Industrial Networks
Mar 20
Can PROFINET and Ethernet Employ the Same Switch?
Switches are crucial components in industrial networks. They are commonly implemented in PROFINET configurations to deploy various topology options (i.e., tree, star, line, ring). But are those switches able to handle PROFINET telegrams and other Ethernet traffic? PROFINET can coexist with other Ethernet-based protocols in the same network and share network infrastructure, such as switches…
Read More
Mar 12
The Difference Between Ethernet and Industrial Ethernet
The terms Ethernet and Industrial Ethernet often create confusion as they are often used interchangeably. This post makes a comparison between Ethernet and Industrial Ethernet. Ethernet and Industrial Ethernet are the same thing. The only difference is that Industrial Ethernet includes running Ethernet traffic over more ruggedized hardware. For example, the cabling employed for Ethernet-based…
Read More
Oct 15
Fieldbus vs 4-20 mA – A Comprehensive Comparison
This blog post explains one of the most dramatic evolutions in Industrial Automation: The transition from 4-20 mA to digital Fieldbuses. It compares the two and highlights key benefits and new business models arising from the implementation of fieldbuses. The Difference Between 4–20 mA and Digital Fieldbuses The factory floor has evolved dramatically over the…
Read More
Feb 15
What about Fiber in Hazardous Environments?
Is fiber ok in hazardous environments*? We got this question in one of our PROFINET one-day training classes while explaining APL (Advanced Physical Layer).  Ethernet is not intrinsically safe. Since IEEE 100BASE-TX Ethernet is the base technology for PROFINET, PROFINET cannot reach hazardous environments. There are options to go around this limitation. Some factories employ containment methods…
Read More
Jul 15
Bringing Ethernet to the Plant Floor
Bringing Ethernet to the Plant Floor? Seven critical things to know before you do it. 1.  Do not to take Office topologies to the plant floor but implement plant/machine topologies with Ethernet. Office Ethernet infrastructures are typically based on commercial grade products meant to be located in a temperature controlled environment and Ethernet switches designed…
Read More
Aug 8
Secure Your Network!
Your network is not secure! Whether you have all the security in place that’s possible or have not even thought about security – your network is not secure! Sadly, no network can be 100% secure. The best that you can hope for is to make it very difficult to hack. Let’s start at one of…
Read More
Feb 28
Choosing an Industrial Ethernet, a Checklist
What should you look for when choosing an Industrial Ethernet? These things: Is it an open standard? Can anyone build products for it? PROFINET is an open standard. It’s part of IEC 61158. Anyone can buy the spec from IEC and build products. To build an EtherNet/IP product, you must sign a contract with ODVA,…
Read More
Jan 24
The Importance of Open Standards
What makes a standard open? I’ve blogged that question before: Open Standards, Proprietary Standards, and in Between Open Networks: What’s in it for you? We just completed an update to our free PROFINET one-day training class material. In the course of that exercise we uncovered more detailed definitions. Institute for Electrical and Electronics Engineers (IEEE),…
Read More
Sep 27
Is That a Protocol?
Are these protocols: RS-232, Ethernet, OPC UA, PROFINET, MQTT? What is a protocol, specifically a network protocol? Merriam Webster says “a set of conventions governing the treatment and especially the formatting of data in an electronic communications system <network protocols>” This seems incomplete to me, so here’s Techopedia’s definition: “Network protocols are formal standards and…
Read More
Apr 12
What did the blender say to the toaster?
What did the blender say to the toaster? I don’t know, but that apparently happens in the Internet of Things. What did the I/O block say to the PLC? Here’s my inputs and thanks for the outputs.  That’s the Industrial Internet of Things. When I read articles about the Internet of Things, I find them…
Read More
Categories
