must be used with Course parameter.","type":"integer","required":false},"topic":{"description":"Limit results to be within a specific Topic. Must be used with Course parameter.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"course":{"default":0,"description":"Associated Course","type":"integer","required":false},"lesson":{"default":0,"description":"Associated Lesson","type":"integer","required":false},"visible_type":{"default":"","description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"default":0,"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"default":"","description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false},"is_external":{"default":false,"description":"External Quiz","type":"boolean","required":false},"external_type":{"default":"virtual","description":"Type","type":"string","enum":["virtual","in-person"],"required":false},"external_require_attendance":{"default":"","description":"Require Attendance","type":"string","enum":["","yes"],"required":false},"prerequisites":{"default":[],"description":"Quiz Prerequisites","type":"array","items":{"type":"integer"},"required":false},"registered_users_only":{"default":false,"description":"Allowed Users","type":"boolean","required":false},"passing_percentage":{"default":0,"description":"Passing Score Percentage","type":"float","required":false},"certificate":{"default":0,"description":"Quiz Certificate","type":"integer","required":false},"certificate_award_threshold":{"default":0,"description":"Certificate Awarded for","type":"float","required":false},"quiz_resume":{"default":false,"description":"Enable Quiz Saving","type":"boolean","required":false},"quiz_resume_cookie_send_timer":{"default":20,"description":"Save cookie data to the server every","type":"integer","required":false},"retry_restrictions_enabled":{"default":false,"description":"Restrict Quiz Retakes","type":"boolean","required":false},"retry_repeats":{"default":"","description":"Number of repeats allowed. blank is unlimited, 0 is 1 repeats, 1 is 2 repeats, etc.","type":"string","required":false},"answer_all_questions_enabled":{"default":true,"description":"All Questions required to complete","type":"boolean","required":false},"time_limit_enabled":{"default":false,"description":"Time Limit Enabled","type":"boolean","required":false},"time_limit_time":{"default":0,"description":"Automatically Submit After","type":"integer","required":false},"materials_enabled":{"default":false,"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Materials","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"auto_start":{"default":false,"description":"Autostart","type":"boolean","required":false},"quiz_modus":{"default":"single","description":"Question Display","type":"string","enum":["single","multiple"],"required":false},"review_table_enabled":{"default":false,"description":"Question Overview Table","type":"boolean","required":false},"summary_hide":{"default":false,"description":"Quiz Summary","type":"boolean","required":false},"skip_question_disabled":{"default":false,"description":"Skip Question","type":"boolean","required":false},"custom_sorting":{"default":false,"description":"Custom Question Ordering","type":"boolean","required":false},"sort_categories":{"default":false,"description":"Sort by Category","type":"boolean","required":false},"question_random":{"default":false,"description":"Randomize Order","type":"boolean","required":false},"show_max_question":{"default":false,"description":"","type":"boolean","required":false},"show_points":{"default":false,"description":"Point Value","type":"boolean","required":false},"show_category":{"default":false,"description":"Question Category","type":"boolean","required":false},"hide_question_position_overview":{"default":false,"description":"Question Position","type":"boolean","required":false},"hide_question_numbering":{"default":false,"description":"Question Numbering","type":"boolean","required":false},"numbered_answer":{"default":false,"description":"Number Answers","type":"boolean","required":false},"answer_random":{"default":false,"description":"Randomize Answers","type":"boolean","required":false},"title_hidden":{"default":false,"description":"Quiz Title","type":"boolean","required":false},"restart_button_hide":{"default":true,"description":"Restart Quiz button","type":"boolean","required":false},"show_average_result":{"default":true,"description":"Average Score","type":"boolean","required":false},"show_category_score":{"default":true,"description":"Category Score","type":"boolean","required":false},"hide_result_points":{"default":true,"description":"Overall Score","type":"boolean","required":false},"hide_result_correct_question":{"default":true,"description":"No. of Correct Answers","type":"boolean","required":false},"hide_result_quiz_time":{"default":true,"description":"Time Spent","type":"boolean","required":false},"custom_answer_feedback":{"default":true,"description":"Custom Answer Feedback","type":"boolean","required":false},"hide_answer_message_box":{"default":true,"description":"Correct \/ Incorrect Messages","type":"boolean","required":false},"disabled_answer_mark":{"default":true,"description":"Correct \/ Incorrect Answer Marks","type":"boolean","required":false},"view_question_button_hidden":{"default":true,"description":"View Questions Button","type":"boolean","required":false},"toplist_enabled":{"default":false,"description":"Leaderboard","type":"boolean","required":false},"toplist_data_add_permissions":{"default":"1","description":"Who can apply?","type":"string","enum":["1","2","3"],"required":false},"toplist_data_add_multiple":{"default":false,"description":"Multiple Applications per user","type":"boolean","required":false},"toplist_data_add_automatic":{"default":false,"description":"Automatic user entry","type":"boolean","required":false},"toplist_data_show_limit":{"default":10,"description":"Number of displayed entries","type":"integer","required":false},"toplist_data_sort":{"default":"1","description":"Sort list by?","type":"string","enum":["1","2","3"],"required":false},"toplist_data_showin_enabled":{"default":false,"description":"Display on Quiz results page","type":"boolean","required":false},"statistics_enabled":{"default":true,"description":"Quiz Statistics","type":"boolean","required":false},"view_profile_statistics_enabled":{"default":true,"description":"Front-end Profile Display","type":"boolean","required":false},"statistics_ip_lock_enabled":{"default":false,"description":"Statistics IP-lock","type":"boolean","required":false},"email_enabled":{"default":false,"description":"Email Notifications","type":"boolean","required":false},"email_admin_enabled":{"default":false,"description":"Admin","type":"boolean","required":false},"email_user_enabled":{"default":false,"description":"User","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/sfwd-quiz"}]}},"\/ldlms\/v2\/sfwd-quiz\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Lesson. Pass zero to show global Course Quizzes. Must be used with Course parameter.","type":"integer","required":false},"topic":{"description":"Limit results to be within a specific Topic. Must be used with Course parameter.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"course":{"description":"Associated Course","type":"integer","required":false},"lesson":{"description":"Associated Lesson","type":"integer","required":false},"visible_type":{"description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false},"is_external":{"description":"External Quiz","type":"boolean","required":false},"external_type":{"description":"Type","type":"string","enum":["virtual","in-person"],"required":false},"external_require_attendance":{"description":"Require Attendance","type":"string","enum":["","yes"],"required":false},"prerequisites":{"description":"Quiz Prerequisites","type":"array","items":{"type":"integer"},"required":false},"registered_users_only":{"description":"Allowed Users","type":"boolean","required":false},"passing_percentage":{"description":"Passing Score Percentage","type":"float","required":false},"certificate":{"description":"Quiz Certificate","type":"integer","required":false},"certificate_award_threshold":{"description":"Certificate Awarded for","type":"float","required":false},"quiz_resume":{"description":"Enable Quiz Saving","type":"boolean","required":false},"quiz_resume_cookie_send_timer":{"description":"Save cookie data to the server every","type":"integer","required":false},"retry_restrictions_enabled":{"description":"Restrict Quiz Retakes","type":"boolean","required":false},"retry_repeats":{"description":"Number of repeats allowed. blank is unlimited, 0 is 1 repeats, 1 is 2 repeats, etc.","type":"string","required":false},"answer_all_questions_enabled":{"description":"All Questions required to complete","type":"boolean","required":false},"time_limit_enabled":{"description":"Time Limit Enabled","type":"boolean","required":false},"time_limit_time":{"description":"Automatically Submit After","type":"integer","required":false},"materials_enabled":{"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Materials","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"auto_start":{"description":"Autostart","type":"boolean","required":false},"quiz_modus":{"description":"Question Display","type":"string","enum":["single","multiple"],"required":false},"review_table_enabled":{"description":"Question Overview Table","type":"boolean","required":false},"summary_hide":{"description":"Quiz Summary","type":"boolean","required":false},"skip_question_disabled":{"description":"Skip Question","type":"boolean","required":false},"custom_sorting":{"description":"Custom Question Ordering","type":"boolean","required":false},"sort_categories":{"description":"Sort by Category","type":"boolean","required":false},"question_random":{"description":"Randomize Order","type":"boolean","required":false},"show_max_question":{"description":"","type":"boolean","required":false},"show_points":{"description":"Point Value","type":"boolean","required":false},"show_category":{"description":"Question Category","type":"boolean","required":false},"hide_question_position_overview":{"description":"Question Position","type":"boolean","required":false},"hide_question_numbering":{"description":"Question Numbering","type":"boolean","required":false},"numbered_answer":{"description":"Number Answers","type":"boolean","required":false},"answer_random":{"description":"Randomize Answers","type":"boolean","required":false},"title_hidden":{"description":"Quiz Title","type":"boolean","required":false},"restart_button_hide":{"description":"Restart Quiz button","type":"boolean","required":false},"show_average_result":{"description":"Average Score","type":"boolean","required":false},"show_category_score":{"description":"Category Score","type":"boolean","required":false},"hide_result_points":{"description":"Overall Score","type":"boolean","required":false},"hide_result_correct_question":{"description":"No. of Correct Answers","type":"boolean","required":false},"hide_result_quiz_time":{"description":"Time Spent","type":"boolean","required":false},"custom_answer_feedback":{"description":"Custom Answer Feedback","type":"boolean","required":false},"hide_answer_message_box":{"description":"Correct \/ Incorrect Messages","type":"boolean","required":false},"disabled_answer_mark":{"description":"Correct \/ Incorrect Answer Marks","type":"boolean","required":false},"view_question_button_hidden":{"description":"View Questions Button","type":"boolean","required":false},"toplist_enabled":{"description":"Leaderboard","type":"boolean","required":false},"toplist_data_add_permissions":{"description":"Who can apply?","type":"string","enum":["1","2","3"],"required":false},"toplist_data_add_multiple":{"description":"Multiple Applications per user","type":"boolean","required":false},"toplist_data_add_automatic":{"description":"Automatic user entry","type":"boolean","required":false},"toplist_data_show_limit":{"description":"Number of displayed entries","type":"integer","required":false},"toplist_data_sort":{"description":"Sort list by?","type":"string","enum":["1","2","3"],"required":false},"toplist_data_showin_enabled":{"description":"Display on Quiz results page","type":"boolean","required":false},"statistics_enabled":{"description":"Quiz Statistics","type":"boolean","required":false},"view_profile_statistics_enabled":{"description":"Front-end Profile Display","type":"boolean","required":false},"statistics_ip_lock_enabled":{"description":"Statistics IP-lock","type":"boolean","required":false},"email_enabled":{"description":"Email Notifications","type":"boolean","required":false},"email_admin_enabled":{"description":"Admin","type":"boolean","required":false},"email_user_enabled":{"description":"User","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v2\/sfwd-essays":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"any","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["graded","not_graded"],"type":"string"},"required":false},"course":{"description":"Filter by Course ID","type":"integer","required":false},"lesson":{"description":"Filter by Lesson ID","type":"integer","default":0,"required":false},"topic":{"description":"Filter by Topic ID","type":"integer","default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/sfwd-essays"}]}},"\/ldlms\/v2\/sfwd-essays\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"any","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["graded","not_graded"],"type":"string"},"required":false},"course":{"description":"Filter by Course ID","type":"integer","required":false},"lesson":{"description":"Filter by Lesson ID","type":"integer","default":0,"required":false},"topic":{"description":"Filter by Topic ID","type":"integer","default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"course":{"description":"Course ID","type":"integer","required":false},"lesson":{"description":"Lesson ID","type":"integer","required":false},"topic":{"description":"Topic ID","type":"integer","required":false},"points_max":{"description":"Essay Points Maximum","type":"float","required":false},"points_awarded":{"description":"Essay Points Awarded","type":"float","required":false}}}]},"\/ldlms\/v2\/sfwd-question":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"quiz":{"default":"","description":"Quiz ID.","type":"integer","required":false},"question_type":{"default":"single","description":"Question type.","type":"enum","enum":["single","multiple","free_answer","sort_answer","matrix_sort_answer","cloze_answer","assessment_answer","essay"],"required":false},"points_total":{"default":"","description":"Total Points amount","type":"integer","required":false},"points_per_answer":{"default":"","description":"Different points for each answer","type":"boolean","required":false},"points_show_in_message":{"default":"","description":"Show reached points in the correct\/incorrect message?","type":"boolean","required":false},"points_diff_modus":{"default":"","description":"Different points - modus 2 activate","type":"boolean","required":false},"disable_correct":{"default":"","description":"Disable answer correct setting.","type":"boolean","required":false},"correct_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"incorrect_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"correct_same":{"default":"","description":"Activate hint for this Question.","type":"boolean","required":false},"hints_enabled":{"default":"","description":"Activate hint for this Question.","type":"boolean","required":false},"hints_message":{"description":"Hint message.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"answers":{"description":"Question answer sets.","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/sfwd-question"}]}},"\/ldlms\/v2\/sfwd-question\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"quiz":{"description":"Quiz ID.","type":"integer","required":false},"question_type":{"description":"Question type.","type":"enum","enum":["single","multiple","free_answer","sort_answer","matrix_sort_answer","cloze_answer","assessment_answer","essay"],"required":false},"points_total":{"description":"Total Points amount","type":"integer","required":false},"points_per_answer":{"description":"Different points for each answer","type":"boolean","required":false},"points_show_in_message":{"description":"Show reached points in the correct\/incorrect message?","type":"boolean","required":false},"points_diff_modus":{"description":"Different points - modus 2 activate","type":"boolean","required":false},"disable_correct":{"description":"Disable answer correct setting.","type":"boolean","required":false},"correct_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"incorrect_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"correct_same":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_enabled":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_message":{"description":"Hint message.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"answers":{"description":"Question answer sets.","type":"object","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v2\/sfwd-assignment":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"any","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["graded","not_graded"],"type":"string"},"required":false},"course":{"description":"Filter by Course ID","type":"integer","required":false},"lesson":{"description":"Filter by Lesson ID","type":"integer","default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/sfwd-assignment"}]}},"\/ldlms\/v2\/sfwd-assignment\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"any","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["graded","not_graded"],"type":"string"},"required":false},"course":{"description":"Filter by Course ID","type":"integer","required":false},"lesson":{"description":"Filter by Lesson ID","type":"integer","default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"course":{"description":"Course ID","type":"integer","required":false},"lesson":{"description":"Lesson ID","type":"integer","required":false},"topic":{"description":"Topic ID","type":"integer","required":false},"approved_status":{"description":"Assignment Approved Status","type":"string","enum":["","approved","not_approved"],"required":false},"points_enabled":{"description":"Assignment Points Enabled","type":"boolean","required":false},"points_max":{"description":"Assignment Points Maximum","type":"integer","required":false},"points_awarded":{"description":"Assignment Points Awarded","type":"integer","required":false}}}]},"\/ldlms\/v2\/groups":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"materials_enabled":{"default":false,"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Materials","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"certificate":{"default":0,"description":"Group Certificate","type":"integer","required":false},"disable_content_table":{"default":false,"description":"Group Content","type":"boolean","required":false},"courses_per_page_custom":{"default":0,"description":"Courses per page","type":"integer","required":false},"courses_orderby":{"default":"","description":"Sort By","type":"string","required":false},"courses_order":{"default":"","description":"Order Direction","type":"string","required":false},"price_type":{"default":"closed","description":"Group Price Type","type":"string","enum":["closed","free","paynow","subscribe"],"required":false},"price_type_paynow_price":{"default":"","description":"Pay Now Group Price","type":"string","required":false},"group_price_type_paynow_enrollment_url":{"default":"","description":"Pay Now group Enrollment URL","type":"string","required":false},"price_type_subscribe_price":{"default":"","description":"Subscribe Group Price","type":"string","required":false},"trial_price":{"default":"","description":"Group Trial Price","type":"string","required":false},"group_price_type_subscribe_enrollment_url":{"default":"","description":"Pay Now group Enrollment URL","type":"string","required":false},"price_type_closed_price":{"default":"","description":"Closed Group Price","type":"string","required":false},"price_type_closed_custom_button_url":{"default":"","description":"Closed Group Button URL","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/groups"}]}},"\/ldlms\/v2\/groups\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"materials_enabled":{"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Materials","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"certificate":{"description":"Group Certificate","type":"integer","required":false},"disable_content_table":{"description":"Group Content","type":"boolean","required":false},"courses_per_page_custom":{"description":"Courses per page","type":"integer","required":false},"courses_orderby":{"description":"Sort By","type":"string","required":false},"courses_order":{"description":"Order Direction","type":"string","required":false},"price_type":{"description":"Group Price Type","type":"string","enum":["closed","free","paynow","subscribe"],"required":false},"price_type_paynow_price":{"description":"Pay Now Group Price","type":"string","required":false},"group_price_type_paynow_enrollment_url":{"description":"Pay Now group Enrollment URL","type":"string","required":false},"price_type_subscribe_price":{"description":"Subscribe Group Price","type":"string","required":false},"trial_price":{"description":"Group Trial Price","type":"string","required":false},"group_price_type_subscribe_enrollment_url":{"description":"Pay Now group Enrollment URL","type":"string","required":false},"price_type_closed_price":{"description":"Closed Group Price","type":"string","required":false},"price_type_closed_custom_button_url":{"description":"Closed Group Button URL","type":"string","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/ldlms\/v2\/groups\/(?P<id>[\\d]+)\/courses":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Group ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Group ID","type":"integer","required":true},"course_ids":{"description":"Course IDs to add to Group.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Group ID","type":"integer","required":true},"course_ids":{"description":"Course IDs to remove from Group.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/groups\/(?P<id>[\\d]+)\/leaders":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Group ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sort collection by user attribute.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limit result set to users with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limit result set to users matching at least one specific role provided. Accepts csv list or single role.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limit result set to users matching at least one specific capability provided. Accepts csv list or single capability.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limit result set to users who are considered authors.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limit result set to users who have published posts.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","igmap":"igmap","um_form":"um_form","um_directory":"um_directory","application-stories":"application-stories","documents":"documents","headlines":"headlines","pi-newsletters":"pi-newsletters","profibus_tech":"profibus_tech","profinet_tech":"profinet_tech","webinar":"webinar","white-papers":"white-papers","sfwd-courses":"sfwd-courses","sfwd-lessons":"sfwd-lessons","sfwd-topic":"sfwd-topic","sfwd-quiz":"sfwd-quiz","sfwd-question":"sfwd-question","ld-exam":"ld-exam","sfwd-certificates":"sfwd-certificates","groups":"groups","fl-builder-template":"fl-builder-template"}},"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Group ID","type":"integer","required":true},"user_ids":{"description":"Group Leader User IDs to enroll into Group","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Group ID","type":"integer","required":true},"user_ids":{"description":"Group Leader User IDs to remove from Group","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/groups\/(?P<id>[\\d]+)\/users":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Group ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sort collection by user attribute.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limit result set to users with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limit result set to users matching at least one specific role provided. Accepts csv list or single role.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limit result set to users matching at least one specific capability provided. Accepts csv list or single capability.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limit result set to users who are considered authors.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limit result set to users who have published posts.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","igmap":"igmap","um_form":"um_form","um_directory":"um_directory","application-stories":"application-stories","documents":"documents","headlines":"headlines","pi-newsletters":"pi-newsletters","profibus_tech":"profibus_tech","profinet_tech":"profinet_tech","webinar":"webinar","white-papers":"white-papers","sfwd-courses":"sfwd-courses","sfwd-lessons":"sfwd-lessons","sfwd-topic":"sfwd-topic","sfwd-quiz":"sfwd-quiz","sfwd-question":"sfwd-question","ld-exam":"ld-exam","sfwd-certificates":"sfwd-certificates","groups":"groups","fl-builder-template":"fl-builder-template"}},"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Group ID","type":"integer","required":true},"user_ids":{"description":"User IDs to enroll into Group.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Group ID","type":"integer","required":true},"user_ids":{"description":"User IDs to remove from Group.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/courses":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"User ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"User ID","type":"integer","required":true},"course_ids":{"description":"Course IDs to add to User.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"User ID","type":"integer","required":true},"course_ids":{"description":"Course IDs to remove from User.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/groups":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"User ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"User ID","type":"integer","required":true},"group_ids":{"description":"Group IDs to add to User.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"User ID","type":"integer","required":true},"group_ids":{"description":"Group IDs to remove from User.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/course-progress":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"User ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/course-progress\/(?P<course>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"User ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/course-progress\/(?P<course>[\\d]+)\/steps":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"User ID","type":"integer","required":true},"course":{"description":"Unique Course identifier for the object.","type":"integer","required":true}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/quiz-progress":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"User ID","type":"integer","required":true},"quiz":{"description":"Limit results to be within a specific Quiz. Required for non-admin users.","type":"integer","required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Lesson. Pass zero to show global Course Quizzes. Must be used with Course parameter.","type":"integer","required":false},"topic":{"description":"Limit results to be within a specific Topic. Must be used with Course parameter.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"orderby":{"default":"taken","enum":["taken","title","id","date"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false}}}]},"\/ldlms\/v2\/sfwd-quiz\/(?P<quiz>[\\d]+)\/statistics":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"quiz":{"description":"Filter by Quiz ID","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","quiz","user"],"required":false},"user":{"description":"Filter by User ID","type":"integer","required":false},"after":{"description":"Limit response items after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to items before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false}}}]},"\/ldlms\/v2\/sfwd-quiz\/(?P<quiz>[\\d]+)\/statistics\/(?P<statistic>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"quiz":{"description":"Unique Quiz identifier for the object.","type":"integer","required":true}}}]},"\/ldlms\/v2\/sfwd-quiz\/(?P<quiz>[\\d]+)\/statistics\/(?P<statistic>[\\d]+)\/questions":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"quiz":{"description":"Unique Quiz identifier for the object.","type":"integer","required":true},"statistic":{"description":"Unique Quiz Statistic identifier for the object.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}]},"\/ldlms\/v2\/sfwd-quiz\/(?P<quiz>[\\d]+)\/statistics\/(?P<statistic>[\\d]+)\/questions\/(?P<id>[\\w-]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"quiz":{"description":"Unique Quiz identifier for the object.","type":"integer","required":true},"statistic":{"description":"Unique Quiz Statistic identifier for the object.","type":"integer","required":true},"id":{"description":"Unique Quiz Statistic Question identifier for the object.","type":"text","required":true}}}]},"\/ldlms\/v2\/sfwd-quiz\/(?P<quiz>[\\d]+)\/form-entries":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed"],"default":"view","required":false},"user":{"description":"User ID","type":"integer","default":0,"required":false},"quiz":{"description":"Quiz ID","type":"integer","default":0,"required":false},"order":{"description":"Order","type":"string","default":"DESC","enum":["ASC","DESC"],"required":false},"orderby":{"description":"Order by","type":"string","default":"date","enum":["date"],"required":false}}}]},"\/ldlms\/v2\/echo":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/echo"}]}},"\/ldlms\/v2\/price-types":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/price-types"}]}},"\/ldlms\/v2\/price-types\/(?P<slug>[\\w-]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"An alphanumeric identifier for the price type.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed"],"default":"view","required":false}}}]},"\/ldlms\/v2\/question-types":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/question-types"}]}},"\/ldlms\/v2\/question-types\/(?P<slug>[\\w-]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"An alphanumeric identifier for the  type","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed"],"default":"view","required":false}}}]},"\/ldlms\/v2\/progress-status":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/progress-status"}]}},"\/ldlms\/v2\/progress-status\/(?P<slug>[\\w-]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"An alphanumeric identifier for the progress status.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed"],"default":"view","required":false}}}]},"\/ldlms\/v2\/exams":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ldlms\/v2\/exams"}]}},"\/ldlms\/v2\/exams\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Whether to bypass trash and force deletion.","required":false}}}]},"\/pll\/v1":{"namespace":"pll\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"pll\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/pll\/v1"}]}},"\/pll\/v1\/languages":{"namespace":"pll\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"name":{"description":"The name is how it is displayed on your site (for example: English).","type":"string","minLength":1,"required":false},"slug":{"description":"Language code - preferably 2-letters ISO 639-1 (for example: en).","type":"string","pattern":"^[a-z][a-z0-9_-]*$","required":false},"locale":{"description":"WordPress Locale for the language (for example: en_US).","type":"string","pattern":"^[a-z]{2,3}(?:_[A-Z]{2})?(?:_[a-z0-9]+)?$","required":true},"is_rtl":{"description":"Text direction. `true` for right-to-left.","type":"boolean","required":false},"term_group":{"description":"Position of the language in the language switcher.","type":"integer","required":false},"flag_code":{"description":"Flag code corresponding to ISO 3166-1 (for example: us for the United States flag).","type":"string","required":false},"no_default_cat":{"default":false,"description":"Tells whether the default category must be created when creating a new language.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/pll\/v1\/languages"}]}},"\/pll\/v1\/languages\/(?P<term_id>[\\d]+)":{"namespace":"pll\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"term_id":{"description":"Unique identifier for the language.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"term_id":{"description":"Unique identifier for the language.","type":"integer","required":false},"name":{"description":"The name is how it is displayed on your site (for example: English).","type":"string","minLength":1,"required":false},"slug":{"description":"Language code - preferably 2-letters ISO 639-1 (for example: en).","type":"string","pattern":"^[a-z][a-z0-9_-]*$","required":false},"locale":{"description":"WordPress Locale for the language (for example: en_US).","type":"string","pattern":"^[a-z]{2,3}(?:_[A-Z]{2})?(?:_[a-z0-9]+)?$","required":false},"is_rtl":{"description":"Text direction. `true` for right-to-left.","type":"boolean","required":false},"term_group":{"description":"Position of the language in the language switcher.","type":"integer","required":false},"flag_code":{"description":"Flag code corresponding to ISO 3166-1 (for example: us for the United States flag).","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"term_id":{"description":"Unique identifier for the language.","type":"integer","required":false}}}]},"\/pll\/v1\/languages\/(?P<slug>[a-z][a-z0-9_-]*)":{"namespace":"pll\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Language code - preferably 2-letters ISO 639-1 (for example: en).","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/pll\/v1\/settings":{"namespace":"pll\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"browser":{"description":"Detect preferred browser language on front page: `true` to detect, `false` to not detect.","type":"boolean","required":false},"rewrite":{"description":"Remove `\/language\/` in pretty permalinks: `true` to remove, `false` to keep.","type":"boolean","required":false},"hide_default":{"description":"Remove the language code in URL for the default language: `true` to hide, `false` to display.","type":"boolean","required":false},"force_lang":{"description":"Determine how the current language is defined.","type":"integer","enum":[0,1,2,3],"required":false},"redirect_lang":{"description":"Remove the page name or page ID from the URL of the front page: `true` to remove, `false` to keep.","type":"boolean","required":false},"media_support":{"description":"Translate media: `true` to translate, `false` otherwise.","type":"boolean","required":false},"sync":{"description":"List of data to synchronize.","type":"array","items":{"type":"string","enum":["taxonomies","post_meta","comment_status","ping_status","sticky_posts","post_date","post_format","post_parent","_wp_page_template","menu_order","_thumbnail_id"]},"required":false},"post_types":{"description":"List of post types to translate.","type":"array","items":{"type":"string"},"required":false},"taxonomies":{"description":"List of taxonomies to translate.","type":"array","items":{"type":"string"},"required":false},"domains":{"description":"Domains used when the language is set from different domains.","type":"object","additionalProperties":false,"patternProperties":{"^[a-z][a-z0-9_-]*$":{"type":"string","format":"uri"}},"required":false},"default_lang":{"description":"Slug of the default language.","type":"string","pattern":"^[a-z][a-z0-9_-]*$","required":false},"nav_menus":{"description":"Translated navigation menus for each theme.","type":"object","additionalProperties":false,"patternProperties":{"[^\\\/:<>\\*\\?\"\\|]+":{"type":"object","patternProperties":{"[\\w-]+":{"type":"object","patternProperties":{"^[a-z][a-z0-9_-]*$":{"type":"integer","minimum":0}},"additionalProperties":false}},"additionalProperties":false}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/pll\/v1\/settings"}]}},"\/ee\/v4.8.29":{"namespace":"ee\/v4.8.29","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ee\/v4.8.29","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.29"}]}},"\/ee\/v4.8.33":{"namespace":"ee\/v4.8.33","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ee\/v4.8.33","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.33"}]}},"\/ee\/v4.8.34":{"namespace":"ee\/v4.8.34","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ee\/v4.8.34","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.34"}]}},"\/ee\/v4.8.36":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ee\/v4.8.36","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36"}]}},"\/ee\/v4.8.36\/config":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/config"}]}},"\/ee\/v4.8.36\/site_info":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/site_info"}]}},"\/ee\/v4.8.36\/resources":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/resources"}]}},"\/ee\/v4.8.36\/answers":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ANS_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"REG_ID":{"description":"Registration ID","type":"integer","default":0,"required":false},"QST_ID":{"description":"Question ID","type":"integer","default":0,"required":false},"ANS_value":{"description":"Answer Value","type":["object","string"],"default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/answers"}]}},"\/ee\/v4.8.36\/answers\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"REG_ID":{"description":"Registration ID","type":"integer","default":0,"required":false},"QST_ID":{"description":"Question ID","type":"integer","default":0,"required":false},"ANS_value":{"description":"Answer Value","type":["object","string"],"default":"","required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/answers\/(?P<id>[^\\\/]+)\/registration":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/answers\/(?P<id>[^\\\/]+)\/registration\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/answers\/(?P<id>[^\\\/]+)\/question":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QST_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/answers\/(?P<id>[^\\\/]+)\/question\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/answers\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/answers\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/answers\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/answers\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ATT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"ATT_full_name":{"description":"Attendee Full Name","type":"string","default":"Unknown","required":false},"ATT_bio":{"description":"Attendee Biography - the content as it exists in the database.","type":"string","default":"No Biography Provided","properties":{"raw":{"description":"Attendee Biography - the content as it exists in the database.","type":"string"},"rendered":{"description":"Attendee Biography - the content rendered for display.","type":"string"}},"required":false},"ATT_slug":{"description":"Attendee URL Slug","type":"string","default":null,"required":true},"ATT_created":{"description":"Time Attendee Created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"ATT_created_gmt":{"description":"Time Attendee Created - the value for this field in UTC. Ignored if ATT_created is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"ATT_short_bio":{"description":"Attendee Short Biography","type":["string","null"],"default":"No Biography Provided","required":false},"ATT_modified":{"description":"Time Attendee Last Modified - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"ATT_modified_gmt":{"description":"Time Attendee Last Modified - the value for this field in UTC. Ignored if ATT_modified is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"ATT_author":{"description":"Creator ID of the first Event attended","type":"integer","default":125,"required":false},"status":{"description":"Attendee Status - the value in the database.","type":"string","default":"publish","properties":{"raw":{"description":"Attendee Status - the value in the database.","type":"string","enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"]},"pretty":{"description":"Attendee Status - the value for display.","type":"string","enum":["Published","Scheduled","Draft","Pending","Private","Trash","auto-draft","inherit","Pending","Confirmed","Failed","Completed","Expired","Inactive","Graded","Not Graded","Cancelled","Postponed","Sold Out"],"read_only":true}},"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"],"required":false},"password":{"description":"Password","type":"string","default":"","required":false},"comment_status":{"description":"Comment Status","type":"string","default":"open","required":false},"ping_status":{"description":"Ping Status","type":"string","default":"open","required":false},"ATT_fname":{"description":"First Name","type":["string","null"],"default":"","required":false},"ATT_lname":{"description":"Last Name","type":["string","null"],"default":"","required":false},"ATT_address":{"description":"Address Part 1","type":["string","null"],"default":"","required":false},"ATT_address2":{"description":"Address Part 2","type":["string","null"],"default":"","required":false},"ATT_city":{"description":"City","type":["string","null"],"default":"","required":false},"STA_ID":{"description":"State","type":["integer","null"],"default":0,"required":false},"CNT_ISO":{"description":"Country","type":["string","null"],"default":"","required":false},"ATT_zip":{"description":"ZIP\/Postal Code","type":["string","null"],"default":"","required":false},"ATT_email":{"description":"Email Address","type":["string","null"],"default":"","format":"email","required":false},"ATT_phone":{"description":"Phone","type":["string","null"],"default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/attendees"}]}},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"ATT_full_name":{"description":"Attendee Full Name","type":"string","default":"Unknown","required":false},"ATT_bio":{"description":"Attendee Biography - the content as it exists in the database.","type":"string","default":"No Biography Provided","properties":{"raw":{"description":"Attendee Biography - the content as it exists in the database.","type":"string"},"rendered":{"description":"Attendee Biography - the content rendered for display.","type":"string"}},"required":false},"ATT_slug":{"description":"Attendee URL Slug","type":"string","default":null,"required":false},"ATT_created":{"description":"Time Attendee Created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"ATT_created_gmt":{"description":"Time Attendee Created - the value for this field in UTC. Ignored if ATT_created is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"ATT_short_bio":{"description":"Attendee Short Biography","type":["string","null"],"default":"No Biography Provided","required":false},"ATT_modified":{"description":"Time Attendee Last Modified - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"ATT_modified_gmt":{"description":"Time Attendee Last Modified - the value for this field in UTC. Ignored if ATT_modified is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"ATT_author":{"description":"Creator ID of the first Event attended","type":"integer","default":125,"required":false},"status":{"description":"Attendee Status - the value in the database.","type":"string","default":"publish","properties":{"raw":{"description":"Attendee Status - the value in the database.","type":"string","enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"]},"pretty":{"description":"Attendee Status - the value for display.","type":"string","enum":["Published","Scheduled","Draft","Pending","Private","Trash","auto-draft","inherit","Pending","Confirmed","Failed","Completed","Expired","Inactive","Graded","Not Graded","Cancelled","Postponed","Sold Out"],"read_only":true}},"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"],"required":false},"password":{"description":"Password","type":"string","default":"","required":false},"comment_status":{"description":"Comment Status","type":"string","default":"open","required":false},"ping_status":{"description":"Ping Status","type":"string","default":"open","required":false},"ATT_fname":{"description":"First Name","type":["string","null"],"default":"","required":false},"ATT_lname":{"description":"Last Name","type":["string","null"],"default":"","required":false},"ATT_address":{"description":"Address Part 1","type":["string","null"],"default":"","required":false},"ATT_address2":{"description":"Address Part 2","type":["string","null"],"default":"","required":false},"ATT_city":{"description":"City","type":["string","null"],"default":"","required":false},"STA_ID":{"description":"State","type":["integer","null"],"default":0,"required":false},"CNT_ISO":{"description":"Country","type":["string","null"],"default":"","required":false},"ATT_zip":{"description":"ZIP\/Postal Code","type":["string","null"],"default":"","required":false},"ATT_email":{"description":"Email Address","type":["string","null"],"default":"","format":"email","required":false},"ATT_phone":{"description":"Phone","type":["string","null"],"default":"","required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/registrations":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/registrations\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/state":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"STA_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/state\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/country":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CNT_ISO":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/country\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/events":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/events\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"TXN_ID":{"default":0,"type":"integer","required":true},"TKT_ID":{"default":0,"type":"integer","required":true},"STS_ID":{"default":"RIC","type":"string","required":true},"REG_date":{"default":"2023-03-17T19:55:29","type":"string","required":true},"REG_final_price":{"default":0,"type":"object","required":true},"REG_paid":{"default":0,"type":"object","required":true},"REG_session":{"default":"","type":"string","required":true},"REG_code":{"default":"","type":"string","required":true},"REG_url_link":{"default":"","type":"string","required":true},"REG_count":{"default":1,"type":["integer","null"],"required":false},"REG_group_size":{"default":1,"type":"integer","required":true},"REG_att_is_going":{"default":false,"type":"boolean","required":true},"REG_deleted":{"default":false,"type":"boolean","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/messages":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"MSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/messages\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/term_relationships":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"object_id":"ASC","term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/term_relationships\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/term_taxonomies":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/term_taxonomies\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/post_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"meta_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/post_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/attendees\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"LOG_time":{"description":"Log Time - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"LOG_time_gmt":{"description":"Log Time - the value for this field in UTC. Ignored if LOG_time is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"OBJ_ID":{"description":"Object ID (int or string)","type":["string","null"],"default":null,"required":false},"OBJ_type":{"description":"Object Type","type":["string","null"],"default":null,"required":false},"LOG_type":{"description":"Type of log entry","type":"string","default":"debug","required":false},"LOG_message":{"description":"Log Message (body)","type":["object","string","null"],"default":null,"required":false},"LOG_wp_user":{"description":"User who was logged in while this occurred","type":["integer","null"],"default":125,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/change_logs"}]}},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"LOG_time":{"description":"Log Time - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"LOG_time_gmt":{"description":"Log Time - the value for this field in UTC. Ignored if LOG_time is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"OBJ_ID":{"description":"Object ID (int or string)","type":["string","null"],"default":null,"required":false},"OBJ_type":{"description":"Object Type","type":["string","null"],"default":null,"required":false},"LOG_type":{"description":"Type of log entry","type":"string","default":"debug","required":false},"LOG_message":{"description":"Log Message (body)","type":["object","string","null"],"default":null,"required":false},"LOG_wp_user":{"description":"User who was logged in while this occurred","type":["integer","null"],"default":125,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/answer":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ANS_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/answer\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/attendee":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ATT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/attendee\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/checkin":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CHK_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/checkin\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/country":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CNT_ISO":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/country\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/currency":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CUR_code":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/currency\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/currency_payment_method":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CPM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/currency_payment_method\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/datetime":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["spaces_remaining_considering_tickets","registrations_checked_in_count","registrations_checked_out_count","spots_taken_pending_payment"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"DTT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/datetime\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/datetime_ticket":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"DTK_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/datetime_ticket\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/event":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/event\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/event_message_template":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EMT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/event_message_template\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/event_question_group":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EQG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/event_question_group\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/event_venue":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVV_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/event_venue\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/extra_join":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXJ_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/extra_join\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/line_item":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LIN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/line_item\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/message":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"MSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/message\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/message_template":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"MTP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/message_template\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/message_template_group":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"GRP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/message_template_group\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/payment":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PAY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/payment\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/payment_method":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PMD_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/payment_method\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/post_meta":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"meta_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/post_meta\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/price":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRC_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/price\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/price_type":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/price_type\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/question":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QST_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/question\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/question_group":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/question_group\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/question_group_question":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QGQ_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/question_group_question\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/question_option":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QSO_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/question_option\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/registration":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/registration\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/registration_payment":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"RPY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/registration_payment\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/state":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"STA_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/state\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/status":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"STS_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/status\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/term":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"term_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/term\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/term_relationship":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"object_id":"ASC","term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/term_relationship\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/term_taxonomy":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/term_taxonomy\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/ticket":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/ticket\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/ticket_price":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/ticket_price\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/ticket_template":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TTM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/ticket_template\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/transaction":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TXN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/transaction\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/venue":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"VNU_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/venue\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/change_logs\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/checkins":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CHK_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"REG_ID":{"description":"Registration Id","type":"integer","default":0,"required":false},"DTT_ID":{"description":"Datetime Id","type":"integer","default":0,"required":false},"CHK_in":{"description":"Whether a person has checked in or checked out","type":"boolean","default":true,"required":false},"CHK_timestamp":{"description":"When the row was modified - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"CHK_timestamp_gmt":{"description":"When the row was modified - the value for this field in UTC. Ignored if CHK_timestamp is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/checkins"}]}},"\/ee\/v4.8.36\/checkins\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"REG_ID":{"description":"Registration Id","type":"integer","default":0,"required":false},"DTT_ID":{"description":"Datetime Id","type":"integer","default":0,"required":false},"CHK_in":{"description":"Whether a person has checked in or checked out","type":"boolean","default":true,"required":false},"CHK_timestamp":{"description":"When the row was modified - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"CHK_timestamp_gmt":{"description":"When the row was modified - the value for this field in UTC. Ignored if CHK_timestamp is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/checkins\/(?P<id>[^\\\/]+)\/registration":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/checkins\/(?P<id>[^\\\/]+)\/registration\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/checkins\/(?P<id>[^\\\/]+)\/datetime":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["spaces_remaining_considering_tickets","registrations_checked_in_count","registrations_checked_out_count","spots_taken_pending_payment"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"DTT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/checkins\/(?P<id>[^\\\/]+)\/datetime\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/checkins\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/checkins\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/checkins\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/checkins\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/countries":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CNT_ISO":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"CNT_active":{"description":"Country Appears in Dropdown Select Lists","type":"boolean","default":true,"required":false},"CNT_ISO":{"description":"Country ISO Code","type":"string","default":null,"required":true},"CNT_ISO3":{"description":"Country ISO3 Code","type":"string","default":"","required":false},"RGN_ID":{"description":"Region ID","type":"integer","default":0,"required":false},"CNT_name":{"description":"Country Name","type":"string","default":"","required":false},"CNT_cur_code":{"description":"Country Currency Code","type":"string","default":null,"required":true},"CNT_cur_single":{"description":"Currency Name Singular","type":"string","default":null,"required":true},"CNT_cur_plural":{"description":"Currency Name Plural","type":"string","default":null,"required":true},"CNT_cur_sign":{"description":"Currency Sign","type":"string","default":null,"required":true},"CNT_cur_sign_b4":{"description":"Currency Sign Before Number","type":"boolean","default":true,"required":false},"CNT_cur_dec_plc":{"description":"Currency Decimal Places","type":"integer","default":2,"required":false},"CNT_cur_dec_mrk":{"description":"Currency Decimal Mark","type":"string","default":".","required":false},"CNT_cur_thsnds":{"description":"Currency Thousands Separator","type":"string","default":",","required":false},"CNT_tel_code":{"description":"Country Telephone Code","type":"string","default":"","required":false},"CNT_is_EU":{"description":"Country is Member of EU","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/countries"}]}},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"CNT_active":{"description":"Country Appears in Dropdown Select Lists","type":"boolean","default":true,"required":false},"CNT_ISO":{"description":"Country ISO Code","type":"string","default":null,"required":false},"CNT_ISO3":{"description":"Country ISO3 Code","type":"string","default":"","required":false},"RGN_ID":{"description":"Region ID","type":"integer","default":0,"required":false},"CNT_name":{"description":"Country Name","type":"string","default":"","required":false},"CNT_cur_code":{"description":"Country Currency Code","type":"string","default":null,"required":false},"CNT_cur_single":{"description":"Currency Name Singular","type":"string","default":null,"required":false},"CNT_cur_plural":{"description":"Currency Name Plural","type":"string","default":null,"required":false},"CNT_cur_sign":{"description":"Currency Sign","type":"string","default":null,"required":false},"CNT_cur_sign_b4":{"description":"Currency Sign Before Number","type":"boolean","default":true,"required":false},"CNT_cur_dec_plc":{"description":"Currency Decimal Places","type":"integer","default":2,"required":false},"CNT_cur_dec_mrk":{"description":"Currency Decimal Mark","type":"string","default":".","required":false},"CNT_cur_thsnds":{"description":"Currency Thousands Separator","type":"string","default":",","required":false},"CNT_tel_code":{"description":"Country Telephone Code","type":"string","default":"","required":false},"CNT_is_EU":{"description":"Country is Member of EU","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)\/attendees":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ATT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)\/attendees\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)\/states":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"STA_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)\/states\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)\/venues":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"VNU_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)\/venues\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/countries\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/currencies":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CUR_code":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"CUR_code":{"description":"Currency Code","type":"string","default":null,"required":true},"CUR_single":{"description":"Currency Name Singular","type":"string","default":null,"required":true},"CUR_plural":{"description":"Currency Name Plural","type":"string","default":null,"required":true},"CUR_sign":{"description":"Currency Sign","type":"string","default":null,"required":true},"CUR_dec_plc":{"description":"Currency Decimal Places","type":"integer","default":2,"required":false},"CUR_active":{"description":"Active?","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/currencies"}]}},"\/ee\/v4.8.36\/currencies\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"CUR_code":{"description":"Currency Code","type":"string","default":null,"required":false},"CUR_single":{"description":"Currency Name Singular","type":"string","default":null,"required":false},"CUR_plural":{"description":"Currency Name Plural","type":"string","default":null,"required":false},"CUR_sign":{"description":"Currency Sign","type":"string","default":null,"required":false},"CUR_dec_plc":{"description":"Currency Decimal Places","type":"integer","default":2,"required":false},"CUR_active":{"description":"Active?","type":"boolean","default":true,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/currencies\/(?P<id>[^\\\/]+)\/payment_methods":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PMD_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/currencies\/(?P<id>[^\\\/]+)\/payment_methods\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/currencies\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/currencies\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/currencies\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/currencies\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/currency_payment_methods":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CPM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"CUR_code":{"description":"Currency Code","type":"string","default":"","required":false},"PMD_ID":{"description":"Paymetn Method ID","type":"integer","default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/currency_payment_methods"}]}},"\/ee\/v4.8.36\/currency_payment_methods\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"CUR_code":{"description":"Currency Code","type":"string","default":"","required":false},"PMD_ID":{"description":"Paymetn Method ID","type":"integer","default":0,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/currency_payment_methods\/(?P<id>[^\\\/]+)\/currency":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CUR_code":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/currency_payment_methods\/(?P<id>[^\\\/]+)\/currency\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/currency_payment_methods\/(?P<id>[^\\\/]+)\/payment_method":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PMD_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/currency_payment_methods\/(?P<id>[^\\\/]+)\/payment_method\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/currency_payment_methods\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/currency_payment_methods\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/currency_payment_methods\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/currency_payment_methods\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/datetimes":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["spaces_remaining_considering_tickets","registrations_checked_in_count","registrations_checked_out_count","spots_taken_pending_payment"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"DTT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"EVT_ID":{"description":"Event ID","type":"integer","default":0,"required":false},"DTT_name":{"description":"Datetime Name","type":"string","default":"","required":false},"DTT_description":{"description":"Description for Datetime - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Description for Datetime - the content as it exists in the database.","type":"string"},"rendered":{"description":"Description for Datetime - the content rendered for display.","type":"string"}},"required":false},"DTT_EVT_start":{"description":"Start time\/date of Event - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"DTT_EVT_start_gmt":{"description":"Start time\/date of Event - the value for this field in UTC. Ignored if DTT_EVT_start is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"DTT_EVT_end":{"description":"End time\/date of Event - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"DTT_EVT_end_gmt":{"description":"End time\/date of Event - the value for this field in UTC. Ignored if DTT_EVT_end is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"DTT_reg_limit":{"description":"Registration Limit for this time","type":["integer","null"],"default":null,"required":false},"DTT_sold":{"description":"How many sales for this Datetime that have occurred","type":["integer","null"],"default":0,"required":false},"DTT_reserved":{"description":"Quantity of tickets reserved, but not yet fully purchased","type":"integer","default":0,"required":false},"DTT_is_primary":{"description":"Flag indicating datetime is primary one for event","type":"boolean","default":false,"required":false},"DTT_order":{"description":"The order in which the Datetime is displayed","type":"integer","default":0,"required":false},"DTT_parent":{"description":"Indicates what DTT_ID is the parent of this DTT_ID","type":["integer","null"],"default":0,"required":false},"DTT_deleted":{"description":"Flag indicating datetime is archived","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/datetimes"}]}},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["spaces_remaining_considering_tickets","registrations_checked_in_count","registrations_checked_out_count","spots_taken_pending_payment"],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"EVT_ID":{"description":"Event ID","type":"integer","default":0,"required":false},"DTT_name":{"description":"Datetime Name","type":"string","default":"","required":false},"DTT_description":{"description":"Description for Datetime - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Description for Datetime - the content as it exists in the database.","type":"string"},"rendered":{"description":"Description for Datetime - the content rendered for display.","type":"string"}},"required":false},"DTT_EVT_start":{"description":"Start time\/date of Event - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"DTT_EVT_start_gmt":{"description":"Start time\/date of Event - the value for this field in UTC. Ignored if DTT_EVT_start is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"DTT_EVT_end":{"description":"End time\/date of Event - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"DTT_EVT_end_gmt":{"description":"End time\/date of Event - the value for this field in UTC. Ignored if DTT_EVT_end is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"DTT_reg_limit":{"description":"Registration Limit for this time","type":["integer","null"],"default":null,"required":false},"DTT_sold":{"description":"How many sales for this Datetime that have occurred","type":["integer","null"],"default":0,"required":false},"DTT_reserved":{"description":"Quantity of tickets reserved, but not yet fully purchased","type":"integer","default":0,"required":false},"DTT_is_primary":{"description":"Flag indicating datetime is primary one for event","type":"boolean","default":false,"required":false},"DTT_order":{"description":"The order in which the Datetime is displayed","type":"integer","default":0,"required":false},"DTT_parent":{"description":"Indicates what DTT_ID is the parent of this DTT_ID","type":["integer","null"],"default":0,"required":false},"DTT_deleted":{"description":"Flag indicating datetime is archived","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/tickets":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/tickets\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/event":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/event\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/checkins":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CHK_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/checkins\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/datetime_tickets":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"DTK_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/datetime_tickets\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/datetimes\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/datetime_tickets":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"DTK_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"DTT_ID":{"description":"The ID to the Datetime","type":"integer","default":0,"required":false},"TKT_ID":{"description":"The ID to the Ticket","type":"integer","default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/datetime_tickets"}]}},"\/ee\/v4.8.36\/datetime_tickets\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"DTT_ID":{"description":"The ID to the Datetime","type":"integer","default":0,"required":false},"TKT_ID":{"description":"The ID to the Ticket","type":"integer","default":0,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/datetime_tickets\/(?P<id>[^\\\/]+)\/ticket":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/datetime_tickets\/(?P<id>[^\\\/]+)\/ticket\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/datetime_tickets\/(?P<id>[^\\\/]+)\/datetime":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["spaces_remaining_considering_tickets","registrations_checked_in_count","registrations_checked_out_count","spots_taken_pending_payment"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"DTT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/datetime_tickets\/(?P<id>[^\\\/]+)\/datetime\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/datetime_tickets\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/datetime_tickets\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/datetime_tickets\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/datetime_tickets\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"EVT_name":{"description":"Event Name","type":"string","default":"","required":false},"EVT_desc":{"description":"Event Description - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Event Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Event Description - the content rendered for display.","type":"string"}},"required":false},"EVT_slug":{"description":"Event Slug","type":"string","default":"","required":false},"EVT_created":{"description":"Date\/Time Event Created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_created_gmt":{"description":"Date\/Time Event Created - the value for this field in UTC. Ignored if EVT_created is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_short_desc":{"description":"Event Short Description","type":"string","default":"","required":false},"EVT_modified":{"description":"Date\/Time Event Modified - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_modified_gmt":{"description":"Date\/Time Event Modified - the value for this field in UTC. Ignored if EVT_modified is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_wp_user":{"description":"Event Creator ID","type":"integer","default":125,"required":false},"parent":{"description":"Event Parent ID","type":"integer","default":0,"required":false},"EVT_order":{"description":"Event Menu Order","type":"integer","default":1,"required":false},"status":{"description":"Event Status - the value in the database.","type":"string","default":"draft","properties":{"raw":{"description":"Event Status - the value in the database.","type":"string","enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"]},"pretty":{"description":"Event Status - the value for display.","type":"string","enum":["Published","Scheduled","Draft","Pending","Private","Trash","auto-draft","inherit","Pending","Confirmed","Failed","Completed","Expired","Inactive","Graded","Not Graded","Cancelled","Postponed","Sold Out"],"read_only":true}},"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"],"required":false},"password":{"description":"Password","type":"string","default":"","required":false},"comment_status":{"description":"Comment Status","type":"string","default":"open","required":false},"ping_status":{"description":"Ping Status","type":"string","default":"open","required":false},"EVT_display_desc":{"description":"Display Description Flag","type":"boolean","default":true,"required":false},"EVT_display_ticket_selector":{"description":"Display Ticket Selector Flag","type":"boolean","default":true,"required":false},"EVT_visible_on":{"description":"Event Visible Date - the value for this field is in the timezone of the site.","type":["string","null"],"default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_visible_on_gmt":{"description":"Event Visible Date - the value for this field in UTC. Ignored if EVT_visible_on is provided.","type":["string","null"],"default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_additional_limit":{"description":"Limit of Additional Registrations on Same Transaction","type":["integer","null"],"default":1,"required":false},"EVT_default_registration_status":{"description":"Default Registration Status on this Event - the value in the database.","type":"string","default":"RAP","properties":{"raw":{"description":"Default Registration Status on this Event - the value in the database.","type":"string","enum":["RAP","RCN","RDC","RIC","RNA","RPP","RWL"]},"pretty":{"description":"Default Registration Status on this Event - the value for display.","type":"string","enum":["APPROVED","CANCELLED","DECLINED","INCOMPLETE","NOT_APPROVED","PENDING_PAYMENT","WAIT_LIST"],"read_only":true}},"enum":["RAP","RCN","RDC","RIC","RNA","RPP","RWL"],"required":false},"EVT_member_only":{"description":"Member-Only Event Flag","type":"boolean","default":false,"required":false},"EVT_phone":{"description":"Event Phone Number","type":"string","default":"","required":false},"EVT_allow_overflow":{"description":"Allow Overflow on Event","type":"boolean","default":false,"required":false},"EVT_timezone_string":{"description":"Timezone (name) for Event times","type":"string","default":"","required":false},"EVT_external_URL":{"description":"URL of Event Page if hosted elsewhere","type":["string","null"],"default":null,"required":false},"EVT_donations":{"description":"Accept Donations?","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/events"}]}},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"EVT_name":{"description":"Event Name","type":"string","default":"","required":false},"EVT_desc":{"description":"Event Description - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Event Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Event Description - the content rendered for display.","type":"string"}},"required":false},"EVT_slug":{"description":"Event Slug","type":"string","default":"","required":false},"EVT_created":{"description":"Date\/Time Event Created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_created_gmt":{"description":"Date\/Time Event Created - the value for this field in UTC. Ignored if EVT_created is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_short_desc":{"description":"Event Short Description","type":"string","default":"","required":false},"EVT_modified":{"description":"Date\/Time Event Modified - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_modified_gmt":{"description":"Date\/Time Event Modified - the value for this field in UTC. Ignored if EVT_modified is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_wp_user":{"description":"Event Creator ID","type":"integer","default":125,"required":false},"parent":{"description":"Event Parent ID","type":"integer","default":0,"required":false},"EVT_order":{"description":"Event Menu Order","type":"integer","default":1,"required":false},"status":{"description":"Event Status - the value in the database.","type":"string","default":"draft","properties":{"raw":{"description":"Event Status - the value in the database.","type":"string","enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"]},"pretty":{"description":"Event Status - the value for display.","type":"string","enum":["Published","Scheduled","Draft","Pending","Private","Trash","auto-draft","inherit","Pending","Confirmed","Failed","Completed","Expired","Inactive","Graded","Not Graded","Cancelled","Postponed","Sold Out"],"read_only":true}},"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"],"required":false},"password":{"description":"Password","type":"string","default":"","required":false},"comment_status":{"description":"Comment Status","type":"string","default":"open","required":false},"ping_status":{"description":"Ping Status","type":"string","default":"open","required":false},"EVT_display_desc":{"description":"Display Description Flag","type":"boolean","default":true,"required":false},"EVT_display_ticket_selector":{"description":"Display Ticket Selector Flag","type":"boolean","default":true,"required":false},"EVT_visible_on":{"description":"Event Visible Date - the value for this field is in the timezone of the site.","type":["string","null"],"default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_visible_on_gmt":{"description":"Event Visible Date - the value for this field in UTC. Ignored if EVT_visible_on is provided.","type":["string","null"],"default":"2023-03-17T19:55:29","format":"date-time","required":false},"EVT_additional_limit":{"description":"Limit of Additional Registrations on Same Transaction","type":["integer","null"],"default":1,"required":false},"EVT_default_registration_status":{"description":"Default Registration Status on this Event - the value in the database.","type":"string","default":"RAP","properties":{"raw":{"description":"Default Registration Status on this Event - the value in the database.","type":"string","enum":["RAP","RCN","RDC","RIC","RNA","RPP","RWL"]},"pretty":{"description":"Default Registration Status on this Event - the value for display.","type":"string","enum":["APPROVED","CANCELLED","DECLINED","INCOMPLETE","NOT_APPROVED","PENDING_PAYMENT","WAIT_LIST"],"read_only":true}},"enum":["RAP","RCN","RDC","RIC","RNA","RPP","RWL"],"required":false},"EVT_member_only":{"description":"Member-Only Event Flag","type":"boolean","default":false,"required":false},"EVT_phone":{"description":"Event Phone Number","type":"string","default":"","required":false},"EVT_allow_overflow":{"description":"Allow Overflow on Event","type":"boolean","default":false,"required":false},"EVT_timezone_string":{"description":"Timezone (name) for Event times","type":"string","default":"","required":false},"EVT_external_URL":{"description":"URL of Event Page if hosted elsewhere","type":["string","null"],"default":null,"required":false},"EVT_donations":{"description":"Accept Donations?","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/registrations":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/registrations\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/datetimes":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["spaces_remaining_considering_tickets","registrations_checked_in_count","registrations_checked_out_count","spots_taken_pending_payment"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"DTT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/datetimes\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/question_groups":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/question_groups\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"EQG_primary":{"default":false,"type":"boolean","required":true},"EQG_additional":{"default":false,"type":"boolean","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/event_question_groups":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EQG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/event_question_groups\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/venues":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"VNU_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/venues\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"EVV_primary":{"default":true,"type":"boolean","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/term_relationships":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"object_id":"ASC","term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/term_relationships\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/term_taxonomies":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/term_taxonomies\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/message_template_groups":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"GRP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/message_template_groups\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/attendees":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ATT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/attendees\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"TXN_ID":{"default":0,"type":"integer","required":true},"TKT_ID":{"default":0,"type":"integer","required":true},"STS_ID":{"default":"RIC","type":"string","required":true},"REG_date":{"default":"2023-03-17T19:55:29","type":"string","required":true},"REG_final_price":{"default":0,"type":"object","required":true},"REG_paid":{"default":0,"type":"object","required":true},"REG_session":{"default":"","type":"string","required":true},"REG_code":{"default":"","type":"string","required":true},"REG_url_link":{"default":"","type":"string","required":true},"REG_count":{"default":1,"type":["integer","null"],"required":false},"REG_group_size":{"default":1,"type":"integer","required":true},"REG_att_is_going":{"default":false,"type":"boolean","required":true},"REG_deleted":{"default":false,"type":"boolean","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/post_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"meta_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/post_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/events\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_message_templates":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EMT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"EVT_ID":{"description":"The ID to the Event","type":"integer","default":0,"required":false},"GRP_ID":{"description":"The ID to the Message Template Group","type":"integer","default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/event_message_templates"}]}},"\/ee\/v4.8.36\/event_message_templates\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"EVT_ID":{"description":"The ID to the Event","type":"integer","default":0,"required":false},"GRP_ID":{"description":"The ID to the Message Template Group","type":"integer","default":0,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/event_message_templates\/(?P<id>[^\\\/]+)\/event":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_message_templates\/(?P<id>[^\\\/]+)\/event\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_message_templates\/(?P<id>[^\\\/]+)\/message_template_group":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"GRP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_message_templates\/(?P<id>[^\\\/]+)\/message_template_group\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_message_templates\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_message_templates\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_message_templates\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_message_templates\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_question_groups":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EQG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"EVT_ID":{"description":"Event ID","type":"integer","default":0,"required":false},"QSG_ID":{"description":"Question Group Id","type":"integer","default":0,"required":false},"EQG_primary":{"description":"Flag indicating question is only for primary attendees","type":"boolean","default":false,"required":false},"EQG_additional":{"description":"Flag indicating question is only for additional attendees","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/event_question_groups"}]}},"\/ee\/v4.8.36\/event_question_groups\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"EVT_ID":{"description":"Event ID","type":"integer","default":0,"required":false},"QSG_ID":{"description":"Question Group Id","type":"integer","default":0,"required":false},"EQG_primary":{"description":"Flag indicating question is only for primary attendees","type":"boolean","default":false,"required":false},"EQG_additional":{"description":"Flag indicating question is only for additional attendees","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/event_question_groups\/(?P<id>[^\\\/]+)\/event":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_question_groups\/(?P<id>[^\\\/]+)\/event\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_question_groups\/(?P<id>[^\\\/]+)\/question_group":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_question_groups\/(?P<id>[^\\\/]+)\/question_group\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_question_groups\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_question_groups\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_question_groups\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_question_groups\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_venues":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVV_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"EVT_ID":{"description":"Event ID","type":"integer","default":0,"required":false},"VNU_ID":{"description":"Venue ID","type":"integer","default":0,"required":false},"EVV_primary":{"description":"Flag indicating venue is primary one for event","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/event_venues"}]}},"\/ee\/v4.8.36\/event_venues\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"EVT_ID":{"description":"Event ID","type":"integer","default":0,"required":false},"VNU_ID":{"description":"Venue ID","type":"integer","default":0,"required":false},"EVV_primary":{"description":"Flag indicating venue is primary one for event","type":"boolean","default":true,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/event_venues\/(?P<id>[^\\\/]+)\/event":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_venues\/(?P<id>[^\\\/]+)\/event\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_venues\/(?P<id>[^\\\/]+)\/venue":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"VNU_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_venues\/(?P<id>[^\\\/]+)\/venue\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_venues\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_venues\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/event_venues\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/event_venues\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/line_items":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LIN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"LIN_code":{"description":"Code for index into Cart","type":["string","null"],"default":null,"required":false},"TXN_ID":{"description":"Transaction ID","type":["integer","null"],"default":null,"required":false},"LIN_name":{"description":"Line Item Name - the value in the database.","type":"string","default":"","properties":{"raw":{"description":"Line Item Name - the value in the database.","type":"string"},"rendered":{"description":"Line Item Name - transformed for display.","type":"string","readonly":true}},"required":false},"LIN_desc":{"description":"Line Item Description","type":["object","null"],"default":null,"properties":{"raw":{"description":"Line Item Description - the value in the database.","type":"string"},"rendered":{"description":"Line Item Description - transformed for display.","type":"string","readonly":true}},"required":false},"LIN_unit_price":{"description":"Unit Price - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Unit Price - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Unit Price - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"LIN_percent":{"description":"Percent","type":"number","default":0,"required":false},"LIN_is_taxable":{"description":"Taxable","type":"boolean","default":false,"required":false},"LIN_order":{"description":"Order of Application towards total of parent","type":"integer","default":1,"required":false},"LIN_total":{"description":"Total (unit price x quantity) - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Total (unit price x quantity) - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Total (unit price x quantity) - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"LIN_quantity":{"description":"Quantity","type":["integer","null"],"default":1,"required":false},"LIN_parent":{"description":"Parent ID (this item goes towards that Line Item&#039;s total)","type":["integer","null"],"default":null,"required":false},"LIN_type":{"description":"Type - the value in the database.","type":"string","default":"line-item","properties":{"raw":{"description":"Type - the value in the database.","type":"string","enum":["line-item","sub-item","sub-total","tax-sub-total","tax","total","cancellation"]},"pretty":{"description":"Type - the value for display.","type":"string","enum":["Line Item","Sub-Item","Subtotal","Tax Subtotal","Tax","Total","Cancellation"],"read_only":true}},"enum":["line-item","sub-item","sub-total","tax-sub-total","tax","total","cancellation"],"required":false},"OBJ_ID":{"description":"ID of Item purchased.","type":["integer","null"],"default":null,"required":false},"OBJ_type":{"description":"Model Name this Line Item is for","type":["string","null"],"default":null,"required":false},"LIN_timestamp":{"description":"When the line item was created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"LIN_timestamp_gmt":{"description":"When the line item was created - the value for this field in UTC. Ignored if LIN_timestamp is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/line_items"}]}},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"LIN_code":{"description":"Code for index into Cart","type":["string","null"],"default":null,"required":false},"TXN_ID":{"description":"Transaction ID","type":["integer","null"],"default":null,"required":false},"LIN_name":{"description":"Line Item Name - the value in the database.","type":"string","default":"","properties":{"raw":{"description":"Line Item Name - the value in the database.","type":"string"},"rendered":{"description":"Line Item Name - transformed for display.","type":"string","readonly":true}},"required":false},"LIN_desc":{"description":"Line Item Description","type":["object","null"],"default":null,"properties":{"raw":{"description":"Line Item Description - the value in the database.","type":"string"},"rendered":{"description":"Line Item Description - transformed for display.","type":"string","readonly":true}},"required":false},"LIN_unit_price":{"description":"Unit Price - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Unit Price - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Unit Price - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"LIN_percent":{"description":"Percent","type":"number","default":0,"required":false},"LIN_is_taxable":{"description":"Taxable","type":"boolean","default":false,"required":false},"LIN_order":{"description":"Order of Application towards total of parent","type":"integer","default":1,"required":false},"LIN_total":{"description":"Total (unit price x quantity) - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Total (unit price x quantity) - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Total (unit price x quantity) - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"LIN_quantity":{"description":"Quantity","type":["integer","null"],"default":1,"required":false},"LIN_parent":{"description":"Parent ID (this item goes towards that Line Item&#039;s total)","type":["integer","null"],"default":null,"required":false},"LIN_type":{"description":"Type - the value in the database.","type":"string","default":"line-item","properties":{"raw":{"description":"Type - the value in the database.","type":"string","enum":["line-item","sub-item","sub-total","tax-sub-total","tax","total","cancellation"]},"pretty":{"description":"Type - the value for display.","type":"string","enum":["Line Item","Sub-Item","Subtotal","Tax Subtotal","Tax","Total","Cancellation"],"read_only":true}},"enum":["line-item","sub-item","sub-total","tax-sub-total","tax","total","cancellation"],"required":false},"OBJ_ID":{"description":"ID of Item purchased.","type":["integer","null"],"default":null,"required":false},"OBJ_type":{"description":"Model Name this Line Item is for","type":["string","null"],"default":null,"required":false},"LIN_timestamp":{"description":"When the line item was created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"LIN_timestamp_gmt":{"description":"When the line item was created - the value for this field in UTC. Ignored if LIN_timestamp is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/transaction":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TXN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/transaction\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/ticket":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/ticket\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/price":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRC_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/price\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/event":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/event\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/line_items\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/messages":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"MSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"MSG_token":{"description":"Unique Token used to represent this row in publicly viewable contexts (eg. a url).","type":"string","default":"e60654e94e20b6ffd7547cfd02e95e51","required":false},"GRP_ID":{"description":"Foreign key to the EEM_Message_Template_Group table.","type":["integer","null"],"default":0,"required":false},"TXN_ID":{"description":"Foreign key to the related EE_Transaction.  This is required to give context for regenerating the specific message","type":["integer","null"],"default":0,"required":false},"MSG_messenger":{"description":"Corresponds to the EE_messenger::name used to send this message. This will also be used to attempt any resending of the message.","type":"string","default":"email","required":false},"MSG_message_type":{"description":"Corresponds to the EE_message_type::name used to generate this message.","type":"string","default":"receipt","required":false},"MSG_context":{"description":"Context","type":"string","default":null,"required":true},"MSG_recipient_ID":{"description":"Recipient ID","type":["integer","null"],"default":null,"required":false},"MSG_recipient_type":{"description":"Recipient Type","type":["string","null"],"default":null,"required":false},"MSG_content":{"description":"Content","type":["object","string","null"],"default":"","required":false},"MSG_to":{"description":"Address To","type":["object","string","null"],"default":null,"required":false},"MSG_from":{"description":"Address From","type":["object","string","null"],"default":null,"required":false},"MSG_subject":{"description":"Subject","type":["object","string","null"],"default":"","required":false},"MSG_priority":{"description":"Priority - the value in the database.","type":"integer","default":30,"properties":{"raw":{"description":"Priority - the value in the database.","enum":[10,20,30],"type":"integer"},"pretty":{"description":"Priority - the value for display.","enum":["high","medium","low"],"type":"string","read_only":true}},"enum":[10,20,30],"required":false},"STS_ID":{"description":"Status","type":"string","default":"MIC","required":false},"MSG_created":{"description":"Created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"MSG_created_gmt":{"description":"Created - the value for this field in UTC. Ignored if MSG_created is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"MSG_modified":{"description":"Modified - the value for this field is in the timezone of the site.","type":["string","null"],"default":"2023-03-17T19:55:29","format":"date-time","required":false},"MSG_modified_gmt":{"description":"Modified - the value for this field in UTC. Ignored if MSG_modified is provided.","type":["string","null"],"default":"2023-03-17T19:55:29","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/messages"}]}},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"MSG_token":{"description":"Unique Token used to represent this row in publicly viewable contexts (eg. a url).","type":"string","default":"e60654e94e20b6ffd7547cfd02e95e51","required":false},"GRP_ID":{"description":"Foreign key to the EEM_Message_Template_Group table.","type":["integer","null"],"default":0,"required":false},"TXN_ID":{"description":"Foreign key to the related EE_Transaction.  This is required to give context for regenerating the specific message","type":["integer","null"],"default":0,"required":false},"MSG_messenger":{"description":"Corresponds to the EE_messenger::name used to send this message. This will also be used to attempt any resending of the message.","type":"string","default":"email","required":false},"MSG_message_type":{"description":"Corresponds to the EE_message_type::name used to generate this message.","type":"string","default":"receipt","required":false},"MSG_context":{"description":"Context","type":"string","default":null,"required":false},"MSG_recipient_ID":{"description":"Recipient ID","type":["integer","null"],"default":null,"required":false},"MSG_recipient_type":{"description":"Recipient Type","type":["string","null"],"default":null,"required":false},"MSG_content":{"description":"Content","type":["object","string","null"],"default":"","required":false},"MSG_to":{"description":"Address To","type":["object","string","null"],"default":null,"required":false},"MSG_from":{"description":"Address From","type":["object","string","null"],"default":null,"required":false},"MSG_subject":{"description":"Subject","type":["object","string","null"],"default":"","required":false},"MSG_priority":{"description":"Priority - the value in the database.","type":"integer","default":30,"properties":{"raw":{"description":"Priority - the value in the database.","enum":[10,20,30],"type":"integer"},"pretty":{"description":"Priority - the value for display.","enum":["high","medium","low"],"type":"string","read_only":true}},"enum":[10,20,30],"required":false},"STS_ID":{"description":"Status","type":"string","default":"MIC","required":false},"MSG_created":{"description":"Created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"MSG_created_gmt":{"description":"Created - the value for this field in UTC. Ignored if MSG_created is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"MSG_modified":{"description":"Modified - the value for this field is in the timezone of the site.","type":["string","null"],"default":"2023-03-17T19:55:29","format":"date-time","required":false},"MSG_modified_gmt":{"description":"Modified - the value for this field in UTC. Ignored if MSG_modified is provided.","type":["string","null"],"default":"2023-03-17T19:55:29","format":"date-time","required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/attendee":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ATT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/attendee\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/registration":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/registration\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/message_template_group":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"GRP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/message_template_group\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/transaction":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TXN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/transaction\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/messages\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/message_templates":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"MTP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"GRP_ID":{"description":"Message Template Group ID","type":"integer","default":0,"required":false},"MTP_template_field":{"description":"Field Name for this Template","type":"string","default":"default","required":false},"MTP_context":{"description":"Message Type Context for this field","type":"string","default":"admin","required":false},"MTP_content":{"description":"The field content for the template","type":["object","string"],"default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/message_templates"}]}},"\/ee\/v4.8.36\/message_templates\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"GRP_ID":{"description":"Message Template Group ID","type":"integer","default":0,"required":false},"MTP_template_field":{"description":"Field Name for this Template","type":"string","default":"default","required":false},"MTP_context":{"description":"Message Type Context for this field","type":"string","default":"admin","required":false},"MTP_content":{"description":"The field content for the template","type":["object","string"],"default":"","required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/message_templates\/(?P<id>[^\\\/]+)\/message_template_group":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"GRP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/message_templates\/(?P<id>[^\\\/]+)\/message_template_group\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/message_templates\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/message_templates\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/message_templates\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/message_templates\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/message_template_groups":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"GRP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"MTP_name":{"description":"The name of the template group","type":"string","default":"","required":false},"MTP_description":{"description":"A brief description about this template.","type":"string","default":"","required":false},"MTP_user_id":{"description":"Template Creator ID","type":"integer","default":125,"required":false},"MTP_messenger":{"description":"Messenger Used for Template","type":"string","default":"email","required":false},"MTP_message_type":{"description":"Message Type","type":"string","default":"registration","required":false},"MTP_is_global":{"description":"Flag indicating if Template Group is Global","type":"boolean","default":true,"required":false},"MTP_is_override":{"description":"Flag indicating if Template Group overrides any other Templates for the messenger\/messagetype combination","type":"boolean","default":false,"required":false},"MTP_deleted":{"description":"Flag indicating whether this has been trashed","type":"boolean","default":false,"required":false},"MTP_is_active":{"description":"Flag indicating whether template group is active","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/message_template_groups"}]}},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"MTP_name":{"description":"The name of the template group","type":"string","default":"","required":false},"MTP_description":{"description":"A brief description about this template.","type":"string","default":"","required":false},"MTP_user_id":{"description":"Template Creator ID","type":"integer","default":125,"required":false},"MTP_messenger":{"description":"Messenger Used for Template","type":"string","default":"email","required":false},"MTP_message_type":{"description":"Message Type","type":"string","default":"registration","required":false},"MTP_is_global":{"description":"Flag indicating if Template Group is Global","type":"boolean","default":true,"required":false},"MTP_is_override":{"description":"Flag indicating if Template Group overrides any other Templates for the messenger\/messagetype combination","type":"boolean","default":false,"required":false},"MTP_deleted":{"description":"Flag indicating whether this has been trashed","type":"boolean","default":false,"required":false},"MTP_is_active":{"description":"Flag indicating whether template group is active","type":"boolean","default":true,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/message_templates":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"MTP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/message_templates\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/messages":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"MSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/messages\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/events":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/events\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/message_template_groups\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payments":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PAY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"TXN_ID":{"description":"Transaction ID","type":"integer","default":0,"required":false},"STS_ID":{"description":"Status ID","type":"string","default":"PFL","required":false},"PAY_timestamp":{"description":"Timestamp of when payment was attempted - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"PAY_timestamp_gmt":{"description":"Timestamp of when payment was attempted - the value for this field in UTC. Ignored if PAY_timestamp is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"PAY_source":{"description":"User-friendly description of payment","type":"string","default":"CART","required":false},"PAY_amount":{"description":"Amount Payment should be for - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Amount Payment should be for - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Amount Payment should be for - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"PMD_ID":{"description":"Payment Method ID","type":"integer","default":null,"required":true},"PAY_gateway_response":{"description":"Response from Gateway about the payment","type":"string","default":"","required":false},"PAY_txn_id_chq_nmbr":{"description":"Gateway Transaction ID or Cheque Number","type":["string","null"],"default":"","required":false},"PAY_po_number":{"description":"Purchase or Sales Number","type":["string","null"],"default":"","required":false},"PAY_extra_accntng":{"description":"Extra Account Info","type":["string","null"],"default":"","required":false},"PAY_details":{"description":"Full Gateway response about payment","type":["object","string","null"],"default":"","required":false},"PAY_redirect_url":{"description":"Redirect URL","type":["string","null"],"default":null,"required":false},"PAY_redirect_args":{"description":"Key-Value POST vars to send along with redirect","type":["object","string","null"],"default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/payments"}]}},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"TXN_ID":{"description":"Transaction ID","type":"integer","default":0,"required":false},"STS_ID":{"description":"Status ID","type":"string","default":"PFL","required":false},"PAY_timestamp":{"description":"Timestamp of when payment was attempted - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"PAY_timestamp_gmt":{"description":"Timestamp of when payment was attempted - the value for this field in UTC. Ignored if PAY_timestamp is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"PAY_source":{"description":"User-friendly description of payment","type":"string","default":"CART","required":false},"PAY_amount":{"description":"Amount Payment should be for - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Amount Payment should be for - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Amount Payment should be for - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"PMD_ID":{"description":"Payment Method ID","type":"integer","default":null,"required":false},"PAY_gateway_response":{"description":"Response from Gateway about the payment","type":"string","default":"","required":false},"PAY_txn_id_chq_nmbr":{"description":"Gateway Transaction ID or Cheque Number","type":["string","null"],"default":"","required":false},"PAY_po_number":{"description":"Purchase or Sales Number","type":["string","null"],"default":"","required":false},"PAY_extra_accntng":{"description":"Extra Account Info","type":["string","null"],"default":"","required":false},"PAY_details":{"description":"Full Gateway response about payment","type":["object","string","null"],"default":"","required":false},"PAY_redirect_url":{"description":"Redirect URL","type":["string","null"],"default":null,"required":false},"PAY_redirect_args":{"description":"Key-Value POST vars to send along with redirect","type":["object","string","null"],"default":null,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/transaction":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TXN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/transaction\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/status":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"STS_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/status\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/payment_method":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PMD_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/payment_method\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/registration_payments":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"RPY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/registration_payments\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/registrations":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/registrations\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"RPY_amount":{"default":0,"type":"object","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payments\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payment_methods":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PMD_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"PMD_type":{"description":"Payment Method Type","type":"string","default":"Admin_Only","required":false},"PMD_name":{"description":"Name","type":"string","default":null,"required":true},"PMD_desc":{"description":"Description - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Description - the content rendered for display.","type":"string"}},"required":false},"PMD_admin_name":{"description":"Admin-Only Name","type":["string","null"],"default":null,"required":false},"PMD_admin_desc":{"description":"Admin-Only Description","type":["object","null"],"default":null,"properties":{"raw":{"description":"Admin-Only Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Admin-Only Description - the content rendered for display.","type":"string"}},"required":false},"PMD_slug":{"description":"Slug","type":"string","default":null,"required":true},"PMD_order":{"description":"Order","type":"integer","default":0,"required":false},"PMD_debug_mode":{"description":"Debug Mode On?","type":"boolean","default":false,"required":false},"PMD_wp_user":{"description":"Payment Method Creator ID","type":"integer","default":125,"required":false},"PMD_open_by_default":{"description":"Open by Default?","type":"boolean","default":false,"required":false},"PMD_button_url":{"description":"Button URL","type":["string","null"],"default":"","required":false},"PMD_scope":{"description":"Usable From?","type":["object","string"],"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/payment_methods"}]}},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"PMD_type":{"description":"Payment Method Type","type":"string","default":"Admin_Only","required":false},"PMD_name":{"description":"Name","type":"string","default":null,"required":false},"PMD_desc":{"description":"Description - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Description - the content rendered for display.","type":"string"}},"required":false},"PMD_admin_name":{"description":"Admin-Only Name","type":["string","null"],"default":null,"required":false},"PMD_admin_desc":{"description":"Admin-Only Description","type":["object","null"],"default":null,"properties":{"raw":{"description":"Admin-Only Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Admin-Only Description - the content rendered for display.","type":"string"}},"required":false},"PMD_slug":{"description":"Slug","type":"string","default":null,"required":false},"PMD_order":{"description":"Order","type":"integer","default":0,"required":false},"PMD_debug_mode":{"description":"Debug Mode On?","type":"boolean","default":false,"required":false},"PMD_wp_user":{"description":"Payment Method Creator ID","type":"integer","default":125,"required":false},"PMD_open_by_default":{"description":"Open by Default?","type":"boolean","default":false,"required":false},"PMD_button_url":{"description":"Button URL","type":["string","null"],"default":"","required":false},"PMD_scope":{"description":"Usable From?","type":["object","string"],"default":[],"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/payments":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PAY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/payments\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/currencies":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CUR_code":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/currencies\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/transactions":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TXN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/transactions\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/payment_methods\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/prices":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRC_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"PRT_ID":{"description":"Price type Id","type":"integer","default":null,"required":true},"PRC_amount":{"description":"Price Amount - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Price Amount - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Price Amount - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"PRC_name":{"description":"Name of Price","type":"string","default":"","required":false},"PRC_desc":{"description":"Price Description - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Price Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Price Description - the content rendered for display.","type":"string"}},"required":false},"PRC_is_default":{"description":"Flag indicating whether price is a default price","type":"boolean","default":false,"required":false},"PRC_overrides":{"description":"Price ID for a global Price that will be overridden by this Price  ( for replacing default prices )","type":["integer","null"],"default":0,"required":false},"PRC_order":{"description":"Order of Application of Price (lower numbers apply first?)","type":"integer","default":1,"required":false},"PRC_deleted":{"description":"Flag Indicating if this has been deleted or not","type":"boolean","default":false,"required":false},"PRC_parent":{"description":"Indicates what PRC_ID is the parent of this PRC_ID","type":["integer","null"],"default":0,"required":false},"PRC_wp_user":{"description":"Price Creator ID","type":"integer","default":125,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/prices"}]}},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"PRT_ID":{"description":"Price type Id","type":"integer","default":null,"required":false},"PRC_amount":{"description":"Price Amount - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Price Amount - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Price Amount - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"PRC_name":{"description":"Name of Price","type":"string","default":"","required":false},"PRC_desc":{"description":"Price Description - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Price Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Price Description - the content rendered for display.","type":"string"}},"required":false},"PRC_is_default":{"description":"Flag indicating whether price is a default price","type":"boolean","default":false,"required":false},"PRC_overrides":{"description":"Price ID for a global Price that will be overridden by this Price  ( for replacing default prices )","type":["integer","null"],"default":0,"required":false},"PRC_order":{"description":"Order of Application of Price (lower numbers apply first?)","type":"integer","default":1,"required":false},"PRC_deleted":{"description":"Flag Indicating if this has been deleted or not","type":"boolean","default":false,"required":false},"PRC_parent":{"description":"Indicates what PRC_ID is the parent of this PRC_ID","type":["integer","null"],"default":0,"required":false},"PRC_wp_user":{"description":"Price Creator ID","type":"integer","default":125,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)\/tickets":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)\/tickets\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)\/price_type":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)\/price_type\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/prices\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/price_types":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"PRT_name":{"description":"Price Type Name","type":"string","default":"","required":false},"PBT_ID":{"description":"Price Base type ID, 1 = Price , 2 = Discount , 3 = Surcharge , 4 = Tax - the value in the database.","type":"integer","default":1,"properties":{"raw":{"description":"Price Base type ID, 1 = Price , 2 = Discount , 3 = Surcharge , 4 = Tax - the value in the database.","enum":[1,2,3,4],"type":"integer"},"pretty":{"description":"Price Base type ID, 1 = Price , 2 = Discount , 3 = Surcharge , 4 = Tax - the value for display.","enum":["Price","Discount","Surcharge","Tax"],"type":"string","read_only":true}},"enum":[1,2,3,4],"required":false},"PRT_is_percent":{"description":"Flag indicating price is a percentage","type":"boolean","default":false,"required":false},"PRT_order":{"description":"Order in which price should be applied. ","type":"integer","default":0,"required":false},"PRT_deleted":{"description":"Flag indicating price type has been trashed","type":"boolean","default":false,"required":false},"PRT_wp_user":{"description":"Price Type Creator ID","type":"integer","default":125,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/price_types"}]}},"\/ee\/v4.8.36\/price_types\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"PRT_name":{"description":"Price Type Name","type":"string","default":"","required":false},"PBT_ID":{"description":"Price Base type ID, 1 = Price , 2 = Discount , 3 = Surcharge , 4 = Tax - the value in the database.","type":"integer","default":1,"properties":{"raw":{"description":"Price Base type ID, 1 = Price , 2 = Discount , 3 = Surcharge , 4 = Tax - the value in the database.","enum":[1,2,3,4],"type":"integer"},"pretty":{"description":"Price Base type ID, 1 = Price , 2 = Discount , 3 = Surcharge , 4 = Tax - the value for display.","enum":["Price","Discount","Surcharge","Tax"],"type":"string","read_only":true}},"enum":[1,2,3,4],"required":false},"PRT_is_percent":{"description":"Flag indicating price is a percentage","type":"boolean","default":false,"required":false},"PRT_order":{"description":"Order in which price should be applied. ","type":"integer","default":0,"required":false},"PRT_deleted":{"description":"Flag indicating price type has been trashed","type":"boolean","default":false,"required":false},"PRT_wp_user":{"description":"Price Type Creator ID","type":"integer","default":125,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/price_types\/(?P<id>[^\\\/]+)\/prices":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRC_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/price_types\/(?P<id>[^\\\/]+)\/prices\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/price_types\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/price_types\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/price_types\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/price_types\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/price_types\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/price_types\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/questions":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QST_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"QST_display_text":{"description":"Question Text","type":["object","null"],"default":"","properties":{"raw":{"description":"Question Text - the content as it exists in the database.","type":"string"},"rendered":{"description":"Question Text - the content rendered for display.","type":"string"}},"required":false},"QST_admin_label":{"description":"Question Label (admin-only)","type":["string","null"],"default":"","required":false},"QST_system":{"description":"Internal string ID for question","type":"string","default":"","required":false},"QST_type":{"description":"Question Type - the value in the database.","type":"string","default":"TEXT","properties":{"raw":{"description":"Question Type - the value in the database.","type":"string","enum":["TEXT","TEXTAREA","CHECKBOX","RADIO_BTN","DROPDOWN","STATE","COUNTRY","DATE","HTML_TEXTAREA","EMAIL","EMAIL_CONFIRM","US_PHONE","DECIMAL","INTEGER","URL","YEAR","MULTI_SELECT"]},"pretty":{"description":"Question Type - the value for display.","type":"string","enum":["Text","Textarea","Checkboxes","Radio Buttons","Dropdown","State\/Province Dropdown","Country Dropdown","Date Picker","HTML Textarea","Email","Confirm Email","USA - Format Phone","Number","Whole Number","URL","Year","Multi Select"],"read_only":true}},"enum":["TEXT","TEXTAREA","CHECKBOX","RADIO_BTN","DROPDOWN","STATE","COUNTRY","DATE","HTML_TEXTAREA","EMAIL","EMAIL_CONFIRM","US_PHONE","DECIMAL","INTEGER","URL","YEAR","MULTI_SELECT"],"required":false},"QST_required":{"description":"Required Question?","type":"boolean","default":false,"required":false},"QST_required_text":{"description":"Text to Display if Not Provided","type":["string","null"],"default":"","required":false},"QST_order":{"description":"Question Order","type":"integer","default":0,"required":false},"QST_admin_only":{"description":"Admin-Only Question?","type":"boolean","default":false,"required":false},"QST_max":{"description":"Max Size","type":["integer","null"],"default":null,"required":false},"QST_wp_user":{"description":"Question Creator ID","type":"integer","default":125,"required":false},"QST_deleted":{"description":"Flag Indicating question was deleted","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/questions"}]}},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"QST_display_text":{"description":"Question Text","type":["object","null"],"default":"","properties":{"raw":{"description":"Question Text - the content as it exists in the database.","type":"string"},"rendered":{"description":"Question Text - the content rendered for display.","type":"string"}},"required":false},"QST_admin_label":{"description":"Question Label (admin-only)","type":["string","null"],"default":"","required":false},"QST_system":{"description":"Internal string ID for question","type":"string","default":"","required":false},"QST_type":{"description":"Question Type - the value in the database.","type":"string","default":"TEXT","properties":{"raw":{"description":"Question Type - the value in the database.","type":"string","enum":["TEXT","TEXTAREA","CHECKBOX","RADIO_BTN","DROPDOWN","STATE","COUNTRY","DATE","HTML_TEXTAREA","EMAIL","EMAIL_CONFIRM","US_PHONE","DECIMAL","INTEGER","URL","YEAR","MULTI_SELECT"]},"pretty":{"description":"Question Type - the value for display.","type":"string","enum":["Text","Textarea","Checkboxes","Radio Buttons","Dropdown","State\/Province Dropdown","Country Dropdown","Date Picker","HTML Textarea","Email","Confirm Email","USA - Format Phone","Number","Whole Number","URL","Year","Multi Select"],"read_only":true}},"enum":["TEXT","TEXTAREA","CHECKBOX","RADIO_BTN","DROPDOWN","STATE","COUNTRY","DATE","HTML_TEXTAREA","EMAIL","EMAIL_CONFIRM","US_PHONE","DECIMAL","INTEGER","URL","YEAR","MULTI_SELECT"],"required":false},"QST_required":{"description":"Required Question?","type":"boolean","default":false,"required":false},"QST_required_text":{"description":"Text to Display if Not Provided","type":["string","null"],"default":"","required":false},"QST_order":{"description":"Question Order","type":"integer","default":0,"required":false},"QST_admin_only":{"description":"Admin-Only Question?","type":"boolean","default":false,"required":false},"QST_max":{"description":"Max Size","type":["integer","null"],"default":null,"required":false},"QST_wp_user":{"description":"Question Creator ID","type":"integer","default":125,"required":false},"QST_deleted":{"description":"Flag Indicating question was deleted","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/question_groups":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/question_groups\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"QGQ_order":{"default":0,"type":"integer","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/question_options":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QSO_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/question_options\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/answers":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ANS_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/answers\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/question_group_questions":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QGQ_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/question_group_questions\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/questions\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_groups":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"QSG_name":{"description":"Question Group Name","type":"string","default":"","required":false},"QSG_identifier":{"description":"Text ID for question Group","type":"string","default":"","required":false},"QSG_desc":{"description":"Description of Question Group","type":["object","null"],"default":"","properties":{"raw":{"description":"Description of Question Group - the content as it exists in the database.","type":"string"},"rendered":{"description":"Description of Question Group - the content rendered for display.","type":"string"}},"required":false},"QSG_order":{"description":"Order in which to show the question group","type":["integer","null"],"default":0,"required":false},"QSG_show_group_name":{"description":"Flag indicating whether to show the group&#039;s name on the registration page","type":"boolean","default":true,"required":false},"QSG_show_group_desc":{"description":"Flag indicating whether to show the group\\s description on the registration page","type":"boolean","default":false,"required":false},"QSG_wp_user":{"description":"Question Group Creator ID","type":"integer","default":125,"required":false},"QSG_system":{"description":"Indicate IF this is a system group and if it is what system group it corresponds to.","type":"integer","default":0,"required":false},"QSG_deleted":{"description":"Flag indicating this question group was deleted","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/question_groups"}]}},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"QSG_name":{"description":"Question Group Name","type":"string","default":"","required":false},"QSG_identifier":{"description":"Text ID for question Group","type":"string","default":"","required":false},"QSG_desc":{"description":"Description of Question Group","type":["object","null"],"default":"","properties":{"raw":{"description":"Description of Question Group - the content as it exists in the database.","type":"string"},"rendered":{"description":"Description of Question Group - the content rendered for display.","type":"string"}},"required":false},"QSG_order":{"description":"Order in which to show the question group","type":["integer","null"],"default":0,"required":false},"QSG_show_group_name":{"description":"Flag indicating whether to show the group&#039;s name on the registration page","type":"boolean","default":true,"required":false},"QSG_show_group_desc":{"description":"Flag indicating whether to show the group\\s description on the registration page","type":"boolean","default":false,"required":false},"QSG_wp_user":{"description":"Question Group Creator ID","type":"integer","default":125,"required":false},"QSG_system":{"description":"Indicate IF this is a system group and if it is what system group it corresponds to.","type":"integer","default":0,"required":false},"QSG_deleted":{"description":"Flag indicating this question group was deleted","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/questions":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QST_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/questions\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"QGQ_order":{"default":0,"type":"integer","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/events":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/events\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"EQG_primary":{"default":false,"type":"boolean","required":true},"EQG_additional":{"default":false,"type":"boolean","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/event_question_groups":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EQG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/event_question_groups\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_groups\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_group_questions":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QGQ_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"QSG_ID":{"description":"Question Group ID","type":"integer","default":0,"required":false},"QST_ID":{"description":"Question Id","type":"integer","default":0,"required":false},"QGQ_order":{"description":"Question Group Question Order","type":"integer","default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/question_group_questions"}]}},"\/ee\/v4.8.36\/question_group_questions\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"QSG_ID":{"description":"Question Group ID","type":"integer","default":0,"required":false},"QST_ID":{"description":"Question Id","type":"integer","default":0,"required":false},"QGQ_order":{"description":"Question Group Question Order","type":"integer","default":0,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/question_group_questions\/(?P<id>[^\\\/]+)\/question_group":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_group_questions\/(?P<id>[^\\\/]+)\/question_group\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_group_questions\/(?P<id>[^\\\/]+)\/question":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QST_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_group_questions\/(?P<id>[^\\\/]+)\/question\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_group_questions\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_group_questions\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_group_questions\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_group_questions\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_options":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QSO_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"QST_ID":{"description":"Question ID","type":"integer","default":0,"required":false},"QSO_value":{"description":"Question Option Value","type":"string","default":"","required":false},"QSO_desc":{"description":"Question Option Description - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Question Option Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Question Option Description - the content rendered for display.","type":"string"}},"required":false},"QSO_order":{"description":"Question Option Order","type":"integer","default":0,"required":false},"QSO_system":{"description":"Internal string ID for question option","type":["string","null"],"default":null,"required":false},"QSO_deleted":{"description":"Flag indicating Option was trashed","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/question_options"}]}},"\/ee\/v4.8.36\/question_options\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"QST_ID":{"description":"Question ID","type":"integer","default":0,"required":false},"QSO_value":{"description":"Question Option Value","type":"string","default":"","required":false},"QSO_desc":{"description":"Question Option Description - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Question Option Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Question Option Description - the content rendered for display.","type":"string"}},"required":false},"QSO_order":{"description":"Question Option Order","type":"integer","default":0,"required":false},"QSO_system":{"description":"Internal string ID for question option","type":["string","null"],"default":null,"required":false},"QSO_deleted":{"description":"Flag indicating Option was trashed","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/question_options\/(?P<id>[^\\\/]+)\/question":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QST_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_options\/(?P<id>[^\\\/]+)\/question\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_options\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_options\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/question_options\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/question_options\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"EVT_ID":{"description":"Event ID","type":"integer","default":0,"required":false},"ATT_ID":{"description":"Attendee ID","type":"integer","default":0,"required":false},"TXN_ID":{"description":"Transaction ID","type":"integer","default":0,"required":false},"TKT_ID":{"description":"Ticket ID","type":"integer","default":0,"required":false},"STS_ID":{"description":"Status ID","type":"string","default":"RIC","required":false},"REG_date":{"description":"Time registration occurred - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"REG_date_gmt":{"description":"Time registration occurred - the value for this field in UTC. Ignored if REG_date is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"REG_final_price":{"description":"Registration&#039;s share of the transaction total - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Registration&#039;s share of the transaction total - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Registration&#039;s share of the transaction total - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"REG_paid":{"description":"Amount paid to date towards registration - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Amount paid to date towards registration - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Amount paid to date towards registration - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"REG_session":{"description":"Session ID of registration","type":"string","default":"","required":false},"REG_code":{"description":"Unique Code for this registration","type":"string","default":"","required":false},"REG_url_link":{"description":"String to be used in URL for identifying registration","type":"string","default":"","required":false},"REG_count":{"description":"Count of this registration in the group registration ","type":["integer","null"],"default":1,"required":false},"REG_group_size":{"description":"Number of registrations on this group","type":"integer","default":1,"required":false},"REG_att_is_going":{"description":"Flag indicating the registrant plans on attending","type":"boolean","default":false,"required":false},"REG_deleted":{"description":"Flag indicating if registration has been archived or not.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/registrations"}]}},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"EVT_ID":{"description":"Event ID","type":"integer","default":0,"required":false},"ATT_ID":{"description":"Attendee ID","type":"integer","default":0,"required":false},"TXN_ID":{"description":"Transaction ID","type":"integer","default":0,"required":false},"TKT_ID":{"description":"Ticket ID","type":"integer","default":0,"required":false},"STS_ID":{"description":"Status ID","type":"string","default":"RIC","required":false},"REG_date":{"description":"Time registration occurred - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"REG_date_gmt":{"description":"Time registration occurred - the value for this field in UTC. Ignored if REG_date is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"REG_final_price":{"description":"Registration&#039;s share of the transaction total - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Registration&#039;s share of the transaction total - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Registration&#039;s share of the transaction total - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"REG_paid":{"description":"Amount paid to date towards registration - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Amount paid to date towards registration - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Amount paid to date towards registration - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"REG_session":{"description":"Session ID of registration","type":"string","default":"","required":false},"REG_code":{"description":"Unique Code for this registration","type":"string","default":"","required":false},"REG_url_link":{"description":"String to be used in URL for identifying registration","type":"string","default":"","required":false},"REG_count":{"description":"Count of this registration in the group registration ","type":["integer","null"],"default":1,"required":false},"REG_group_size":{"description":"Number of registrations on this group","type":"integer","default":1,"required":false},"REG_att_is_going":{"description":"Flag indicating the registrant plans on attending","type":"boolean","default":false,"required":false},"REG_deleted":{"description":"Flag indicating if registration has been archived or not.","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/event":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/event\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/attendee":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ATT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/attendee\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/transaction":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TXN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/transaction\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/ticket":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/ticket\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/status":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"STS_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/status\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/answers":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ANS_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/answers\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/checkins":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CHK_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/checkins\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/registration_payments":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"RPY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/registration_payments\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/payments":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PAY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/payments\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"RPY_amount":{"default":0,"type":"object","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/messages":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"MSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/messages\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registrations\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registration_payments":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"RPY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"REG_ID":{"description":"Registration ID","type":"integer","default":0,"required":false},"PAY_ID":{"description":"Payment ID","type":["integer","null"],"default":null,"required":false},"RPY_amount":{"description":"Amount attributed to the registration - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Amount attributed to the registration - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Amount attributed to the registration - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/registration_payments"}]}},"\/ee\/v4.8.36\/registration_payments\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"REG_ID":{"description":"Registration ID","type":"integer","default":0,"required":false},"PAY_ID":{"description":"Payment ID","type":["integer","null"],"default":null,"required":false},"RPY_amount":{"description":"Amount attributed to the registration - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Amount attributed to the registration - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Amount attributed to the registration - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/registration_payments\/(?P<id>[^\\\/]+)\/registration":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registration_payments\/(?P<id>[^\\\/]+)\/registration\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registration_payments\/(?P<id>[^\\\/]+)\/payment":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PAY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registration_payments\/(?P<id>[^\\\/]+)\/payment\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registration_payments\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registration_payments\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registration_payments\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/registration_payments\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/states":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"STA_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"CNT_ISO":{"description":"Country ISO Code","type":"string","default":null,"required":true},"STA_abbrev":{"description":"State Abbreviation","type":"string","default":"","required":false},"STA_name":{"description":"State Name","type":"string","default":"","required":false},"STA_active":{"description":"State Active Flag","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/states"}]}},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"CNT_ISO":{"description":"Country ISO Code","type":"string","default":null,"required":false},"STA_abbrev":{"description":"State Abbreviation","type":"string","default":"","required":false},"STA_name":{"description":"State Name","type":"string","default":"","required":false},"STA_active":{"description":"State Active Flag","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)\/attendees":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ATT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)\/attendees\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)\/country":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CNT_ISO":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)\/country\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)\/venues":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"VNU_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)\/venues\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/states\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/statuses":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"STS_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"STS_ID":{"description":"Status ID","type":"string","default":null,"required":true},"STS_code":{"description":"Status Code","type":"string","default":"","required":false},"STS_type":{"description":"Type - the value in the database.","type":"string","default":"event","properties":{"raw":{"description":"Type - the value in the database.","type":"string","enum":["event","registration","transaction","payment","email","message"]},"pretty":{"description":"Type - the value for display.","type":"string","enum":["Event","Registration","Transaction","Payment","Email","Message"],"read_only":true}},"enum":["event","registration","transaction","payment","email","message"],"required":false},"STS_can_edit":{"description":"Editable?","type":"boolean","default":false,"required":false},"STS_desc":{"description":"Description","type":"string","default":"","required":false},"STS_open":{"description":"Open?","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/statuses"}]}},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"STS_ID":{"description":"Status ID","type":"string","default":null,"required":false},"STS_code":{"description":"Status Code","type":"string","default":"","required":false},"STS_type":{"description":"Type - the value in the database.","type":"string","default":"event","properties":{"raw":{"description":"Type - the value in the database.","type":"string","enum":["event","registration","transaction","payment","email","message"]},"pretty":{"description":"Type - the value for display.","type":"string","enum":["Event","Registration","Transaction","Payment","Email","Message"],"read_only":true}},"enum":["event","registration","transaction","payment","email","message"],"required":false},"STS_can_edit":{"description":"Editable?","type":"boolean","default":false,"required":false},"STS_desc":{"description":"Description","type":"string","default":"","required":false},"STS_open":{"description":"Open?","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)\/registrations":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)\/registrations\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)\/transactions":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TXN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)\/transactions\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)\/payments":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PAY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)\/payments\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/statuses\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/terms":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"term_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/terms"}]}},"\/ee\/v4.8.36\/terms\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}}]},"\/ee\/v4.8.36\/terms\/(?P<id>[^\\\/]+)\/term_taxonomies":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/terms\/(?P<id>[^\\\/]+)\/term_taxonomies\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/terms\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/terms\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/terms\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/terms\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_relationships":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"object_id":"ASC","term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/term_relationships"}]}},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/term_taxonomy":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/term_taxonomy\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/attendee":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ATT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/attendee\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/event":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/event\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/venue":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"VNU_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/venue\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_relationships\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_taxonomies":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/term_taxonomies"}]}},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/term_relationships":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"object_id":"ASC","term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/term_relationships\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/term":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"term_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/term\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/attendees":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ATT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/attendees\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/events":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/events\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/venues":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"VNU_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/venues\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/term_taxonomies\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/tickets":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"TTM_ID":{"description":"Ticket Template ID","type":"integer","default":0,"required":false},"TKT_name":{"description":"Ticket Name","type":"string","default":"","required":false},"TKT_description":{"description":"Description of Ticket - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Description of Ticket - the content as it exists in the database.","type":"string"},"rendered":{"description":"Description of Ticket - the content rendered for display.","type":"string"}},"required":false},"TKT_start_date":{"description":"Start time\/date of Ticket - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TKT_start_date_gmt":{"description":"Start time\/date of Ticket - the value for this field in UTC. Ignored if TKT_start_date is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TKT_end_date":{"description":"End time\/date of Ticket - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TKT_end_date_gmt":{"description":"End time\/date of Ticket - the value for this field in UTC. Ignored if TKT_end_date is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TKT_min":{"description":"Minimum quantity of this ticket that must be purchased","type":"integer","default":0,"required":false},"TKT_max":{"description":"Maximum quantity of this ticket that can be purchased in one transaction","type":["integer","null"],"default":null,"required":false},"TKT_price":{"description":"Final calculated price for ticket - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Final calculated price for ticket - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Final calculated price for ticket - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"TKT_sold":{"description":"Number of this ticket sold","type":"integer","default":0,"required":false},"TKT_qty":{"description":"Quantity of this ticket that is available","type":["integer","null"],"default":null,"required":false},"TKT_reserved":{"description":"Quantity of this ticket that is reserved, but not yet fully purchased","type":"integer","default":0,"required":false},"TKT_uses":{"description":"Number of datetimes this ticket can be used at","type":["integer","null"],"default":null,"required":false},"TKT_required":{"description":"Flag indicating whether this ticket must be purchased with a transaction","type":"boolean","default":false,"required":false},"TKT_taxable":{"description":"Flag indicating whether there is tax applied on this ticket","type":"boolean","default":false,"required":false},"TKT_is_default":{"description":"Flag indicating that this ticket is a default ticket","type":"boolean","default":false,"required":false},"TKT_order":{"description":"The order in which the Ticket is displayed in the editor (used for autosaves when the form doesn&#039;t have the ticket ID yet)","type":"integer","default":0,"required":false},"TKT_row":{"description":"How tickets are displayed in the ui","type":"integer","default":0,"required":false},"TKT_deleted":{"description":"Flag indicating if this has been archived or not","type":"boolean","default":false,"required":false},"TKT_wp_user":{"description":"Ticket Creator ID","type":"integer","default":125,"required":false},"TKT_parent":{"description":"Indicates what TKT_ID is the parent of this TKT_ID (used in autosaves\/revisions)","type":["integer","null"],"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/tickets"}]}},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"TTM_ID":{"description":"Ticket Template ID","type":"integer","default":0,"required":false},"TKT_name":{"description":"Ticket Name","type":"string","default":"","required":false},"TKT_description":{"description":"Description of Ticket - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Description of Ticket - the content as it exists in the database.","type":"string"},"rendered":{"description":"Description of Ticket - the content rendered for display.","type":"string"}},"required":false},"TKT_start_date":{"description":"Start time\/date of Ticket - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TKT_start_date_gmt":{"description":"Start time\/date of Ticket - the value for this field in UTC. Ignored if TKT_start_date is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TKT_end_date":{"description":"End time\/date of Ticket - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TKT_end_date_gmt":{"description":"End time\/date of Ticket - the value for this field in UTC. Ignored if TKT_end_date is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TKT_min":{"description":"Minimum quantity of this ticket that must be purchased","type":"integer","default":0,"required":false},"TKT_max":{"description":"Maximum quantity of this ticket that can be purchased in one transaction","type":["integer","null"],"default":null,"required":false},"TKT_price":{"description":"Final calculated price for ticket - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Final calculated price for ticket - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Final calculated price for ticket - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"TKT_sold":{"description":"Number of this ticket sold","type":"integer","default":0,"required":false},"TKT_qty":{"description":"Quantity of this ticket that is available","type":["integer","null"],"default":null,"required":false},"TKT_reserved":{"description":"Quantity of this ticket that is reserved, but not yet fully purchased","type":"integer","default":0,"required":false},"TKT_uses":{"description":"Number of datetimes this ticket can be used at","type":["integer","null"],"default":null,"required":false},"TKT_required":{"description":"Flag indicating whether this ticket must be purchased with a transaction","type":"boolean","default":false,"required":false},"TKT_taxable":{"description":"Flag indicating whether there is tax applied on this ticket","type":"boolean","default":false,"required":false},"TKT_is_default":{"description":"Flag indicating that this ticket is a default ticket","type":"boolean","default":false,"required":false},"TKT_order":{"description":"The order in which the Ticket is displayed in the editor (used for autosaves when the form doesn&#039;t have the ticket ID yet)","type":"integer","default":0,"required":false},"TKT_row":{"description":"How tickets are displayed in the ui","type":"integer","default":0,"required":false},"TKT_deleted":{"description":"Flag indicating if this has been archived or not","type":"boolean","default":false,"required":false},"TKT_wp_user":{"description":"Ticket Creator ID","type":"integer","default":125,"required":false},"TKT_parent":{"description":"Indicates what TKT_ID is the parent of this TKT_ID (used in autosaves\/revisions)","type":["integer","null"],"default":0,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/datetimes":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["spaces_remaining_considering_tickets","registrations_checked_in_count","registrations_checked_out_count","spots_taken_pending_payment"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"DTT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/datetimes\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/datetime_tickets":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"DTK_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/datetime_tickets\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/prices":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRC_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/prices\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/ticket_template":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TTM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/ticket_template\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/registrations":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/registrations\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/tickets\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/ticket_prices":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKP_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"TKT_ID":{"description":"Ticket Id","type":"integer","default":0,"required":false},"PRC_ID":{"description":"Price ID","type":"integer","default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/ticket_prices"}]}},"\/ee\/v4.8.36\/ticket_prices\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"TKT_ID":{"description":"Ticket Id","type":"integer","default":0,"required":false},"PRC_ID":{"description":"Price ID","type":"integer","default":0,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/ticket_prices\/(?P<id>[^\\\/]+)\/ticket":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/ticket_prices\/(?P<id>[^\\\/]+)\/ticket\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/ticket_prices\/(?P<id>[^\\\/]+)\/price":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRC_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/ticket_prices\/(?P<id>[^\\\/]+)\/price\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/ticket_prices\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/ticket_prices\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/ticket_prices\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/ticket_prices\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/ticket_templates":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TTM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"TTM_name":{"description":"The name of the ticket template","type":"string","default":"","required":false},"TTM_description":{"description":"The description for the ticket template","type":["string","null"],"default":"","required":false},"TTM_file":{"description":"The file name for the actual template file saved on disk","type":["string","null"],"default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/ticket_templates"}]}},"\/ee\/v4.8.36\/ticket_templates\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"TTM_name":{"description":"The name of the ticket template","type":"string","default":"","required":false},"TTM_description":{"description":"The description for the ticket template","type":["string","null"],"default":"","required":false},"TTM_file":{"description":"The file name for the actual template file saved on disk","type":["string","null"],"default":"","required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/ticket_templates\/(?P<id>[^\\\/]+)\/tickets":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/ticket_templates\/(?P<id>[^\\\/]+)\/tickets\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/ticket_templates\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/ticket_templates\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/ticket_templates\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/ticket_templates\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/transactions":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TXN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"TXN_timestamp":{"description":"date when transaction was created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TXN_timestamp_gmt":{"description":"date when transaction was created - the value for this field in UTC. Ignored if TXN_timestamp is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TXN_total":{"description":"Total value of Transaction - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Total value of Transaction - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Total value of Transaction - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"TXN_paid":{"description":"Amount paid towards transaction to date - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Amount paid towards transaction to date - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Amount paid towards transaction to date - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"STS_ID":{"description":"Status ID","type":"string","default":"TFL","required":false},"TXN_session_data":{"description":"Serialized session data","type":["object","string","null"],"default":"","required":false},"TXN_hash_salt":{"description":"Transaction Hash Salt","type":["string","null"],"default":"","required":false},"PMD_ID":{"description":"Last Used Payment Method","type":["integer","null"],"default":null,"required":false},"TXN_reg_steps":{"description":"Registration Steps","type":["object","string"],"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/transactions"}]}},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"TXN_timestamp":{"description":"date when transaction was created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TXN_timestamp_gmt":{"description":"date when transaction was created - the value for this field in UTC. Ignored if TXN_timestamp is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"TXN_total":{"description":"Total value of Transaction - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Total value of Transaction - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Total value of Transaction - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"TXN_paid":{"description":"Amount paid towards transaction to date - the raw value as it exists in the database as a simple float.","type":"number","default":0,"properties":{"raw":{"description":"Amount paid towards transaction to date - the raw value as it exists in the database as a simple float.","type":"number"},"pretty":{"description":"Amount paid towards transaction to date - formatted for display in the set currency and decimal places.","type":"string","format":"money"}},"required":false},"STS_ID":{"description":"Status ID","type":"string","default":"TFL","required":false},"TXN_session_data":{"description":"Serialized session data","type":["object","string","null"],"default":"","required":false},"TXN_hash_salt":{"description":"Transaction Hash Salt","type":["string","null"],"default":"","required":false},"PMD_ID":{"description":"Last Used Payment Method","type":["integer","null"],"default":null,"required":false},"TXN_reg_steps":{"description":"Registration Steps","type":["object","string"],"default":[],"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/registrations":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["datetime_checkin_stati"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"REG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/registrations\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/payments":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PAY_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/payments\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/status":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"STS_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/status\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/line_items":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LIN_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/line_items\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/payment_method":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PMD_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/payment_method\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/messages":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"MSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/messages\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/transactions\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/venues":{"namespace":"ee\/v4.8.36","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"VNU_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}},{"methods":["POST"],"args":{"VNU_name":{"description":"Venue Name","type":"string","default":"","required":false},"VNU_desc":{"description":"Venue Description - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Venue Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Venue Description - the content rendered for display.","type":"string"}},"required":false},"VNU_identifier":{"description":"Venue Identifier","type":"string","default":"","required":false},"VNU_created":{"description":"Date Venue Created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"VNU_created_gmt":{"description":"Date Venue Created - the value for this field in UTC. Ignored if VNU_created is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"VNU_short_desc":{"description":"Short Description of Venue","type":["string","null"],"default":"","required":false},"VNU_modified":{"description":"Venue Modified Date - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"VNU_modified_gmt":{"description":"Venue Modified Date - the value for this field in UTC. Ignored if VNU_modified is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"VNU_wp_user":{"description":"Venue Creator ID","type":"integer","default":125,"required":false},"parent":{"description":"Venue Parent ID","type":"integer","default":0,"required":false},"VNU_order":{"description":"Venue order","type":"integer","default":1,"required":false},"password":{"description":"Password","type":"string","default":"","required":false},"status":{"description":"Event Status - the value in the database.","type":"string","default":"draft","properties":{"raw":{"description":"Event Status - the value in the database.","type":"string","enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"]},"pretty":{"description":"Event Status - the value for display.","type":"string","enum":["Published","Scheduled","Draft","Pending","Private","Trash","auto-draft","inherit","Pending","Confirmed","Failed","Completed","Expired","Inactive","Graded","Not Graded","Cancelled","Postponed","Sold Out"],"read_only":true}},"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"],"required":false},"comment_status":{"description":"Comment Status","type":"string","default":"open","required":false},"ping_status":{"description":"Ping Status","type":"string","default":"open","required":false},"VNU_address":{"description":"Venue Address line 1","type":["string","null"],"default":"","required":false},"VNU_address2":{"description":"Venue Address line 2","type":["string","null"],"default":"","required":false},"VNU_city":{"description":"Venue City","type":["string","null"],"default":"","required":false},"STA_ID":{"description":"State ID","type":["integer","null"],"default":null,"required":false},"CNT_ISO":{"description":"Country Code","type":["string","null"],"default":null,"required":false},"VNU_zip":{"description":"Venue Zip\/Postal Code","type":["string","null"],"default":null,"required":false},"VNU_phone":{"description":"Venue Phone","type":["string","null"],"default":null,"required":false},"VNU_capacity":{"description":"Venue Capacity","type":["integer","null"],"default":null,"required":false},"VNU_url":{"description":"Venue Website","type":["string","null"],"default":null,"required":false},"VNU_virtual_phone":{"description":"Call in Number","type":["string","null"],"default":null,"required":false},"VNU_virtual_url":{"description":"Virtual URL","type":["string","null"],"default":null,"required":false},"VNU_google_map_link":{"description":"Google Map Link","type":["string","null"],"default":null,"required":false},"VNU_enable_for_gmap":{"description":"Show Google Map?","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/venues"}]}},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"VNU_name":{"description":"Venue Name","type":"string","default":"","required":false},"VNU_desc":{"description":"Venue Description - the content as it exists in the database.","type":"string","default":"","properties":{"raw":{"description":"Venue Description - the content as it exists in the database.","type":"string"},"rendered":{"description":"Venue Description - the content rendered for display.","type":"string"}},"required":false},"VNU_identifier":{"description":"Venue Identifier","type":"string","default":"","required":false},"VNU_created":{"description":"Date Venue Created - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"VNU_created_gmt":{"description":"Date Venue Created - the value for this field in UTC. Ignored if VNU_created is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"VNU_short_desc":{"description":"Short Description of Venue","type":["string","null"],"default":"","required":false},"VNU_modified":{"description":"Venue Modified Date - the value for this field is in the timezone of the site.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"VNU_modified_gmt":{"description":"Venue Modified Date - the value for this field in UTC. Ignored if VNU_modified is provided.","type":"string","default":"2023-03-17T19:55:29","format":"date-time","required":false},"VNU_wp_user":{"description":"Venue Creator ID","type":"integer","default":125,"required":false},"parent":{"description":"Venue Parent ID","type":"integer","default":0,"required":false},"VNU_order":{"description":"Venue order","type":"integer","default":1,"required":false},"password":{"description":"Password","type":"string","default":"","required":false},"status":{"description":"Event Status - the value in the database.","type":"string","default":"draft","properties":{"raw":{"description":"Event Status - the value in the database.","type":"string","enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"]},"pretty":{"description":"Event Status - the value for display.","type":"string","enum":["Published","Scheduled","Draft","Pending","Private","Trash","auto-draft","inherit","Pending","Confirmed","Failed","Completed","Expired","Inactive","Graded","Not Graded","Cancelled","Postponed","Sold Out"],"read_only":true}},"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","advanced_ads_expired","acf-disabled","graded","not_graded","cancelled","postponed","sold_out"],"required":false},"comment_status":{"description":"Comment Status","type":"string","default":"open","required":false},"ping_status":{"description":"Ping Status","type":"string","default":"open","required":false},"VNU_address":{"description":"Venue Address line 1","type":["string","null"],"default":"","required":false},"VNU_address2":{"description":"Venue Address line 2","type":["string","null"],"default":"","required":false},"VNU_city":{"description":"Venue City","type":["string","null"],"default":"","required":false},"STA_ID":{"description":"State ID","type":["integer","null"],"default":null,"required":false},"CNT_ISO":{"description":"Country Code","type":["string","null"],"default":null,"required":false},"VNU_zip":{"description":"Venue Zip\/Postal Code","type":["string","null"],"default":null,"required":false},"VNU_phone":{"description":"Venue Phone","type":["string","null"],"default":null,"required":false},"VNU_capacity":{"description":"Venue Capacity","type":["integer","null"],"default":null,"required":false},"VNU_url":{"description":"Venue Website","type":["string","null"],"default":null,"required":false},"VNU_virtual_phone":{"description":"Call in Number","type":["string","null"],"default":null,"required":false},"VNU_virtual_url":{"description":"Virtual URL","type":["string","null"],"default":null,"required":false},"VNU_google_map_link":{"description":"Google Map Link","type":["string","null"],"default":null,"required":false},"VNU_enable_for_gmap":{"description":"Show Google Map?","type":"boolean","default":false,"required":false}}},{"methods":["DELETE"],"args":{"allow_blocking":{"default":true,"type":"boolean","required":false},"force":{"default":false,"type":"boolean","required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/events":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/events\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"EVV_primary":{"default":true,"type":"boolean","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/state":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"STA_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/state\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/country":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"CNT_ISO":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/country\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/event_venues":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVV_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/event_venues\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/wp_user":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/wp_user\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/term_relationships":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"object_id":"ASC","term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/term_relationships\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/term_taxonomies":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"term_taxonomy_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/term_taxonomies\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/post_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"meta_id":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/post_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/venues\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/ee\/v4.8.36\/wp_users"}]}},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/attendees":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["user_avatar"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"ATT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/attendees\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/events":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":["optimum_sales_at_start","optimum_sales_now","spaces_remaining","spots_taken","spots_taken_pending_payment","registrations_checked_in_count","registrations_checked_out_count","image_thumbnail","image_medium","image_medium_large","image_large","image_post_thumbnail","image_full"],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EVT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/events\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/messages":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"MSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/messages\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/payment_methods":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PMD_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/payment_methods\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/prices":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRC_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/prices\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/price_types":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"PRT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/price_types\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/questions":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QST_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/questions\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/question_groups":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"QSG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/question_groups\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/tickets":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"TKT_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/tickets\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/venues":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"VNU_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/venues\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/extra_metas":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"EXM_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/extra_metas\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/change_logs":{"namespace":"ee\/v4.8.36","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"include":{"default":"*","type":"string","required":false},"calculate":{"default":"","enum":[],"type":"string","required":false},"password":{"default":"","type":"string","required":false},"where":{"default":[],"type":"object","required":false},"limit":{"default":50,"type":["array","string","integer"],"required":false},"order_by":{"default":{"LOG_ID":"ASC"},"type":["object","string"],"required":false},"group_by":{"default":null,"type":["object","string"],"required":false},"having":{"default":null,"type":"object","required":false},"caps":{"default":"read","type":"string","enum":["read","read_admin","edit","delete"],"required":false}}}]},"\/ee\/v4.8.36\/wp_users\/(?P<id>[^\\\/]+)\/change_logs\/(?P<related_id>[^\\\/]+)":{"namespace":"ee\/v4.8.36","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/ee\/v4.8.36\/registrations\/(?P<REG_ID>\\d+)\/toggle_checkin_for_datetime\/(?P<DTT_ID>\\d+)":{"namespace":"ee\/v4.8.36","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"force":{"default":false,"description":"Whether to force toggle checkin, or to verify the registration status and allowed ticket uses","required":false}}}]},"\/google-site-kit\/v1":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"google-site-kit\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1"}]}},"\/google-site-kit\/v1\/core\/site\/data\/setup-tag":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/setup-tag"}]}},"\/google-site-kit\/v1\/core\/site\/data\/connection":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/connection"}]}},"\/google-site-kit\/v1\/core\/user\/data\/authentication":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/authentication"}]}},"\/google-site-kit\/v1\/core\/user\/data\/disconnect":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/disconnect"}]}},"\/google-site-kit\/v1\/core\/user\/data\/get-token":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/get-token"}]}},"\/google-site-kit\/v1\/core\/user\/data\/user-input-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"questions":{"purpose":{"type":"array","items":{"type":"string"}},"postFrequency":{"type":"array","items":{"type":"string"}},"goals":{"type":"array","items":{"type":"string"}},"includeConversionEvents":{"type":"array","items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/user-input-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/audience-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"configuredAudiences":{"type":"array","items":{"type":"string"}},"isAudienceSegmentationWidgetHidden":{"type":"boolean"},"didSetAudiences":{"type":"boolean"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/audience-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"newEventsCalloutDismissedAt":{"type":"integer"},"lostEventsCalloutDismissedAt":{"type":"integer"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/list":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/list"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/activation":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/activation"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/info"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/check-access":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/check-access"}]}},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"data":{"type":"object","description":"Settings to set.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/data-available":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/(?P<datapoint>[a-z\\-]+)":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"datapoint":{"type":"string","description":"Module data point to address.","default":null,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"datapoint":{"type":"string","description":"Module data point to address.","default":null,"required":false},"data":{"type":"object","description":"Data to set.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/core\/modules\/data\/recover-modules":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/recover-modules"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-items":{"namespace":"google-site-kit\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":{"data":{"type":"object","description":"","default":null,"minProperties":1,"additionalProperties":false,"properties":{"slugs":{"type":"array","required":true,"items":{"type":"string"}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-item":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-item"}]}},"\/google-site-kit\/v1\/core\/user\/data\/expirable-items":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/expirable-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","description":"","default":null,"items":{"type":"object","additionalProperties":false,"properties":{"slug":{"type":"string","required":true},"expiration":{"type":"integer","required":true}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers"}]}},"\/google-site-kit\/v1\/core\/user\/data\/permissions":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/permissions"}]}},"\/google-site-kit\/v1\/core\/user\/data\/nonces":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/nonces"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-trigger":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"triggerID":{"type":"string","required":true},"ttl":{"type":"integer","minimum":0}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-trigger"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-event":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"session":{"type":"object","required":true,"properties":{"session_id":{"type":"string","required":true},"session_token":{"type":"string","required":true}}},"event":{"type":"object","required":true,"properties":{"survey_shown":{"type":"object"},"survey_closed":{"type":"object"},"question_answered":{"type":"object"},"completion_shown":{"type":"object"},"follow_up_link_clicked":{"type":"object"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-event"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset-persistent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset-persistent"}]}},"\/google-site-kit\/v1\/core\/site\/data\/developer-plugin":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/developer-plugin"}]}},"\/google-site-kit\/v1\/core\/user\/data\/tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":true}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/tracking"}]}},"\/google-site-kit\/v1\/core\/search\/data\/entity-search":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"query":{"type":"string","description":"Text content to search for.","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/search\/data\/entity-search"}]}},"\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":false}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings"}]}},"\/google-site-kit\/v1\/core\/site\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/notifications"}]}},"\/google-site-kit\/v1\/core\/site\/data\/mark-notification":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/mark-notification"}]}},"\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test"}]}},"\/google-site-kit\/v1\/core\/site\/data\/health-checks":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/health-checks"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour"}]}},"\/google-site-kit\/v1\/core\/user\/data\/key-metrics":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"isWidgetHidden":{"type":"boolean","required":true},"widgetSlugs":{"type":"array","required":false,"maxItems":8,"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/key-metrics"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-mode":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean"},"regions":{"type":"array","items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-mode"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-info"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate"}]}},"\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status"}]}},"\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking"}]}},"\/bsf-core\/v1":{"namespace":"bsf-core\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"bsf-core\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/bsf-core\/v1"}]}},"\/bsf-core\/v1\/license\/activate":{"namespace":"bsf-core\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product-id":{"type":"string","required":true},"license-key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/bsf-core\/v1\/license\/activate"}]}},"\/nps-survey\/v1":{"namespace":"nps-survey\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"nps-survey\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/nps-survey\/v1"}]}},"\/nps-survey\/v1\/rating":{"namespace":"nps-survey\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nps_id":{"type":"string","required":true},"rating":{"type":"integer","required":true},"comment":{"type":"string","default":"","required":false},"plugin_slug":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/nps-survey\/v1\/rating"}]}},"\/nps-survey\/v1\/dismiss-nps-survey":{"namespace":"nps-survey\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nps_id":{"type":"string","required":true},"plugin_slug":{"type":"string","required":true},"dismiss_timespan":{"type":"integer","required":true},"current_step":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/nps-survey\/v1\/dismiss-nps-survey"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limit result set to items with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limit result set to items except those with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limit result set to items with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limit result set to items except those with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limit result set to items that are sticky.","type":"boolean","required":false},"ignore_sticky":{"description":"Whether to ignore sticky posts or not.","type":"boolean","default":true,"required":false},"format":{"description":"Limit result set to items assigned one or more given formats.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"The format for the post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Whether or not the post should be treated as sticky.","type":"boolean","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the post in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the post in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"The format for the post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Whether or not the post should be treated as sticky.","type":"boolean","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the post in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the post in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"The format for the post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Whether or not the post should be treated as sticky.","type":"boolean","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the post in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the post in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limit result set to items with particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"parent":{"description":"The ID for the parent of the post.","type":"integer","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"parent":{"description":"The ID for the parent of the post.","type":"integer","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limit result set to items with particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limit result set to attachments of a particular media type or media types.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Limit result set to attachments of a particular MIME type or MIME types.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"alt_text":{"description":"Alternative text to display when attachment is not displayed.","type":"string","required":false},"caption":{"description":"The attachment caption.","type":"object","properties":{"raw":{"description":"Caption for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML caption for the attachment, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"The attachment description.","type":"object","properties":{"raw":{"description":"Description for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML description for the attachment, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"The ID for the associated post of the attachment.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"alt_text":{"description":"Alternative text to display when attachment is not displayed.","type":"string","required":false},"caption":{"description":"The attachment caption.","type":"object","properties":{"raw":{"description":"Caption for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML caption for the attachment, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"The attachment description.","type":"object","properties":{"raw":{"description":"Description for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML description for the attachment, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"The ID for the associated post of the attachment.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the attachment.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL to the edited image file.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array of image edits.","type":"array","minItems":1,"items":{"description":"Image edit.","type":"object","required":["type","args"],"oneOf":[{"title":"Flip","properties":{"type":{"description":"Flip type.","type":"string","enum":["flip"]},"args":{"description":"Flip arguments.","type":"object","required":["flip"],"properties":{"flip":{"description":"Flip direction.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Whether to flip in the horizontal direction.","type":"boolean"},"vertical":{"description":"Whether to flip in the vertical direction.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Rotation type.","type":"string","enum":["rotate"]},"args":{"description":"Rotation arguments.","type":"object","required":["angle"],"properties":{"angle":{"description":"Angle to rotate clockwise in degrees.","type":"number"}}}}},{"title":"Crop","properties":{"type":{"description":"Crop type.","type":"string","enum":["crop"]},"args":{"description":"Crop arguments.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horizontal position from the left to begin the crop as a percentage of the image width.","type":"number"},"top":{"description":"Vertical position from the top to begin the crop as a percentage of the image height.","type":"number"},"width":{"description":"Width of the crop as a percentage of the image width.","type":"number"},"height":{"description":"Height of the crop as a percentage of the image height.","type":"number"}}}}}]},"required":false},"rotation":{"description":"The amount to rotate the image clockwise in degrees. DEPRECATED: Use `modifiers` instead.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"As a percentage of the image, the x position to start the crop from. DEPRECATED: Use `modifiers` instead.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"As a percentage of the image, the y position to start the crop from. DEPRECATED: Use `modifiers` instead.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"As a percentage of the image, the width to crop the image to. DEPRECATED: Use `modifiers` instead.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"As a percentage of the image, the height to crop the image to. DEPRECATED: Use `modifiers` instead.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"The attachment caption.","type":"object","properties":{"raw":{"description":"Caption for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML caption for the attachment, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"The attachment description.","type":"object","properties":{"raw":{"description":"Description for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML description for the attachment, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"The ID for the associated post of the attachment.","type":"integer","required":false},"alt_text":{"description":"Alternative text to display when attachment is not displayed.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limit result set to items with specific terms assigned in the menus taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limit result set to items except those with specific terms assigned in the menus taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"The title for the object.","type":["string","object"],"properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"The family of objects originally represented, such as \"post_type\" or \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"parent":{"default":0,"description":"The ID for the parent of the object.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text for the title attribute of the link element for this menu item.","type":"string","required":false},"classes":{"description":"Class names for the link element of this menu item.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"The description of this menu item.","type":"string","required":false},"menu_order":{"default":1,"description":"The DB ID of the nav_menu_item that is this item's menu parent, if any, otherwise 0.","type":"integer","minimum":1,"required":false},"object":{"description":"The type of object originally represented, such as \"category\", \"post\", or \"attachment\".","type":"string","required":false},"object_id":{"default":0,"description":"The database ID of the original object this menu item represents, for example the ID for posts or the term_id for categories.","type":"integer","minimum":0,"required":false},"target":{"description":"The target attribute of the link element for this menu item.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"The URL to which this menu item points.","type":"string","format":"uri","required":false},"xfn":{"description":"The XFN relationship expressed in the link of this menu item.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"The terms assigned to the object in the nav_menu taxonomy.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_pll_menu_item":{"type":"object","title":"","description":"Language switcher settings","default":[],"additionalProperties":{"type":"boolean"}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"title":{"description":"The title for the object.","type":["string","object"],"properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"The family of objects originally represented, such as \"post_type\" or \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"parent":{"description":"The ID for the parent of the object.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text for the title attribute of the link element for this menu item.","type":"string","required":false},"classes":{"description":"Class names for the link element of this menu item.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"The description of this menu item.","type":"string","required":false},"menu_order":{"description":"The DB ID of the nav_menu_item that is this item's menu parent, if any, otherwise 0.","type":"integer","minimum":1,"required":false},"object":{"description":"The type of object originally represented, such as \"category\", \"post\", or \"attachment\".","type":"string","required":false},"object_id":{"description":"The database ID of the original object this menu item represents, for example the ID for posts or the term_id for categories.","type":"integer","minimum":0,"required":false},"target":{"description":"The target attribute of the link element for this menu item.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"The URL to which this menu item points.","type":"string","format":"uri","required":false},"xfn":{"description":"The XFN relationship expressed in the link of this menu item.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"The terms assigned to the object in the nav_menu taxonomy.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_pll_menu_item":{"type":"object","title":"","description":"Language switcher settings","default":[],"additionalProperties":{"type":"boolean"}}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the object.","type":"integer","minimum":0,"required":false},"title":{"description":"The title for the object.","type":["string","object"],"properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"The family of objects originally represented, such as \"post_type\" or \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"attr_title":{"description":"Text for the title attribute of the link element for this menu item.","type":"string","required":false},"classes":{"description":"Class names for the link element of this menu item.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"The description of this menu item.","type":"string","required":false},"menu_order":{"description":"The DB ID of the nav_menu_item that is this item's menu parent, if any, otherwise 0.","type":"integer","minimum":1,"required":false},"object":{"description":"The type of object originally represented, such as \"category\", \"post\", or \"attachment\".","type":"string","required":false},"object_id":{"description":"The database ID of the original object this menu item represents, for example the ID for posts or the term_id for categories.","type":"integer","minimum":0,"required":false},"target":{"description":"The target attribute of the link element for this menu item.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"The URL to which this menu item points.","type":"string","format":"uri","required":false},"xfn":{"description":"The XFN relationship expressed in the link of this menu item.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"The terms assigned to the object in the nav_menu taxonomy.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_pll_menu_item":{"type":"object","title":"","description":"Language switcher settings","default":[],"additionalProperties":{"type":"boolean"}}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limit result set to items with specific terms assigned in the wp_pattern_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limit result set to items except those with specific terms assigned in the wp_pattern_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"wp_pattern_category":{"description":"The terms assigned to the post in the wp_pattern_category taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"wp_pattern_category":{"description":"The terms assigned to the post in the wp_pattern_category taxonomy.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"wp_pattern_category":{"description":"The terms assigned to the post in the wp_pattern_category taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The id of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The id of a template","type":"string","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The id of a template","type":"string","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The id of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"The id of a template","type":"string","required":false},"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description of template.","type":"string","required":false},"status":{"description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The id of a template","type":"string","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limit to the specified post id.","type":"integer","required":false},"area":{"description":"Limit to the specified template part area.","type":"string","required":false},"post_type":{"description":"Post type to get the templates for.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"default":"","description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Description of template.","type":"string","required":false},"status":{"default":"publish","description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"The slug of the template to get the fallback for","type":"string","required":true},"is_custom":{"description":"Indicates if a template is custom or part of the template hierarchy","type":"boolean","required":false},"template_prefix":{"description":"The template prefix for the created template. This is used to extract the main template type, e.g. in `taxonomy-books` extracts the `taxonomy`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The id of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"The id of a template","type":"string","required":false},"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description of template.","type":"string","required":false},"status":{"description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"The id of a template","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The id of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The id of a template","type":"string","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The id of a template","type":"string","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The id of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"The id of a template","type":"string","required":false},"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description of template.","type":"string","required":false},"status":{"description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false},"area":{"description":"Where the template part is intended for use (header, footer, etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The id of a template","type":"string","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limit to the specified post id.","type":"integer","required":false},"area":{"description":"Limit to the specified template part area.","type":"string","required":false},"post_type":{"description":"Post type to get the templates for.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"default":"","description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Description of template.","type":"string","required":false},"status":{"default":"publish","description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false},"area":{"description":"Where the template part is intended for use (header, footer, etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"The slug of the template to get the fallback for","type":"string","required":true},"is_custom":{"description":"Indicates if a template is custom or part of the template hierarchy","type":"boolean","required":false},"template_prefix":{"description":"The template prefix for the created template. This is used to extract the main template type, e.g. in `taxonomy-books` extracts the `taxonomy`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The id of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"The id of a template","type":"string","required":false},"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description of template.","type":"string","required":false},"status":{"description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false},"area":{"description":"Where the template part is intended for use (header, footer, etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"The id of a template","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the global styles revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the global styles revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"The theme identifier","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"The theme identifier","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID of global styles config.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Global styles.","type":["object"],"required":false},"settings":{"description":"Global settings.","type":["object"],"required":false},"title":{"description":"Title of the global styles variation.","type":["object","string"],"properties":{"raw":{"description":"Title for the global styles variation, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Version of the theme.json schema used for the typography settings.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"font-family declaration in theme.json format, encoded as a string.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"theme_json_version":{"description":"Version of the theme.json schema used for the typography settings.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"font-family declaration in theme.json format, encoded as a string.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"The ID for the parent font family of the font face.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"The ID for the parent font family of the font face.","type":"integer","required":true},"theme_json_version":{"description":"Version of the theme.json schema used for the typography settings.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"font-face declaration in theme.json format, encoded as a string.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"The ID for the parent font family of the font face.","type":"integer","required":true},"id":{"description":"Unique identifier for the font face.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"The ID for the parent font family of the font face.","type":"integer","required":true},"id":{"description":"Unique identifier for the font face.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/igmap":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limit result set to items with particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"parent":{"description":"The ID for the parent of the post.","type":"integer","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/igmap"}]}},"\/wp\/v2\/igmap\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"parent":{"description":"The ID for the parent of the post.","type":"integer","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/um_form":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/um_form"}]}},"\/wp\/v2\/um_form\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/um_directory":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/um_directory"}]}},"\/wp\/v2\/um_directory\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/application-stories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"application_stories_cat":{"description":"Limit result set to items with specific terms assigned in the application_stories_cat taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"application_stories_cat_exclude":{"description":"Limit result set to items except those with specific terms assigned in the application_stories_cat taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"application_stories_cat":{"description":"The terms assigned to the post in the application_stories_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/application-stories"}]}},"\/wp\/v2\/application-stories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"application_stories_cat":{"description":"The terms assigned to the post in the application_stories_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/application-stories\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"application_stories_cat":{"description":"The terms assigned to the post in the application_stories_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/application-stories\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/documents":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"documents_cat":{"description":"Limit result set to items with specific terms assigned in the documents_cat taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"documents_cat_exclude":{"description":"Limit result set to items except those with specific terms assigned in the documents_cat taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"documents_cat":{"description":"The terms assigned to the post in the documents_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/documents"}]}},"\/wp\/v2\/documents\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"documents_cat":{"description":"The terms assigned to the post in the documents_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/documents\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"documents_cat":{"description":"The terms assigned to the post in the documents_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/documents\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/headlines":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/headlines"}]}},"\/wp\/v2\/headlines\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/headlines\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/headlines\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pi-newsletters":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/pi-newsletters"}]}},"\/wp\/v2\/pi-newsletters\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/pi-newsletters\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/pi-newsletters\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/profibus_tech":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/profibus_tech"}]}},"\/wp\/v2\/profibus_tech\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/profibus_tech\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/profibus_tech\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/profinet_tech":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/profinet_tech"}]}},"\/wp\/v2\/profinet_tech\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/profinet_tech\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/profinet_tech\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/webinar":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"webinar_cat":{"description":"Limit result set to items with specific terms assigned in the webinar_cat taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"webinar_cat_exclude":{"description":"Limit result set to items except those with specific terms assigned in the webinar_cat taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"webinar_cat":{"description":"The terms assigned to the post in the webinar_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/webinar"}]}},"\/wp\/v2\/webinar\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"webinar_cat":{"description":"The terms assigned to the post in the webinar_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/webinar\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"webinar_cat":{"description":"The terms assigned to the post in the webinar_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/webinar\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/white-papers":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"white_papers_cat":{"description":"Limit result set to items with specific terms assigned in the white_papers_cat taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"white_papers_cat_exclude":{"description":"Limit result set to items except those with specific terms assigned in the white_papers_cat taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"white_papers_cat":{"description":"The terms assigned to the post in the white_papers_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/white-papers"}]}},"\/wp\/v2\/white-papers\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"white_papers_cat":{"description":"The terms assigned to the post in the white_papers_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/white-papers\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"white_papers_cat":{"description":"The terms assigned to the post in the white_papers_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/white-papers\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-courses":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"course_materials":{"description":"Course Materials","type":"html","required":false},"course_price_type":{"default":"open","description":"Course Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"Custom Button URL","type":"text","required":false},"course_price":{"description":"Course Price","type":"text","required":false},"course_prerequisite_enabled":{"default":false,"description":"Enable Course Prerequisites","type":"boolean","required":false},"course_prerequisite":{"default":[],"description":"Course Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"default":"ANY","description":"Course Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Enable Course Points","type":"boolean","required":false},"course_points":{"description":"Course Points","type":"number","required":false},"course_points_access":{"description":"Course Points Access","type":"number","required":false},"course_disable_lesson_progression":{"default":0,"description":"Disable Lesson Progression","type":"boolean","required":false},"expire_access":{"description":"Expire Access","type":"boolean","required":false},"expire_access_days":{"description":"Expire Access After (days)","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Course and Quiz Data After Expiration","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/sfwd-courses"}]}},"\/wp\/v2\/sfwd-courses\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"course_materials":{"description":"Course Materials","type":"html","required":false},"course_price_type":{"description":"Course Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"Custom Button URL","type":"text","required":false},"course_price":{"description":"Course Price","type":"text","required":false},"course_prerequisite_enabled":{"description":"Enable Course Prerequisites","type":"boolean","required":false},"course_prerequisite":{"description":"Course Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"description":"Course Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Enable Course Points","type":"boolean","required":false},"course_points":{"description":"Course Points","type":"number","required":false},"course_points_access":{"description":"Course Points Access","type":"number","required":false},"course_disable_lesson_progression":{"description":"Disable Lesson Progression","type":"boolean","required":false},"expire_access":{"description":"Expire Access","type":"boolean","required":false},"expire_access_days":{"description":"Expire Access After (days)","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Course and Quiz Data After Expiration","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/sfwd-courses\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-courses\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/sfwd-courses\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"course_materials":{"description":"Course Materials","type":"html","required":false},"course_price_type":{"description":"Course Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"Custom Button URL","type":"text","required":false},"course_price":{"description":"Course Price","type":"text","required":false},"course_prerequisite_enabled":{"description":"Enable Course Prerequisites","type":"boolean","required":false},"course_prerequisite":{"description":"Course Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"description":"Course Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Enable Course Points","type":"boolean","required":false},"course_points":{"description":"Course Points","type":"number","required":false},"course_points_access":{"description":"Course Points Access","type":"number","required":false},"course_disable_lesson_progression":{"description":"Disable Lesson Progression","type":"boolean","required":false},"expire_access":{"description":"Expire Access","type":"boolean","required":false},"expire_access_days":{"description":"Expire Access After (days)","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Course and Quiz Data After Expiration","type":"boolean","required":false}}}]},"\/wp\/v2\/sfwd-courses\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-lessons":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limit result set to items with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limit result set to items except those with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limit result set to items with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limit result set to items except those with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"ld_lesson_category":{"description":"Limit result set to items with specific terms assigned in the ld_lesson_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_lesson_category_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_lesson_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_lesson_tag":{"description":"Limit result set to items with specific terms assigned in the ld_lesson_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_lesson_tag_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_lesson_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the post in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the post in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_category":{"description":"The terms assigned to the post in the ld_lesson_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_tag":{"description":"The terms assigned to the post in the ld_lesson_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"lesson_materials":{"description":"Lesson Materials","type":"html","required":false},"forced_lesson_time":{"default":"","description":"Forced Lesson Timer","type":"text","required":false},"lesson_assignment_upload":{"default":0,"description":"Upload Assignment","type":"boolean","required":false},"auto_approve_assignment":{"default":"on","description":"Auto Approve Assignment","type":"boolean","required":false},"assignment_upload_limit_count":{"default":"1","description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_deletion_enabled":{"default":0,"description":"Allow Student to Delete own Assignment(s)","type":"boolean","required":false},"lesson_assignment_points_enabled":{"default":0,"description":"Award Points for Assignment","type":"boolean","required":false},"lesson_assignment_points_amount":{"default":0,"description":"Set Number of Points for Assignment","type":"number","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Allowed File Size","type":"text","required":false},"visible_after":{"default":0,"description":"Make Lesson visible X Days After Sign-up","type":"number","required":false},"visible_after_specific_date":{"description":"Make Lesson Visible on Specific Date","type":"wp_date_selector","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/sfwd-lessons"}]}},"\/wp\/v2\/sfwd-lessons\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the post in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the post in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_category":{"description":"The terms assigned to the post in the ld_lesson_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_tag":{"description":"The terms assigned to the post in the ld_lesson_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"lesson_materials":{"description":"Lesson Materials","type":"html","required":false},"forced_lesson_time":{"description":"Forced Lesson Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Upload Assignment","type":"boolean","required":false},"auto_approve_assignment":{"description":"Auto Approve Assignment","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_deletion_enabled":{"description":"Allow Student to Delete own Assignment(s)","type":"boolean","required":false},"lesson_assignment_points_enabled":{"description":"Award Points for Assignment","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Set Number of Points for Assignment","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false},"visible_after":{"description":"Make Lesson visible X Days After Sign-up","type":"number","required":false},"visible_after_specific_date":{"description":"Make Lesson Visible on Specific Date","type":"wp_date_selector","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/sfwd-lessons\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-lessons\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/sfwd-lessons\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the post in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the post in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_category":{"description":"The terms assigned to the post in the ld_lesson_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_lesson_tag":{"description":"The terms assigned to the post in the ld_lesson_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"lesson_materials":{"description":"Lesson Materials","type":"html","required":false},"forced_lesson_time":{"description":"Forced Lesson Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Upload Assignment","type":"boolean","required":false},"auto_approve_assignment":{"description":"Auto Approve Assignment","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_deletion_enabled":{"description":"Allow Student to Delete own Assignment(s)","type":"boolean","required":false},"lesson_assignment_points_enabled":{"description":"Award Points for Assignment","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Set Number of Points for Assignment","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false},"visible_after":{"description":"Make Lesson visible X Days After Sign-up","type":"number","required":false},"visible_after_specific_date":{"description":"Make Lesson Visible on Specific Date","type":"wp_date_selector","required":false}}}]},"\/wp\/v2\/sfwd-lessons\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-topic":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"ld_topic_category":{"description":"Limit result set to items with specific terms assigned in the ld_topic_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_category_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_topic_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_topic_tag":{"description":"Limit result set to items with specific terms assigned in the ld_topic_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_tag_exclude":{"description":"Limit result set to items except those with specific terms assigned in the ld_topic_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Lesson. Must be used with Course parameter.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"ld_topic_category":{"description":"The terms assigned to the post in the ld_topic_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"The terms assigned to the post in the ld_topic_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"topic_materials":{"description":"Topic Materials","type":"html","required":false},"forced_lesson_time":{"default":"","description":"Forced Topic Timer","type":"text","required":false},"lesson_assignment_upload":{"default":0,"description":"Upload Assignment","type":"boolean","required":false},"auto_approve_assignment":{"default":"on","description":"Auto Approve Assignment","type":"boolean","required":false},"assignment_upload_limit_count":{"default":"1","description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_points_enabled":{"default":0,"description":"Award Points for Assignment","type":"boolean","required":false},"lesson_assignment_points_amount":{"default":0,"description":"Set Number of Points for Assignment","type":"number","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Allowed File Size","type":"text","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/sfwd-topic"}]}},"\/wp\/v2\/sfwd-topic\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"ld_topic_category":{"description":"The terms assigned to the post in the ld_topic_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"The terms assigned to the post in the ld_topic_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"topic_materials":{"description":"Topic Materials","type":"html","required":false},"forced_lesson_time":{"description":"Forced Topic Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Upload Assignment","type":"boolean","required":false},"auto_approve_assignment":{"description":"Auto Approve Assignment","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_points_enabled":{"description":"Award Points for Assignment","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Set Number of Points for Assignment","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/sfwd-topic\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-topic\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/sfwd-topic\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"ld_topic_category":{"description":"The terms assigned to the post in the ld_topic_category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"The terms assigned to the post in the ld_topic_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"topic_materials":{"description":"Topic Materials","type":"html","required":false},"forced_lesson_time":{"description":"Forced Topic Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Upload Assignment","type":"boolean","required":false},"auto_approve_assignment":{"description":"Auto Approve Assignment","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_points_enabled":{"description":"Award Points for Assignment","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Set Number of Points for Assignment","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false}}}]},"\/wp\/v2\/sfwd-topic\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-quiz":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false},"course":{"description":"Limit results to be within a specific Course. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Lesson. Pass zero to show global Course Quizzes. Must be used with Course parameter.","type":"integer","required":false},"topic":{"description":"Limit results to be within a specific Topic. Must be used with Course parameter.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"quiz_materials":{"description":"Quiz Materials","type":"html","required":false},"threshold":{"default":"0.8","description":"Certificate Threshold","type":"text","required":false},"passingpercentage":{"default":"80","description":"Passing Percentage","type":"text","required":false},"certificate":{"default":"","description":"Associated Certificate","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/sfwd-quiz"}]}},"\/wp\/v2\/sfwd-quiz\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"quiz_materials":{"description":"Quiz Materials","type":"html","required":false},"threshold":{"description":"Certificate Threshold","type":"text","required":false},"passingpercentage":{"description":"Passing Percentage","type":"text","required":false},"certificate":{"description":"Associated Certificate","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/sfwd-quiz\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-quiz\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/sfwd-quiz\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"quiz_materials":{"description":"Quiz Materials","type":"html","required":false},"threshold":{"description":"Certificate Threshold","type":"text","required":false},"passingpercentage":{"description":"Passing Percentage","type":"text","required":false},"certificate":{"description":"Associated Certificate","type":"string","required":false}}}]},"\/wp\/v2\/sfwd-quiz\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-question":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"quiz":{"default":"","description":"Quiz ID.","type":"integer","required":false},"question_type":{"default":"single","description":"Question type.","type":"enum","enum":["single","multiple","free_answer","sort_answer","matrix_sort_answer","cloze_answer","assessment_answer","essay"],"required":false},"points_total":{"default":"","description":"Total Points amount","type":"integer","required":false},"points_per_answer":{"default":"","description":"Different points for each answer","type":"boolean","required":false},"points_show_in_message":{"default":"","description":"Show reached points in the correct\/incorrect message?","type":"boolean","required":false},"points_diff_modus":{"default":"","description":"Different points - modus 2 activate","type":"boolean","required":false},"disable_correct":{"default":"","description":"Disable answer correct setting.","type":"boolean","required":false},"correct_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"incorrect_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"correct_same":{"default":"","description":"Activate hint for this Question.","type":"boolean","required":false},"hints_enabled":{"default":"","description":"Activate hint for this Question.","type":"boolean","required":false},"hints_message":{"description":"Hint message.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"answers":{"description":"Question answer sets.","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/sfwd-question"}]}},"\/wp\/v2\/sfwd-question\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"quiz":{"description":"Quiz ID.","type":"integer","required":false},"question_type":{"description":"Question type.","type":"enum","enum":["single","multiple","free_answer","sort_answer","matrix_sort_answer","cloze_answer","assessment_answer","essay"],"required":false},"points_total":{"description":"Total Points amount","type":"integer","required":false},"points_per_answer":{"description":"Different points for each answer","type":"boolean","required":false},"points_show_in_message":{"description":"Show reached points in the correct\/incorrect message?","type":"boolean","required":false},"points_diff_modus":{"description":"Different points - modus 2 activate","type":"boolean","required":false},"disable_correct":{"description":"Disable answer correct setting.","type":"boolean","required":false},"correct_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"incorrect_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"correct_same":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_enabled":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_message":{"description":"Hint message.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"answers":{"description":"Question answer sets.","type":"object","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/sfwd-question\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-question\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/sfwd-question\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"quiz":{"description":"Quiz ID.","type":"integer","required":false},"question_type":{"description":"Question type.","type":"enum","enum":["single","multiple","free_answer","sort_answer","matrix_sort_answer","cloze_answer","assessment_answer","essay"],"required":false},"points_total":{"description":"Total Points amount","type":"integer","required":false},"points_per_answer":{"description":"Different points for each answer","type":"boolean","required":false},"points_show_in_message":{"description":"Show reached points in the correct\/incorrect message?","type":"boolean","required":false},"points_diff_modus":{"description":"Different points - modus 2 activate","type":"boolean","required":false},"disable_correct":{"description":"Disable answer correct setting.","type":"boolean","required":false},"correct_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"incorrect_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"correct_same":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_enabled":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_message":{"description":"Hint message.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"answers":{"description":"Question answer sets.","type":"object","required":false}}}]},"\/wp\/v2\/sfwd-question\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/ld-exam":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/ld-exam"}]}},"\/wp\/v2\/ld-exam\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/ld-exam\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/ld-exam\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/ld-exam\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/ld-exam\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-certificates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/sfwd-certificates"}]}},"\/wp\/v2\/sfwd-certificates\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/sfwd-certificates\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-certificates\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/sfwd-certificates\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/sfwd-certificates\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/groups":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/groups"}]}},"\/wp\/v2\/groups\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/groups\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/groups\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/fl-builder-template":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","graded","not_graded","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/fl-builder-template"}]}},"\/wp\/v2\/fl-builder-template\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's timezone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","graded","not_graded"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false}}}]},"\/wp\/v2\/fl-builder-template\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/fl-builder-template\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"An alphanumeric identifier for the post type.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"An alphanumeric identifier for the status.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limit results to taxonomies associated with a specific post type.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"An alphanumeric identifier for the taxonomy.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to terms assigned to a specific parent.","type":"integer","required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false},"locations":{"description":"The locations assigned to the menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Whether to automatically add top level pages to this menu.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false},"locations":{"description":"The locations assigned to the menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Whether to automatically add top level pages to this menu.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/application_stories_cat":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/application_stories_cat"}]}},"\/wp\/v2\/application_stories_cat\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/documents_cat":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/documents_cat"}]}},"\/wp\/v2\/documents_cat\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/webinar_cat":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/webinar_cat"}]}},"\/wp\/v2\/webinar_cat\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/white_papers_cat":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/white_papers_cat"}]}},"\/wp\/v2\/white_papers_cat\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/espresso_event_categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to terms assigned to a specific parent.","type":"integer","required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/espresso_event_categories"}]}},"\/wp\/v2\/espresso_event_categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/espresso_venue_categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to terms assigned to a specific parent.","type":"integer","required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/espresso_venue_categories"}]}},"\/wp\/v2\/espresso_venue_categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/espresso_event_type":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to terms assigned to a specific parent.","type":"integer","required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/espresso_event_type"}]}},"\/wp\/v2\/espresso_event_type\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/ld_lesson_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to terms assigned to a specific parent.","type":"integer","required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/ld_lesson_category"}]}},"\/wp\/v2\/ld_lesson_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/ld_lesson_tag":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/ld_lesson_tag"}]}},"\/wp\/v2\/ld_lesson_tag\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/ld_topic_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to terms assigned to a specific parent.","type":"integer","required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/ld_topic_category"}]}},"\/wp\/v2\/ld_topic_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/ld_topic_tag":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/ld_topic_tag"}]}},"\/wp\/v2\/ld_topic_tag\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support trashing.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sort collection by user attribute.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limit result set to users with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limit result set to users matching at least one specific role provided. Accepts csv list or single role.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limit result set to users matching at least one specific capability provided. Accepts csv list or single capability.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limit result set to users who are considered authors.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limit result set to users who have published posts.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","igmap":"igmap","um_form":"um_form","um_directory":"um_directory","application-stories":"application-stories","documents":"documents","headlines":"headlines","pi-newsletters":"pi-newsletters","profibus_tech":"profibus_tech","profinet_tech":"profinet_tech","webinar":"webinar","white-papers":"white-papers","sfwd-courses":"sfwd-courses","sfwd-lessons":"sfwd-lessons","sfwd-topic":"sfwd-topic","sfwd-quiz":"sfwd-quiz","sfwd-question":"sfwd-question","ld-exam":"ld-exam","sfwd-certificates":"sfwd-certificates","groups":"groups","fl-builder-template":"fl-builder-template"}},"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Login name for the user.","type":"string","required":true},"name":{"description":"Display name for the user.","type":"string","required":false},"first_name":{"description":"First name for the user.","type":"string","required":false},"last_name":{"description":"Last name for the user.","type":"string","required":false},"email":{"description":"The email address for the user.","type":"string","format":"email","required":true},"url":{"description":"URL of the user.","type":"string","format":"uri","required":false},"description":{"description":"Description of the user.","type":"string","required":false},"locale":{"description":"Locale for the user.","type":"string","enum":["","en_US","es_MX","event_espresso-es_MX"],"required":false},"nickname":{"description":"The nickname for the user.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the user.","type":"string","required":false},"roles":{"description":"Roles assigned to the user.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Password for the user (never included).","type":"string","required":true},"meta":{"description":"Meta fields.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"The date and time the preferences were updated.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the user.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the user.","type":"integer","required":false},"username":{"description":"Login name for the user.","type":"string","required":false},"name":{"description":"Display name for the user.","type":"string","required":false},"first_name":{"description":"First name for the user.","type":"string","required":false},"last_name":{"description":"Last name for the user.","type":"string","required":false},"email":{"description":"The email address for the user.","type":"string","format":"email","required":false},"url":{"description":"URL of the user.","type":"string","format":"uri","required":false},"description":{"description":"Description of the user.","type":"string","required":false},"locale":{"description":"Locale for the user.","type":"string","enum":["","en_US","es_MX","event_espresso-es_MX"],"required":false},"nickname":{"description":"The nickname for the user.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the user.","type":"string","required":false},"roles":{"description":"Roles assigned to the user.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Password for the user (never included).","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"The date and time the preferences were updated.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the user.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as users do not support trashing.","required":false},"reassign":{"type":"integer","description":"Reassign the deleted user's posts and links to this user ID.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Login name for the user.","type":"string","required":false},"name":{"description":"Display name for the user.","type":"string","required":false},"first_name":{"description":"First name for the user.","type":"string","required":false},"last_name":{"description":"Last name for the user.","type":"string","required":false},"email":{"description":"The email address for the user.","type":"string","format":"email","required":false},"url":{"description":"URL of the user.","type":"string","format":"uri","required":false},"description":{"description":"Description of the user.","type":"string","required":false},"locale":{"description":"Locale for the user.","type":"string","enum":["","en_US","es_MX","event_espresso-es_MX"],"required":false},"nickname":{"description":"The nickname for the user.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the user.","type":"string","required":false},"roles":{"description":"Roles assigned to the user.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Password for the user (never included).","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"The date and time the preferences were updated.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Required to be true, as users do not support trashing.","required":false},"reassign":{"type":"integer","description":"Reassign the deleted user's posts and links to this user ID.","required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"A UUID provided by the application to uniquely identify it. It is recommended to use an UUID v5 with the URL or DNS namespace.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"The name of the application password.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"A UUID provided by the application to uniquely identify it. It is recommended to use an UUID v5 with the URL or DNS namespace.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"The name of the application password.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to comments published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to comments assigned to specific user IDs. Requires authorization.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Ensure result set excludes comments assigned to specific user IDs. Requires authorization.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limit result set to that from a specific author email. Requires authorization.","format":"email","type":"string","required":false},"before":{"description":"Limit response to comments published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by comment attribute.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limit result set to comments of specific parent IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Ensure result set excludes specific parent IDs.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limit result set to comments assigned to specific post IDs.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limit result set to comments assigned a specific status. Requires authorization.","type":"string","required":false},"type":{"default":"comment","description":"Limit result set to comments assigned a specific type. Requires authorization.","type":"string","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"The ID of the user object, if author was a user.","type":"integer","required":false},"author_email":{"description":"Email address for the comment author.","type":"string","format":"email","required":false},"author_ip":{"description":"IP address for the comment author.","type":"string","format":"ip","required":false},"author_name":{"description":"Display name for the comment author.","type":"string","required":false},"author_url":{"description":"URL for the comment author.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User agent for the comment author.","type":"string","required":false},"content":{"description":"The content for the comment.","type":"object","properties":{"raw":{"description":"Content for the comment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the comment, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"The date the comment was published, in the site's timezone.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"The date the comment was published, as GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"The ID for the parent of the comment.","type":"integer","required":false},"post":{"default":0,"description":"The ID of the associated post object.","type":"integer","required":false},"status":{"description":"State of the comment.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Note resolution status","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the comment.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the parent post of the comment (if the post is password protected).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the comment.","type":"integer","required":false},"author":{"description":"The ID of the user object, if author was a user.","type":"integer","required":false},"author_email":{"description":"Email address for the comment author.","type":"string","format":"email","required":false},"author_ip":{"description":"IP address for the comment author.","type":"string","format":"ip","required":false},"author_name":{"description":"Display name for the comment author.","type":"string","required":false},"author_url":{"description":"URL for the comment author.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User agent for the comment author.","type":"string","required":false},"content":{"description":"The content for the comment.","type":"object","properties":{"raw":{"description":"Content for the comment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the comment, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"The date the comment was published, in the site's timezone.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"The date the comment was published, as GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"The ID for the parent of the comment.","type":"integer","required":false},"post":{"description":"The ID of the associated post object.","type":"integer","required":false},"status":{"description":"State of the comment.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Note resolution status","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the comment.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Trash and force deletion.","required":false},"password":{"description":"The password for the parent post of the comment (if the post is password protected).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"type":{"default":"post","description":"Limit results to items of an object type.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limit results to items of one or more object subtypes.","type":"array","items":{"enum":["post","page","application-stories","documents","headlines","pi-newsletters","profibus_tech","profinet_tech","webinar","white-papers","sfwd-courses","sfwd-lessons","sfwd-topic","sfwd-quiz","ld-exam","sfwd-certificates","category","post_tag","application_stories_cat","documents_cat","webinar_cat","white_papers_cat","espresso_event_categories","espresso_venue_categories","espresso_event_type","ld_lesson_category","ld_lesson_tag","ld_topic_category","ld_topic_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Unique registered name for the block.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attributes for the block.","type":"object","default":[],"required":false},"post_id":{"description":"ID of the post context.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block namespace.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block namespace.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Block name.","type":"string","required":false},"namespace":{"description":"Block namespace.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"Title","description":"Site title.","type":"string","required":false},"description":{"title":"Tagline","description":"Site tagline.","type":"string","required":false},"url":{"title":"","description":"Site URL.","type":"string","format":"uri","required":false},"email":{"title":"","description":"This address is used for admin purposes, like new user notification.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"A city in the same timezone as you.","type":"string","required":false},"date_format":{"title":"","description":"A date format for all date strings.","type":"string","required":false},"time_format":{"title":"","description":"A time format for all time strings.","type":"string","required":false},"start_of_week":{"title":"","description":"A day number of the week that the week should start on.","type":"integer","required":false},"language":{"title":"","description":"WordPress locale code.","type":"string","required":false},"use_smilies":{"title":"","description":"Convert emoticons like :-) and :-P to graphics on display.","type":"boolean","required":false},"default_category":{"title":"","description":"Default post category.","type":"integer","required":false},"default_post_format":{"title":"","description":"Default post format.","type":"string","required":false},"posts_per_page":{"title":"Maximum posts per page","description":"Blog pages show at most.","type":"integer","required":false},"show_on_front":{"title":"Show on front","description":"What to show on the front page","type":"string","required":false},"page_on_front":{"title":"Page on front","description":"The ID of the page that should be displayed on the front page","type":"integer","required":false},"page_for_posts":{"title":"","description":"The ID of the page that should display the latest posts","type":"integer","required":false},"default_ping_status":{"title":"","description":"Allow link notifications from other blogs (pingbacks and trackbacks) on new articles.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Allow comments on new posts","description":"Allow people to submit comments on new posts.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Site logo.","type":"integer","required":false},"site_icon":{"title":"Icon","description":"Site icon.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limit result set to themes assigned one or more statuses.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"The theme's stylesheet. This uniquely identifies the theme.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"status":{"description":"Limits results to plugins with the given status.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","pattern":"[\\w\\-]+","required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"The plugin activation status.","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The id of a registered sidebar","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Nested widgets.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The widget type id.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"The widget type id.","type":"string","required":true},"instance":{"description":"Current instance settings of the widget.","type":"object","required":false},"form_data":{"description":"Serialized widget form data to encode into instance settings.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"The widget type id.","type":"string","required":true},"instance":{"description":"Current instance settings of the widget.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"The sidebar to return widgets for.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the widget.","type":"string","required":false},"id_base":{"description":"The type of the widget. Corresponds to ID in widget-types endpoint.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"The sidebar the widget belongs to.","type":"string","required":true},"instance":{"description":"Instance settings of the widget, if supported.","type":"object","properties":{"encoded":{"description":"Base64 encoded representation of the instance settings.","type":"string","context":["edit"]},"hash":{"description":"Cryptographic hash of the instance settings.","type":"string","context":["edit"]},"raw":{"description":"Unencoded instance settings, if supported.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-encoded form data from the widget admin form. Used to update a widget that does not support instance. Write only.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the widget.","type":"string","required":false},"id_base":{"description":"The type of the widget. Corresponds to ID in widget-types endpoint.","type":"string","required":false},"sidebar":{"description":"The sidebar the widget belongs to.","type":"string","required":false},"instance":{"description":"Instance settings of the widget, if supported.","type":"object","properties":{"encoded":{"description":"Base64 encoded representation of the instance settings.","type":"string","context":["edit"]},"hash":{"description":"Cryptographic hash of the instance settings.","type":"string","context":["edit"]},"raw":{"description":"Unencoded instance settings, if supported.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-encoded form data from the widget admin form. Used to update a widget that does not support instance. Write only.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Whether to force removal of the widget, or move it to the inactive sidebar.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limit result set to blocks matching the search term.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","minLength":1,"required":false},"category":{"description":"Limit results to those matching a category ID.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limit results to those matching a keyword ID.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limit results to those matching a pattern (slug).","type":"array","required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"The URL to process.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"An alphanumeric identifier for the menu location.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Unique identifier for the ability category.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Unique identifier for the ability.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Input parameters for the ability execution.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limit results to abilities in specific ability category.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/us.profinet.com\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Unique identifier for the ability.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]}},"site_logo":0,"site_icon":17984,"site_icon_url":"https:\/\/us.profinet.com\/wp-content\/uploads\/2018\/08\/cropped-PI-North-America-Icon.png","ee":{"version":"5.0.19.p","documentation_url":"https:\/\/github.com\/eventespresso\/event-espresso-core\/tree\/master\/docs\/C--REST-API","addons":{"Attendee_Mover":{"name":"Attendee_Mover","version":"1.0.7.p"},"Events_Table_Template":{"name":"Events_Table_Template","version":"1.3.9.p"},"Stripe_Gateway":{"name":"Stripe_Gateway","version":"1.1.13.p"},"EE_WPUsers":{"name":"EE_WPUsers","version":"2.1.2.p"}},"maintenance_mode":0,"served_core_versions":["4.8.29","4.8.33","4.8.34","4.8.36"]},"_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/us.profinet.com\/wp-json\/wp\/v2\/media\/17984"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
